MSP430FR2676: msp430fr2676 hardware I2C receiving data error
Part Number: MSP430FR2676
Other Parts Discussed in Thread: LP5562
msp430fr2676 hardware I2C first execution receive one extra byte of data.
MCLK 16M , SMCLK 16M, I2C RATE 400K,  Slave device lp5562 , IDE CCS10
first
Other
i2c.h
//! ucb1_i2c.h - \b EUSCI_B1_I2C驱动程序头文件
//! @author  CVZTS
//! @date    2022-01-27
//! @version V100R001SP0001
#ifndef __DRIVER_UCB1_I2C_H__
#define __DRIVER_UCB1_I2C_H__
#ifdef __cplusplus
extern "C" {
#endif
 *  =============================== 返回码定义 =================================
#define UCB1_I2C_SUCCESS        (0)     // 执行成功
#define UCB1_I2C_ERROR_BUSY     (-1)    // 数据总线忙
#define UCB1_I2C_ERROR_NAK      (-2)    // 设备未应答
 *  ================================ 全局定义 ==================================
#define UCB1_I2C_CS_SMCLK       (0)    // I2C模块时钟源SMCLK
#define UCB1_I2C_CS_ACLK        (1)    // I2C模块时钟源ACLK
#define UCB1_I2C_RATE_100K      (0)    // I2C接口速率100KBps
#define UCB1_I2C_RATE_400K      (1)    // I2C接口速率400KBps
 *  ================================== API ====================================
//! \brief 初始化UCB1_I2C接口
//! \param[in] clkSrc  I2C模块时钟源
//!                    - \b UCB1_I2C_CS_SMCLK
//!                    - \b UCB1_I2C_CS_ACLK
//! \param[in] clock   I2C模块时钟源频率(Hz)
//! \param[in] rate    I2C接口速率
//!                    - \b UCB1_I2C_RATE_100K
//!                    - \b UCB1_I2C_RATE_400K
//! \return none
//! \note   none
extern void drv_InitUCB1I2C(uint8_t clkSrc, uint32_t clock, uint8_t rate);
//! \brief 设置设备地址
//! \param[in] addr 设备地址
//! \return none
//! \note   none
extern void drv_UCB1I2CSetSlaveAddress(uint8_t addr);
//! \brief 获取设备地址
//! \param none
//! \return 设备地址
//! \note   none
extern uint8_t drv_UCB1I2CGetSlaveAddress(void);
//! \brief 设置I2C最大错误重试次数
//! \param[in] retNum  最大重试次数(0-255)
//! \return none
//! \note   none
extern void drv_UCB1I2CSetRetriesNumber(uint8_t retNum);
//! \brief 获取I2C最大错误重试次数
//! \param none
//! \return 最大错误重试次数
//! \note   none
extern uint8_t drv_UCB1I2CGetRetriesNumber(void);
//! \brief I2C读取多字节数据
//! \param[in] regAddr  起始寄存器地址
//! \param[in] dataPtr  保存已读取数据的指针
//! \param[in] size     读取数据多大小
//! \return 如果成功返回  \b UCB1_I2C_SUCCESS
//!         否则返回      \b UCB1_I2C_ERROR_BUSY or \b UCB1_I2C_ERROR_NAK
//! \note   none
extern int16_t drv_UCB1I2CReadMultiByte(uint8_t regAddr, uint8_t *dataPtr, uint16_t size);
#ifdef __cplusplus
#endif
#endif // __DRIVER_UCB1_I2C_H__
i2c.c
//! ucb1_i2c.c - \b EUSCI_B1_I2C驱动程序源文件
//! @author  CVZTS
//! @date    2022-02-05
 *  =============================== 头文件引入 =================================
#include "board.h"
#include "ucb1_i2c.h"
#include "uartprint/uartprint.h"
#define I2C_RETRIES_MAX     (3)     // 最大重试次数
 *  ================================ 数据结构 ==================================
// UCB1_I2C 信息存储块数据结构
typedef struct t_UCB1I2CBlock
    uint8_t retriesNumber;    // 最大重试次数
} UCB1I2CBlock;
 *  ================================ 全局变量 ==================================
// UCB1_I2C模块时钟源列表
static uint8_t g_clockSourceList[2] =
    [UCB1_I2C_CS_SMCLK] = EUSCI_B_I2C_CLOCKSOURCE_SMCLK,
    [UCB1_I2C_CS_ACLK]  = EUSCI_B_I2C_CLOCKSOURCE_ACLK
// UCB1_I2C接口速率列表
static uint32_t g_rateList[2] =
    [UCB1_I2C_RATE_100K] = EUSCI_B_I2C_SET_DATA_RATE_100KBPS,
    [UCB1_I2C_RATE_400K] = EUSCI_B_I2C_SET_DATA_RATE_400KBPS
// UCB1_I2C 信息存储块
static UCB1I2CBlock g_block = {0};
 *  ================================ 内部函数 ==================================
//! \return none
//! \note   none
    // 设置I2C错误最大重试次数
    g_block.retriesNumber = I2C_RETRIES_MAX;
    // EUSCIA重新映射源选择
    SYSCFG3 |= USCIB1RMP;
    // EUSCI_B1_I2C 初始化
    EUSCI_B_I2C_initMasterParam _param = {0};
    _param.selectClockSource    = g_clockSourceList[clkSrc];
    _param.i2cClk               = clock;
    _param.dataRate             = g_rateList[rate];
    _param.byteCounterThreshold = 0;
    _param.autoSTOPGeneration   = EUSCI_B_I2C_NO_AUTO_STOP;
    MAP_EUSCI_B_I2C_initMaster(EUSCI_B1_BASE, &_param);
    // 设置I2C为传输模式
    MAP_EUSCI_B_I2C_setMode(EUSCI_B1_BASE, EUSCI_B_I2C_TRANSMIT_MODE);
    // 启用I2C模块
    EUSCI_B_I2C_enable(EUSCI_B1_BASE);
    // 清除I2C中断标志
    MAP_EUSCI_B_I2C_clearInterrupt(EUSCI_B1_BASE,
                                   EUSCI_B_I2C_NAK_INTERRUPT +
                                   EUSCI_B_I2C_TRANSMIT_INTERRUPT0 +
                                   EUSCI_B_I2C_RECEIVE_INTERRUPT0);
//! \brief 设置设备地址
//! \return none
//! \note   none
    EUSCI_B_I2C_setSlaveAddress(EUSCI_B1_BASE, addr);
//! \brief 获取设备地址
//! \param none
//! \return 设备地址
//! \note   none
    return (HWREG16(EUSCI_B1_BASE + OFS_UCBxI2CSA));
//! \return none
//! \note   none
    g_block.retriesNumber = retNum;
//! \param none
//! \note   none
    return (g_block.retriesNumber);
//! \note   none
    //! 等待总线空闲
    //! 如果累计重试次数等于最大错误重试次数
    //! 返回 \b UCB1_I2C_ERROR_BUSY
    uint8_t _retNum = 0;
    while(MAP_EUSCI_B_I2C_isBusBusy(EUSCI_B1_BASE))
        _retNum++;
        if (_retNum == g_block.retriesNumber)
            return (UCB1_I2C_ERROR_BUSY);
    // 设置I2C为传输模式
    // 发送写入数据开始信号
    MAP_EUSCI_B_I2C_masterSendStart(EUSCI_B1_BASE);
    // 等待开始信号
    while(EUSCI_B_I2C_SENDING_START == MAP_EUSCI_B_I2C_masterIsStartSent(EUSCI_B1_BASE));
    // 如果设备未应答
    if (MAP_EUSCI_B_I2C_getInterruptStatus(EUSCI_B1_BASE, EUSCI_B_I2C_NAK_INTERRUPT))
        // 发送停止信号
        MAP_EUSCI_B_I2C_masterSendMultiByteStop(EUSCI_B1_BASE);
        // 等待停止信号发送
        while (EUSCI_B_I2C_SENDING_STOP == MAP_EUSCI_B_I2C_masterIsStopSent(EUSCI_B1_BASE));
        // 清除中断标志
                                       EUSCI_B_I2C_RECEIVE_INTERRUPT0 +
                                       EUSCI_B_I2C_BYTE_COUNTER_INTERRUPT);
        // 返回错误代码
        return (UCB1_I2C_ERROR_NAK);
    // 发送寄存器地址
    MAP_EUSCI_B_I2C_masterSendMultiByteNext(EUSCI_B1_BASE, regAddr);
    // 清除Tx中断标志
    MAP_EUSCI_B_I2C_clearInterrupt(EUSCI_B1_BASE, EUSCI_B_I2C_TRANSMIT_INTERRUPT0);
    // 发送接收起始信号
    MAP_EUSCI_B_I2C_masterReceiveStart(EUSCI_B1_BASE);
    // 等待开始信号生成
    for (uint16_t i = 0; i < size; i++)
        // 接收数据
        dataPtr[i] = MAP_EUSCI_B_I2C_masterReceiveSingle(EUSCI_B1_BASE);
    // 发送停止信号
    MAP_EUSCI_B_I2C_masterReceiveMultiByteStop(EUSCI_B1_BASE);
    // 轮询等待停止信号发送完成
    return (UCB1_I2C_SUCCESS);
call
void main(void)
    drv_InitUCB1I2C(UCB1_I2C_CS_SMCLK, CS_getSMCLK(), UCB1_I2C_RATE_400K);
    drv_UCB1I2CSetSlaveAddress(0x30);
    uint8_t _buff[10];
    while (1)
        drv_UCB1I2CReadMultiByte(0x00, _buff, 10);
        __delay_cycles(50000);
  • Do you mean that first communication is good, the second and third are not good?
    Can you test the code in debug mode, if this part of code works right:
    // 接收数据
  • first not good,second and third is good!
  • first not good,second and third good.
  • Can you test the code in debug mode, if this part of code works right:
    // 接收数据
    Please add a breakpoint at "dataPtr[i] = MAP_EUSCI_B_I2C_masterReceiveSingle(EUSCI_B1_BASE);"
        // 计算最后一字节数据的索引
        uint16_t _lastIndex = size - 1;
        // 接收数据(不包含最后一个字节)
        for (int i = 0; i < _lastIndex; i++)
            // 轮询接收中断标志.
            while (!MAP_EUSCI_B_I2C_getInterruptStatus(EUSCI_B1_BASE, EUSCI_B_I2C_RECEIVE_INTERRUPT0));
            // 接收数据
            dataPtr[i] = MAP_EUSCI_B_I2C_masterReceiveMultiByteNext(EUSCI_B1_BASE);
        // 接收最后一个字节
        // 并且发送停止信号
        dataPtr[_lastIndex] = MAP_EUSCI_B_I2C_masterReceiveMultiByteFinish(EUSCI_B1_BASE);
    Thank you. Problem solved. After sending the stop signal . one more byte needs to be received
