Part Number: TMS320F28379D
Greetings,
I generated a linker command file using a union construct. In the hopes of not needing to specify the object file etc for each entry in the union, I tried removing that information. The linker accepted it and produced the output. Is this the expected result? If the code contained more than one place with a given name, would they simply be concatenated? I guess I’m going beyond the basics now. Is there any documentation which could help? The syntax used is below:
UNION
NAME1
NAME2
} > MEMORY_VALUE, PAGE = 1
Thank you,
Ed
