Other Parts Discussed in Thread: TIDM-1021
Hello there!
We have an application requiring liquid toletant buttons, and after doing some research we came across your TIDM-1021.
Following you design guidelines for TIDM-1021, we started developing a one button prototype using the mutual mode (with a hatched TX sensor on the TOP layer with an RX electrode, hatched GND on 2on and 3rd layer, and solid GND on BOT layer).
Also, this button will be on vertical position, and have a LED on the BOT layer.
That’s what we got:
Right now, we achieve good sensitivity with the button, but we cannot obtain the same results shown on the video (https://www.youtube.com/watch?v=_hWXgGZijec). At first, water stream decreases delta and activates the negative touch flag, but after that, the water increases increase delta count, and activates our TOUCH.
Doing some more research I came across to this other post (https://e2e.ti.com/support/microcontrollers/msp-low-power-microcontrollers-group/msp430/f/msp-low-power-microcontroller-forum/935359/boostxl-capkeypad-waterproof-capacitive-touch-sensor-does-not-work-as-expected)
Should we evade GND on 2nd an 3rd layer to avoid GND coupling? or there is something else that we are missing out?
Also, its better approach to create a guard button (as you explained on the previous post) to protect the button from water (see image)?
Thank you for any help about this issue
Best regards
