Part Number: MSP430FR6047
Other Parts Discussed in Thread: EVM430-FR6043, SN74LVC2T45
Hi, I'm reading documents about MSP430FR6047 and evaluation board of that to use for blood flow metering and I faced with some questions.
First Question: Is there any configuration to change value of speed of sound in water to speed of that in blood? I couldn't find such variable in Ultrasonic Sensing Design Center (GUI).
Second problem: Where can I set the distance that sound travel in Fluid (Blood). You know to calculate velocity of flow we need to length of distance that sound travels in flow. But It seems there isn't any parameter for this purpose in GUI?! Is there any parameter in Coding Part? It is very important because the system can be used to measure a thick pipe's flow or thin one. Therefore, the time of sound travel in body of pipe will be different and this affect measurements.
Third: also cosine of piezo angle needs in formula of flow metering by Delta TOF.
fourth: In clamp on water meter for PVC pipes application report (slaa949) have been showed an experiment that piezos used in clamp on method. The output of MSP430 piezo driver has an approximately 2.5 volt pin. But we know driving piezos mostly needs higher voltages. Is there any amplifier used in this test? or the used piezos can be excited with lower voltage?
best regards
