TMS320F280049: LIN controller IP general questions
Part Number: TMS320F280049
Hi expert,
I'd like to have answer of below two questions:
1. Does the LIN controller have message based or byte level Tx Rx behavior?
2. Please provide a diagram showing how the LIN controller samples the data (i.e., 3 samples at tq 7, 8 and 9, 1 sample at tq 8, etc.)
Sheldon
  • Hi Sheldon,
    I am not sure what you mean by message based, LIN transmits/receives data in bytes.
    I am not sure what you mean by 3 samples at tq 7, 8 and 9? Also, not sure what diagram you are looking for in terms of data sampling?
    LIN message frame has a protocol, with a start and stop bit, along with data and PID. All of it is explained in the TRM, do you want to know how to calculate baud rate?
    Nirav
  • Hi Nirav,
    Thanks for your reply!
    As for the second question, we need design level information on how voltage level is qualified/sampled internally in the LIN module. It could be some digram like "Figure 27-4. Asynchronous Communication Bit Timing" in device datasheet.
    Sheldon
