Codegen Tools V5.1.6 is available
A production patch for the Codegen 5.1.x build stream is has been released:
- For more information contact:
- ClearQuest ID: SDSCM00008363
- Headline: Link-time errors with assert pragma
- Fixed in Version: 5.1.6
- ClearQuest ID: SDSCM00029328
- Headline: Missing warning when place an initialized symbol in an un-initialized section using the DATA_SECTION pragma under C++
- ClearQuest ID: SDSCM00029984
- Headline: Difference in output due to various optimization levels
- ClearQuest ID: SDSCM00030311
- Headline: Provide user visibility to the __fmax and __fmin intrinsics
- ClearQuest ID: SDSCM00031732
- Headline: Generated assembly code for whole_program build never reaches a call to Swi_post()
- ClearQuest ID: SDSCM00031975
- Headline: Using _enable_interrupts() intrinsic causes c28 FP linker error
- ClearQuest ID: SDSCM00032116
- Headline: Compiler incorrectly reorders subsequent accesses to global variable
- ClearQuest ID: SDSCM00032325
- Headline: Free mismatched memory bug in C2000 shell
- ClearQuest ID: SDSCM00032470
- Headline: PC optimizer segmentation fault under eabi while processing huge function with lots of if/else statements and huge structures
- ClearQuest ID: SDSCM00032672
- Headline: Highly inefficient use of stack space
- ClearQuest ID: SDSCM00032746
- Headline: Using designated initializers on unions causes the parser to crash
- ClearQuest ID: SDSCM00033071
- Headline: Inlining of __disable_interrupts intrinsic causes application error
- ClearQuest ID: SDSCM00033245
- Headline: Internal "Decomposition error" associated with struct field of an enumerated type when --small_enum is used
- ClearQuest ID: SDSCM00033288
- Headline: Using DATA_ALIGN pragma causes incorrect load of data page
- ClearQuest ID: SDSCM00033302
- Headline: Compiler does not issue error when a variable length array is seen with --gcc and --c99 options are used
- ClearQuest ID: SDSCM00033320
- Headline: Abnormal termination - very large switch case list
- ClearQuest ID: SDSCM00033394
- Headline: Executables created on different PCs have different ordering of sections
- ClearQuest ID: SDSCM00033398
- Headline: GCC Extension Support Parser does not accept a while-do as the last statement in a statement expression
- ClearQuest ID: SDSCM00033448
- Headline: GCC Extensions Parser crashes on case involving statement expression
- ClearQuest ID: SDSCM00033490
- Headline: Store and load to same structure member getting swapped
- ClearQuest ID: SDSCM00033532
- Headline: LDW and STW occur in incorrect order causing wrong result
- ClearQuest ID: SDSCM00033570
- Headline: Incorrect encoding for assembly instruction
- ClearQuest ID: SDSCM00033671
- Headline: Incorrect code generated for loop with a read from x[0] and a write to x[i] on each iteration
- ClearQuest ID: SDSCM00033677
- Headline: The 'run' address from the linker uses a different 'load' address if 'load' not specified
- ClearQuest ID: SDSCM00033691
- ClearQuest ID: SDSCM00033770
- Headline: The compiler generates incorrect code with a conditional function call
- ClearQuest ID: SDSCM00033811
- Headline: Error message "INTERNAL ERROR Decomposition error" is displayed when compiling with the --gen_profile_info flag
- ClearQuest ID: SDSCM00033846
- Headline: The linker is overwriting sections while merging sections
- ClearQuest ID: SDSCM00033854
- Headline: The compiler ignores all but the last --preinclude option
- ClearQuest ID: SDSCM00033878
- Headline: C2000 compiler generates a SP relative index offset larger than 63
- ClearQuest ID: SDSCM00033905
- Headline: Test fails msp benchmark
- ClearQuest ID: SDSCM00033942
- Headline: The compiler removes a "value = ~value;" expression
- ClearQuest ID: SDSCM00034078
- Headline: Compiler ignores restrict qualifier on a C++ reference type struct argument
- ClearQuest ID: SDSCM00034147
- Headline: The compiler incorrectly accesses ioport variables
- ClearQuest ID: SDSCM00034228
- Headline: Codegen seg fault
- ClearQuest ID: SDSCM00034230
- Headline: Codegen assertion failure
- ClearQuest ID: SDSCM00034533
- Headline: Incorrect code generated for a const variable in a loop when compiled with optimizeation -o1or higher
- ClearQuest ID: SDSCM00034557
- Headline: Compiler generates incorrect code for certain arithmetic with mixed types
- ClearQuest ID: SDSCM00034773
- Headline: Syntax (and acc,#~(3 << 8)) not accepted by assembler
- ClearQuest ID: SDSCM00035027
- Headline: Compiler mishandles long expressions when building with -mf
- ClearQuest ID: SDSCM00035082
- Headline: Including math.h inside extern "C" gives errors
- ClearQuest ID: SDSCM00035153
- Headline: CGT Optimizer terminated abnormally
- ClearQuest ID: SDSCM00035306
- Headline: The compiler may produce incorrect code when a static local variable appears as part of an argument to a function call
- ClearQuest ID: SDSCM00035361
- Headline: Assembler sometimes mistranslates C2LP branch conditional with two parameters
- ClearQuest ID: SDSCM00035399
- Headline: Under certain conditions, the compiler may unroll a loop more times than the loop will actually iterate
- ClearQuest ID: SDSCM00035418
- Headline: Bitwise ops on memory access may go wrong if op assign in register promotion
- ClearQuest ID: SDSCM00035422
- Headline: When building a relocatable executable, linker omits relocation entries from the .debug_info section
- ClearQuest ID: SDSCM00035558
- Headline: Fix shell memory allocation errors in the compiler shell
- ClearQuest ID: SDSCM00035618
- Headline: C2000 FPU assembler error messages incorrect/inconsistent
- ClearQuest ID: SDSCM00035624
- Headline: Optimized conditional statement results in Z-flag being used from the wrong MOV statement
- ClearQuest ID: SDSCM00035755
- Headline: Compiler drops MINL and MAXL instructions, leaves MINCUL, MAXCUL
- ClearQuest ID: SDSCM00035917
- Headline: GCC language extension allowing arithmetic on void* pointers generates incorrect code
- ClearQuest ID: SDSCM00035932
- Headline: C2800 compiler sometimes fails to test conditions before branching
- ClearQuest ID: SDSCM00035996
- Headline: C2000 CGT generates incorrect code with __f32_max_idx/__f32_min_idx intrinsics
- ClearQuest ID: SDSCM00036371
- Headline: Address shell crash reports
- ClearQuest ID: SDSCM00036839
- Headline: c60_ofd does not properly load attributes
- ClearQuest ID: SDSCM00036896
- Headline: Internal error on memcpy() used for value when optimization is used
- ClearQuest ID: SDSCM00038871
- Headline: bug when using -plink optimization option
