Other Parts Discussed in Thread: TMS320F28035
Hi all,
I am using the EPwm1 in TMS320F28035 micro-controller in a power supply project. I have connected a push button at one of the GPIO port for starting and stoping the PWM pulses.
I am facing following problems in this
Question 1
When I start the PWM a wide pulse comes first on EPWM1A channel and then starts the normal PWM pulses. The width of this pulse varies each time I starts.
My question is, is there any standard way to start and stop pwm pulses. What I am doing wrong. Please refer my code given below
// To STOP the PWM
EPwm1Regs.AQSFRC.bit.RLDCSF = 3;
EPwm1Regs.AQSFRC.bit.ACTSFA = 1;
EPwm1Regs.AQSFRC.bit.ACTSFB = 1;
EPwm1Regs.AQSFRC.bit.OTSFA = 1;
EPwm1Regs.AQSFRC.bit.OTSFB = 1;
EPwm1Regs.AQCSFRC.bit.CSFA = 1;
EPwm1Regs.AQCSFRC.bit.CSFB = 1;
EPwm1Regs.DBCTL.bit.OUT_MODE = 0;
// To START the PWM
EPwm1Regs.AQSFRC.bit.RLDCSF = 0;
EPwm1Regs.AQSFRC.bit.ACTSFA = 0;
EPwm1Regs.AQSFRC.bit.ACTSFB = 0;
EPwm1Regs.AQSFRC.bit.OTSFA = 0;
EPwm1Regs.AQSFRC.bit.OTSFB = 0;
EPwm1Regs.AQCSFRC.bit.CSFA = 0;
EPwm1Regs.DBCTL.bit.OUT_MODE = 3;
Question 2
I have configured the trip zone for over current protection. The over current tripping is working OK. But once it is tripped we are not able to start the pulse again by pressing the start button.
To restart the PWM pulse I have to do power ON/OFF of the development kit.
Please refer my Initialization Code given below and start code shown above. Please give your suggestions.
Thanks and regards
Ittoop
//------------------------------------------------------Start--------------------------------------------------------------------------
// EPM configuration
EPwm1Regs.TBCTL.bit.CTRMODE = TB_FREEZE; // disable counter
EPwm1Regs.TBCTR = 0x0000; // Clear timer counter
EPwm1Regs.TBPRD = FREQ_MAX_COUNT; // Period = Start from max frequency
EPwm1Regs.CMPA.half.CMPA = FREQ_MAX_COUNT/2;
EPwm1Regs.AQCTLA.bit.ZRO = AQ_TOGGLE; //AQ_TOGGLE;
// Dead band configuration
EPwm1Regs.DBCTL.bit.IN_MODE = DBA_ALL; // EPWMxA is the source for both delays
EPwm1Regs.DBCTL.bit.OUT_MODE =DB_FULL_ENABLE; //DB_DISABLE;// Enable Deadband module
EPwm1Regs.DBCTL.bit.POLSEL = DB_ACTV_HIC; // Active High Complementary (AHC)
EPwm1Regs.DBRED = 150; //2.5uS dead time
EPwm1Regs.DBFED = 150;
// Trip zone configuration
EPwm1Regs.TZCLR.all=0; // clear previous trips
EPwm1Regs.TZCLR.bit.OST=1;
EPwm1Regs.TZSEL.bit.OSHT1 = 1; // one-shot source
EPwm1Regs.TZCTL.bit.TZA = TZ_FORCE_LO; // set EPWM1A to low at fault
EPwm1Regs.TZCTL.bit.TZB = TZ_FORCE_LO; // set EPWM1B to low at fault
EPwm1Regs.TBCTL.bit.CTRMODE = TB_COUNT_UP;
//--------------------------------------------------------End--------------------------------------------------------------------------
