TMS320F28075: High Resolution Period with Deadband on up-count mode
Genius 16855 points
Part Number: TMS320F28075
Can the latest HRPWM like F2807x generate complementary high resolution PFM with deadband on up-count mode?
I tested it few years ago, but I don't remember the conclusion well. Then I want to confirm again.
Oba
  • Hi Oba,
    Yes, it is able to do that. For more information you can see the section titled "High-Resolution Period Configuration" in the device TRM. Deadband is also compatible with this mode.
    Kris
    www.ti.com/.../spruhm9d.pdf
  • Hello Kris,
    Have you tested it?
    As far as I tested, it is possible for up-down count. But it can't for up-count.
    Do you have any sample code?
    Oba
  • Hi Oba,
    I do not have any example code for this. Which portion of the implementation seems to not be working? Do you have any waveforms you can share?
    Kris
  • Hi Oba,
    Since we have not heard back we hope that means your problem has been resolved. We are going to close this thread. Please feel free to open a new thread if the issue is still ongoing.
    Kris
  • Hello Kris,
    I'm sorry that I couln't reply after that.
    This problem has not been solved yet, but unfortunately, because I'm very busy for other task now, I can't take a time to this issue.
    So I agree to close once. I may open again later.
    Thanks for your help.
    Satoshi Obata
