Part Number: MSP430F248
Hello I work for Honeywell just receive 19 IC pcs reporter as defective from customer Defect parts turn on then turn off after 5 minutes.
Part MSP430F2418T
1) 19 pcs tested and confirmed to be defective turn on and after 5 minutes the unit turn off.
2) Reviewed voltages before and after IC with PN: 50027048-001 are present, when unit turn off after 5 minutes, voltages before IC are present but from IC to Display are not present any more.
3) 3 pcs reviewed on Xray, if there’s is any solder ball or solder short and no issues found.
4) 3 pcs preformed reflowing the IC in order to verify if there is any cold solder and after reflowing still the same issue turn on and off so no cold solder found.
5) 3 pcs reprogramed in FFT to verify if program of IC was corrupted, and problem persist.
6) IC replaced and reprogramed and FFT pass, and problem is not present any more.
Please find below 2 of the 19 parts.
