TMS320F280049C: Implementing HR duty and period control in up-count mode
Part Number: TMS320F280049C
Champs,
I am working to enable both duty cycle and period high resolution control and in up-count mode. I am working off hrpwm_ex1_duty_sfo_v8.c example provided in c2000ware under c:\ti\c2000\C2000Ware_3_03_00_00\device_support\f28004x\examples\hrpwm\.
The HR duty cycle control works fine but when I add HR period control following the procedure from the TRM I observe ~ 2Khz frequency jitter in the output signal (477Khz). The jitter goes away when I use TBPRDHR close to zero but when I assign there a value I need to achieve better period accuracy it starts jittering. The up-down example seems to work ok. I've seen this issue reported here on the forum in several threads but haven't seen a solution. There was a suggestion to use TRREM but I am not sure how to do it. The example I found in c:\ti\c2000\C2000Ware_3_03_00_00\device_support\f2838x\examples\cpu1\hrpwm\hrpwm_ex4_deadband_sfo_v8.c seems pretty involved and I am not sure it is really needed to just generate PWM output with a period that falls somewhere between adjacent TBPRD values.
I am attaching the example file I currently have, it can be dropped straight into the example project. Will greatly appreciate your guidance.
Michael
// FILE:    hrpwm_ex1_duty_sfo_v8.c
// TITLE:   HRPWM SFO V8 High-Resolution Period
//          (Up Count) example
//! \addtogroup bitfield_example_list
//! <h1>HRPWM Duty Up Count</h1>
//! This example modifies the MEP control registers to show edge displacement
//! for high-resolution period with ePWM in Up count mode
//! due to the HRPWM control extension of the respective ePWM module.
//! This example calls the following TI's MEP Scale Factor Optimizer (SFO)
//! software library V8 functions:
//! \b int \b SFO(); \n
//! updates MEP_ScaleFactor dynamically when HRPWM is in use
//! updates HRMSTEP register (exists only in EPwm1Regs register space)
//! with MEP_ScaleFactor value
//! - returns 2 if error: MEP_ScaleFactor is greater than maximum value of 255
//!   (Auto-conversion may not function properly under this condition)
//! - returns 1 when complete for the specified channel
//! - returns 0 if not complete for the specified channel
//! This example is intended to explain the HRPWM capabilities. The code can be
//! optimized for code efficiency. Refer to TI's Digital power application
//! examples and TI Digital Power Supply software libraries for details.
//! To run this example:
//! -# Run this example at maximum SYSCLKOUT
//! -# Activate Real time mode
//! -# Run the code
//! \b External \b Connections \n
//!  - Monitor ePWM1 A/B pins on an oscilloscope.
//! \b Watch \b Variables \n
//!  - status - Example run status
//!  - UpdateFine - Set to 1 use HRPWM capabilities and observe in fine MEP
//!                 steps(default)
//!                 Set to 0 to disable HRPWM capabilities and observe in
//!                 coarse SYSCLKOUT cycle steps
// $TI Release: F28004x Support Library v1.11.00.00 $
// $Release Date: Sun Oct  4 15:49:15 IST 2020 $
// $Copyright:
// Copyright (C) 2020 Texas Instruments Incorporated - http://www.ti.com/
// Redistribution and use in source and binary forms, with or without
// modification, are permitted provided that the following conditions
// are met:
//   Redistributions of source code must retain the above copyright
//   notice, this list of conditions and the following disclaimer.
//   Redistributions in binary form must reproduce the above copyright
//   notice, this list of conditions and the following disclaimer in the
//   documentation and/or other materials provided with the
//   distribution.
//   Neither the name of Texas Instruments Incorporated nor the names of
//   its contributors may be used to endorse or promote products derived
//   from this software without specific prior written permission.
// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
// "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
// LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
// OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
// SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
// LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
// DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
// THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
// (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
// OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
// Included Files
#include "F28x_Project.h"
#include "SFO_V8.h"
// Defines
#define PWM_CH            2       // # of PWM channels - 1
#define STATUS_SUCCESS    1
#define STATUS_FAIL       0
#define AUTOCONVERT       1       // 1 = Turn auto-conversion ON
                                  // 0 = Turn auto-conversion OFF
// Globals
uint16_t UpdateFine;
uint16_t DutyFine;
uint16_t status;
uint16_t CMPA_reg_val;
uint16_t CMPAHR_reg_val;
uint16_t CMPB_reg_val;
uint16_t CMPBHR_reg_val;
int MEP_ScaleFactor; // Global variable used by the SFO library
                     // Result can be used for all HRPWM channels
                     // This variable is also copied to HRMSTEP
                     // register by SFO() function.
// Used by SFO library (ePWM[0] is a dummy value that isn't used)
volatile struct EPWM_REGS *ePWM[PWM_CH] = {&EPwm1Regs, &EPwm1Regs};
// Function Prototypes
void initHRPWM1GPIO(void);
void configHRPWM(uint16_t period);
void error(void);
// Main
void main(void)
    uint16_t i;
    uint32_t temp, temp1;
    // Initialize device clock and peripherals
    InitSysCtrl();
    // Initialize GPIO
    InitGpio();
    initHRPWM1GPIO();
    // Initialize PIE and clear PIE registers. Disables CPU interrupts.
    DINT;
    InitPieCtrl();
    IER = 0x0000;
    IFR = 0x0000;
    // Initialize the PIE vector table with pointers to the shell Interrupt
    // Service Routines (ISR).
    InitPieVectTable();
    // Setup example variables
    UpdateFine = 1;
    DutyFine = 0;
    status = SFO_INCOMPLETE;
    // Enable Global Interrupt (INTM) and realtime interrupt (DBGM)
    EINT;
    ERTM;
    // ePWM and HRPWM register initialization
    for(i=1; i<PWM_CH; i++)
        // Change clock divider to /1
        // (PWM clock needs to be > 60MHz)
        (*ePWM[i]).TBCTL.bit.HSPCLKDIV = 0;
////    configHRPWM(10);
    configHRPWM(210);
    // Calling SFO() updates the HRMSTEP register with calibrated
    // MEP_ScaleFactor. HRMSTEP must be populated with a scale factor value
    // prior to enabling high resolution period control.
    while(status == SFO_INCOMPLETE)
        status = SFO();
        if(status == SFO_ERROR)
            error();   // SFO function returns 2 if an error occurs & # of MEP
        }              // steps/coarse step exceeds maximum of 255.
    EALLOW;
    for(;;)
        // Sweep DutyFine as a Q15 number from 0.2 - 0.999
////        for(DutyFine = 0x199A; DutyFine < 0x7FDF; DutyFine++)
        DutyFine=0x1D71;
            if(UpdateFine)
                // all below calculation apply for CMPB as well
                // CMPA_reg_val , CMPA_reg_val is calculated as a Q0.
                // Since DutyFine is a Q15 number, and the period is Q0
                // the product is Q15. So to store as a Q0, we shift right
                // 15 bits.
                CMPA_reg_val = ((long)DutyFine * (EPwm1Regs.TBPRD + 1)) >> 15;
                // This next step is to obtain the remainder which was
                // truncated during our 15 bit shift above.
                // compute the whole value, and then subtract CMPA_reg_val
                // shifted LEFT 15 bits:
                temp = ((long)DutyFine * (EPwm1Regs.TBPRD + 1)) ;
                temp = temp - ((long)CMPA_reg_val<<15);
                // If auto-conversion is disabled, the following step can be
                // skipped. If autoconversion is enabled, the SFO function will
                // write the MEP_ScaleFactor to the HRMSTEP register and the
                // hardware will automatically scale the remainder in the
                // CMPAHR register by the MEP_ScaleFactor.
                // Because the remainder calculated above (temp) is in Q15
                // format, it must be shifted left by 1 to convert to Q16
                // format for the hardware to properly convert.
                CMPAHR_reg_val = temp<<1;
                // If auto-conversion is enabled, the following step is
                // performed automatically in hardware and can be skipped
                // This obtains the MEP count in digits, from
                // 0,1, .... MEP_Scalefactor.
                // 0x0080 (0.5 in Q8) is converted to 0.5 in Q15 by shifting
                // left 7. This is added to fractional duty*MEP_SF product in
                // order to round the decimal portion of the product up to the
                // next integer if the decimal portion is >=0.5.
                //Once again since this is Q15
                // convert to Q0 by shifting:
                CMPAHR_reg_val = (temp*MEP_ScaleFactor+(0x0080<<7))>>15;
                // Now the lower 8 bits contain the MEP count.
                // Since the MEP count needs to be in the upper 8 bits of
                // the 16 bit CMPAHR register, shift left by 8.
                CMPAHR_reg_val = CMPAHR_reg_val << 8;
                // Add the offset and rounding
                CMPAHR_reg_val += 0x0080;
                // Write the values to the registers as one 32-bit
                // or two 16-bits
                EPwm1Regs.CMPA.bit.CMPA = CMPA_reg_val;
                EPwm1Regs.CMPA.bit.CMPAHR = CMPAHR_reg_val;
                // All the above operations may be condensed into
                // the following form:
                // EPWM1 calculations
                    CMPA_reg_val = ((long)DutyFine * ((*ePWM[i]).TBPRD + 1)) >> 15;
                    CMPB_reg_val = ((long)DutyFine * ((*ePWM[i]).TBPRD + 1)) >> 15;
                    temp = ((long)DutyFine * ((*ePWM[i]).TBPRD + 1)) ;
                    temp1 = ((long)DutyFine * ((*ePWM[i]).TBPRD + 1)) ;
                    temp = temp - ((long)CMPA_reg_val << 15);
                    temp1 = temp1 - ((long)CMPB_reg_val << 15);
                   #if(AUTOCONVERT)
                    CMPAHR_reg_val = temp << 1; // convert to Q16
                    CMPBHR_reg_val = temp << 1; // convert to Q16
                   #else
                    CMPAHR_reg_val = ((temp * MEP_ScaleFactor) +
                                      (0x0080 << 7)) >> 15;
                    CMPBHR_reg_val = ((temp1 * MEP_ScaleFactor) +
                    CMPBHR_reg_val = CMPBHR_reg_val << 8;
                   #endif
                   // Example for a 32 bit write to CMPA:CMPAHR
                    (*ePWM[i]).CMPA.all = ((long)CMPA_reg_val) << 16 |
                                          CMPAHR_reg_val; // loses lower 8-bits
                   // Example for a 32 bit write to CMPB:CMPBHR
                    (*ePWM[i]).CMPB.all = ((long)CMPB_reg_val) << 16 |
                                          CMPBHR_reg_val; // loses lower 8-bits
                    (*ePWM[i]).TBPRDHR = 0x8000; //In Q16 format
            else
                // CMPA_reg_val is calculated as a Q0.
                // 15 bits.
                    (*ePWM[i]).CMPA.bit.CMPA = (((long)DutyFine *
                                                ((*ePWM[i]).TBPRD + 1)) >> 15);
                    (*ePWM[i]).CMPB.bit.CMPB = (((long)DutyFine *
            // Call the scale factor optimizer lib function SFO()
            // periodically to track for any change due to temp/voltage.
            // This function generates MEP_ScaleFactor by running the
            // MEP calibration module in the HRPWM logic. This scale
            // factor can be used for all HRPWM channels. The SFO()
            // function also updates the HRMSTEP register with the
            // scale factor value.
            status = SFO(); // in background, MEP calibration module
                            // continuously updates MEP_ScaleFactor
            if (status == SFO_ERROR)
                           // of MEP steps/coarse step exceeds maximum of 255.
////        } // end DutyFine for loop
    } // end infinite for loop
// configHRPWM - Configures all ePWM channels and sets up HRPWM
//                on ePWMxA / ePWMxB  channels
    uint16_t j=1;
    EALLOW;
    CpuSysRegs.PCLKCR0.bit.HRPWM = 1;
    CpuSysRegs.PCLKCR0.bit.TBCLKSYNC = 0;   // Disable TBCLK within the EPWM
    for (j=1;j<PWM_CH;j++)
        (*ePWM[j]).TBCTL.bit.PRDLD = TB_SHADOW;  // set Immediate load
        (*ePWM[j]).TBPRD = period-1;             // PWM frequency = 1 / period
        (*ePWM[j]).CMPA.bit.CMPA = period / 2;   // set duty 50% initially
        (*ePWM[j]).CMPA.bit.CMPAHR = (1 << 8);   // initialize HRPWM extension
        (*ePWM[j]).CMPB.bit.CMPB = period / 2;   // set duty 50% initially
        (*ePWM[j]).CMPB.bit.CMPBHR = (1 << 8);   // initialize HRPWM extension
        (*ePWM[j]).CMPB.all |= (1 << 8);         // initialize HRPWM extension
        (*ePWM[j]).TBPHS.all = 0;
        (*ePWM[j]).TBCTR = 0;
        (*ePWM[j]).TBCTL.bit.CTRMODE = TB_COUNT_UP;
        (*ePWM[j]).TBCTL.bit.SYNCOSEL = TB_SYNC_DISABLE;
        (*ePWM[j]).TBCTL.bit.HSPCLKDIV = TB_DIV1;
        (*ePWM[j]).TBCTL.bit.CLKDIV = TB_DIV1;
        (*ePWM[j]).TBCTL.bit.FREE_SOFT = 11;
        (*ePWM[j]).CMPCTL.bit.LOADAMODE = CC_CTR_PRD;
        (*ePWM[j]).CMPCTL.bit.LOADBMODE = CC_CTR_PRD;
        (*ePWM[j]).CMPCTL.bit.SHDWAMODE = CC_SHADOW;
        (*ePWM[j]).CMPCTL.bit.SHDWBMODE = CC_SHADOW;
        (*ePWM[j]).AQCTLA.bit.ZRO = AQ_SET;      // PWM toggle high/low
        (*ePWM[j]).AQCTLA.bit.CAU = AQ_CLEAR;
        (*ePWM[j]).AQCTLB.bit.ZRO = AQ_SET;
        (*ePWM[j]).AQCTLB.bit.CBU = AQ_CLEAR;
        (*ePWM[j]).HRCNFG.all = 0x0;
        (*ePWM[j]).HRCNFG.bit.EDGMODE = HR_BEP;  // MEP control on falling edge
        (*ePWM[j]).HRCNFG.bit.CTLMODE = HR_CMP;
        (*ePWM[j]).HRCNFG.bit.HRLOAD  = HR_CTR_ZERO_PRD;
        (*ePWM[j]).HRCNFG.bit.EDGMODEB = HR_BEP; // MEP control on falling edge
        (*ePWM[j]).HRCNFG.bit.CTLMODEB = HR_CMP;
        (*ePWM[j]).HRCNFG.bit.HRLOADB  = HR_CTR_ZERO_PRD;
        #if (AUTOCONVERT)
        (*ePWM[j]).HRCNFG.bit.AUTOCONV = 1;     // Enable auto-conversion
                                                // logic
        #endif
        (*ePWM[j]).HRPCTL.bit.TBPHSHRLOADE = 1;
        (*ePWM[j]).TBCTL.bit.PHSEN = 1;
        (*ePWM[j]).HRPCTL.bit.HRPE = 1; // Turn on high-resolution period
                                        // control.
//        (*ePWM[j]).HRMSTEP.bit.HRMSTEP = 55;
        CpuSysRegs.PCLKCR0.bit.TBCLKSYNC = 1;      // Enable TBCLK within
                                                 // the EPWM
        (*ePWM[j]).TBCTL.bit.SWFSYNC = 1;          // Synchronize high
    EDIS;
// initHRPWM1GPIO - Initialize HRPWM1 GPIOs
    EALLOW;
    // Disable internal pull-up for the selected output pins
    // for reduced power consumption
    // Pull-ups can be enabled or disabled by the user.
    GpioCtrlRegs.GPAPUD.bit.GPIO0 = 1;    // Disable pull-up on GPIO0 (EPWM1A)
    GpioCtrlRegs.GPAPUD.bit.GPIO1 = 1;    // Disable pull-up on GPIO1 (EPWM1B)
    // Configure EPWM-1 pins using GPIO regs
    // This specifies which of the possible GPIO pins will be EPWM1 functional
    // pins.
    GpioCtrlRegs.GPAMUX1.bit.GPIO0 = 1;   // Configure GPIO0 as EPWM1A
    GpioCtrlRegs.GPAMUX1.bit.GPIO1 = 1;   // Configure GPIO1 as EPWM1B
    EDIS;
// error - Halt debugger when called
void error(void)
    ESTOP0;         // Stop here and handle error
// End of file
  • Michael, please let me know if you got the response above, I sent it over last night but it seems like it never went through.
    Nima
  • Now to clarify some points,
    When using High resolution period and high resolution duty, use the same settings as the examples above, BUT since you want to use UP-COUNT only make sure your SHADOW to ACTIVE load modes for all HR and non HR registers to be CTR=ZERO.
    For the MEP, make sure to control the edge you need and not both edges.
  • Hi Nima,
    something weird is going on with attachments, I can't access any ("file does not exist"). Could you please email me internally to save time?
    thanks
    Michael
  • Emailed them to you!
    Nima
  • Michael,
    I am working on a UP-COUNT, High resolution period and duty control example for you.
    Tomorrow I will test it on my oscope and report back if the example is finalized and works.
    Nima
  • Michael,
    I have the following so far for the HRPE (High resolution period and high resolution duty control.
    // Included Files
    #include "driverlib.h"
    #include "device.h"
    #include "board.h"
    #include "SFO_V8.h"
    // Defines
    #define LAST_EPWM_INDEX_FOR_EXAMPLE    5
    // Globals
    float32_t dutyFine = 50.786f; //PERCENT
    float32_t periodFine = 100.567f;
    uint16_t status;
    volatile uint32_t ePWM[] =
        {0, myEPWM1_BASE, myEPWM2_BASE, myEPWM3_BASE, myEPWM4_BASE};
    void initHRPWM(float32_t duty, float32_t period);
    void error(void);
    //__interrupt void epwm1ISR(void);
    //__interrupt void epwm2ISR(void);
    //__interrupt void epwm3ISR(void);
    //__interrupt void epwm4ISR(void);
    // Main
    void main(void)
        uint16_t i = 0;
        Device_init();
        // Disable pin locks and enable internal pull ups.
        Device_initGPIO();
        Interrupt_initModule();
        Interrupt_initVectorTable();
        // Assign the interrupt service routines to ePWM interrupts
        //Interrupt_register(INT_EPWM1, &epwm1ISR);
        //Interrupt_register(INT_EPWM2, &epwm2ISR);
        //Interrupt_register(INT_EPWM3, &epwm3ISR);
        //Interrupt_register(INT_EPWM4, &epwm4ISR);
        // Initialize the EPWM GPIO Pins and change the XBAR inputs from using GPIO0
        Board_init();
        // Calling SFO() updates the HRMSTEP register with calibrated MEP_ScaleFactor.
        // HRMSTEP must be populated with a scale factor value prior to enabling
        // high resolution period control.
            status = SFO();
        // Disable sync(Freeze clock to PWM as well)
        SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_TBCLKSYNC);
        initHRPWM(dutyFine, periodFine);
        // Enable sync and clock to PWM
        SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_TBCLKSYNC);
        // Enable ePWM interrupts
        //Interrupt_enable(INT_EPWM1);
        //Interrupt_enable(INT_EPWM2);
        //Interrupt_enable(INT_EPWM3);
        //Interrupt_enable(INT_EPWM4);
        EINT;
        ERTM;
        for(;;)
             DEVICE_DELAY_US(1000);
             for(i=1; i<LAST_EPWM_INDEX_FOR_EXAMPLE; i++)
                 float32_t count = (dutyFine * (float32_t)(periodFine * 256))/100;
                 uint32_t compCount = (count);
                 HRPWM_setCounterCompareValue(ePWM[i], HRPWM_COUNTER_COMPARE_A, compCount);
                 HRPWM_setCounterCompareValue(ePWM[i], HRPWM_COUNTER_COMPARE_B, compCount);
                 uint32_t periodCount = (uint32_t)((periodFine - 1) * 256);
                 HRPWM_setTimeBasePeriod(ePWM[i], periodCount);
             }              // exceeds maximum of 255.
    // epwm1ISR - ePWM 1 ISR
    //    EPWM_clearEventTriggerInterruptFlag(EPWM1_BASE);
    //    Interrupt_clearACKGroup(INTERRUPT_ACK_GROUP3);
    // epwm2ISR - ePWM 2 ISR
    //    EPWM_clearEventTriggerInterruptFlag(EPWM2_BASE);
    // epwm3ISR - ePWM 3 ISR
    //    EPWM_clearEventTriggerInterruptFlag(EPWM3_BASE);
    // epwm4ISR - ePWM 4 ISR
    //    EPWM_clearEventTriggerInterruptFlag(EPWM4_BASE);
        uint16_t j;
        uint32_t periodCount;
        uint32_t compCount;
        float32_t count;
        // ePWM channel register configuration with HRPWM
        // ePWMxA / ePWMxB toggle low/high with MEP control on Rising edge
        for (j=1;j<LAST_EPWM_INDEX_FOR_EXAMPLE;j++)
            EPWM_setEmulationMode(ePWM[j], EPWM_EMULATION_FREE_RUN);
            // Set-up TBCLK
            EPWM_setPhaseShift(ePWM[j], 0U);
            EPWM_setTimeBaseCounter(ePWM[j], 0U);
            periodCount = (uint32_t)((period - 1) * 256);
            HRPWM_setTimeBasePeriod(ePWM[j], periodCount);
            count = (duty * (float32_t)(period * 256))/100;
            HRPWM_setCounterCompareValue(ePWM[j], HRPWM_COUNTER_COMPARE_A, compCount);
            HRPWM_setCounterCompareValue(ePWM[j], HRPWM_COUNTER_COMPARE_B, compCount);
            // Set up counter mode
            EPWM_setTimeBaseCounterMode(ePWM[j], EPWM_COUNTER_MODE_UP);
            EPWM_disablePhaseShiftLoad(ePWM[j]);
            EPWM_setClockPrescaler(ePWM[j],
                                   EPWM_CLOCK_DIVIDER_1,
                                   EPWM_HSCLOCK_DIVIDER_1);
            EPWM_setSyncOutPulseMode(ePWM[j], EPWM_SYNC_OUT_PULSE_DISABLED);
            // Set up shadowing
            EPWM_setCounterCompareShadowLoadMode(ePWM[j],
                                                 EPWM_COUNTER_COMPARE_A,
                                                 EPWM_COMP_LOAD_ON_CNTR_PERIOD);
                                                 EPWM_COUNTER_COMPARE_B,
            // Set actions
            EPWM_setActionQualifierAction(ePWM[j],
                                          EPWM_AQ_OUTPUT_A,
                                          EPWM_AQ_OUTPUT_HIGH,
                                          EPWM_AQ_OUTPUT_ON_TIMEBASE_ZERO);
                                          EPWM_AQ_OUTPUT_B,
                                          EPWM_AQ_OUTPUT_A,
                                          EPWM_AQ_OUTPUT_LOW,
                                          EPWM_AQ_OUTPUT_ON_TIMEBASE_UP_CMPA);
                                          EPWM_AQ_OUTPUT_B,
                                          EPWM_AQ_OUTPUT_LOW,
                                          EPWM_AQ_OUTPUT_ON_TIMEBASE_UP_CMPB);
            HRPWM_setMEPEdgeSelect(ePWM[j], HRPWM_CHANNEL_A, HRPWM_MEP_CTRL_FALLING_EDGE);
            HRPWM_setMEPControlMode(ePWM[j], HRPWM_CHANNEL_A, HRPWM_MEP_DUTY_PERIOD_CTRL);
            HRPWM_setCounterCompareShadowLoadEvent(ePWM[j], HRPWM_CHANNEL_A, HRPWM_LOAD_ON_CNTR_ZERO_PERIOD);
            HRPWM_setMEPEdgeSelect(ePWM[j], HRPWM_CHANNEL_B, HRPWM_MEP_CTRL_FALLING_EDGE);
            HRPWM_setMEPControlMode(ePWM[j], HRPWM_CHANNEL_B, HRPWM_MEP_DUTY_PERIOD_CTRL);
            HRPWM_setCounterCompareShadowLoadEvent(ePWM[j], HRPWM_CHANNEL_B, HRPWM_LOAD_ON_CNTR_ZERO_PERIOD);
            HRPWM_enableAutoConversion(ePWM[j]);
            HRPWM_enablePeriodControl(ePWM[j]);
            // Turn on high-resolution period control.
            HRPWM_disablePhaseShiftLoad(ePWM[j]);
            // Interrupt where we will change the Compare Values
            // Select INT on Time base counter zero event,
            // Enable INT, generate INT on 1st event
            //EPWM_setInterruptSource(ePWM[j], EPWM_INT_TBCTR_ZERO);
            //EPWM_enableInterrupt(ePWM[j]);
            //EPWM_setInterruptEventCount(ePWM[j], 1U);
    void error (void)
    https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/171/hrpwm_5F00_ex5_5F00_duty_5F00_and_5F00_prd_5F00_upcount_5F00_sfo.syscfg
    // Included Files
    #include "device.h"
    #include "board.h"
    #include "SFO_V8.h"
    // Defines
    // Globals
    uint16_t status;
    void error(void);
    // Main
    void main(void)
        uint16_t i = 0;
        Device_init();
        Device_initGPIO();
        Board_init();
            status = SFO();
        EINT;
        ERTM;
        for(;;)
        uint16_t j;
        uint32_t compCount;
        float32_t count;
            // Set-up TBCLK
            // Set up shadowing
            // Set actions
                                          EPWM_AQ_OUTPUT_A,
                                          EPWM_AQ_OUTPUT_B,
                                          EPWM_AQ_OUTPUT_A,
                                          EPWM_AQ_OUTPUT_LOW,
                                          EPWM_AQ_OUTPUT_B,
                                          EPWM_AQ_OUTPUT_LOW,
    void error (void)
    Nima
  • Hi Nima,
    with this code I observe the output frequency jumping between 990Khz and 1Mhz. Is this what you see too?
    thanks
    Michael
  • I will create an internal thread and loop you in for the jitter which I also do see on my scope when I tested today.
  • Michael,
    Will await the respnose from the team to complete this.
    Nima
  • Updated HRPWM settings code to remove the jitter discussed:
        uint16_t j;
        uint32_t compCount;
        float32_t count;
            // Set-up TBCLK
            // Set up shadowing
            // MUST LOAD ON CTR=PRD
            // Set actions
            // MUST SET HIGH ON PERIOD and NOT ZERO
                                          EPWM_AQ_OUTPUT_A,
                                          EPWM_AQ_OUTPUT_ON_TIMEBASE_PERIOD);
                                          EPWM_AQ_OUTPUT_B,
                                          EPWM_AQ_OUTPUT_A,
                                          EPWM_AQ_OUTPUT_LOW,
                                          EPWM_AQ_OUTPUT_B,
                                          EPWM_AQ_OUTPUT_LOW,
            // MUST BE USING BOTH EDGES
            HRPWM_setMEPEdgeSelect(ePWM[j], HRPWM_CHANNEL_A, HRPWM_MEP_CTRL_RISING_AND_FALLING_EDGE);
            HRPWM_setMEPEdgeSelect(ePWM[j], HRPWM_CHANNEL_B, HRPWM_MEP_CTRL_RISING_AND_FALLING_EDGE);
  • Michael,
    Shall we close this for now?
    If new issues come up we can open a new thread.
    Nima
