Part Number: MSP430F5438A
Hi team,
Here's a question from the customer may need your help:
Regarding RTC, if do not calibrate the week, will it affect the time? Could you help resolve this case? Thanks.
Cherry
Hi team,
Cherry
Hello.
Thanks for your support first!
What do you mean be "calibrate the week"?
They only want the data of year/month/day/ and the clock data(exact time, minute and second), skip setting the week when setting and initializing time, will it affect the normal calendar display?
Thanks and regards,
Cherry
Hi Cherry,
Suggest to initial the week register although customer don't use the week information because that is make sure that after the initialization the value of the RTC register is within the specified range. Writing of invalid date or time information or data values outside the legal ranges specified in the RTCSEC, RTCMIN, RTCHOUR, RTCDAY, RTCDOW, RTCYEARH, RTCYEARL, RTCAMIN, RTCAHOUR, RTCADAY, and RTCADOW registers can result in unpredictable behavior.
Hi Allen,
That is, when the initialization week data is within the register range, it will be ok, right? And it won't affect the actual display of week and clock?
Thanks and regards,
Cherry
Hi cherry,
The week is based on your configuration. Day add one and the week will add one(from your initialization) cycle and cycle. You customer don't need week information they don't need to care the week is correct or not. Just give a initialization to make it start in a correct range.
