MSP430FR2676: Use FRAM as data log memory region
Part Number: MSP430FR2676
Other Parts Discussed in Thread: MSP430WARE, , MSP430FR2476
My customer wants to store some data in FRAM during runtime.
Customer uses INFO memory region as same as example code in MSP430Ware msp430fr267x_framwrite.c.
Below is linker command file and .log is used as data storage in c code. It works fine.
lnk_msp430fr2676.cmd:
MEMORY
    TINYRAM                 : origin = 0x6, length = 0x1A
    BSL0                    : origin = 0x1000, length = 0x800
    INFO                    : origin = 0x1800, length = 0x200  // Data saved here
    TLVMEM                  : origin = 0x1A00, length = 0x200
SECTIONS
    /* MSP430 INFO memory segments */
    .log : type = NOINIT{} > INFO
Now customer needs more than 512bytes data area, so he wants to use below FRAM area for data storage.
.log and .log2 are used as data storage in c code.
MEMORY
    FRAM                    : origin = 0x8000, length = 0x7F80
	FRAM2                   : origin = 0x10000,length = 0x6000
	LOG                     : origin = 0x16000,length = 0x2000 // Additional Data log area in FRAM
SECTIONS
    .log2 : type = NOINIT{} > LOG
But above change causes warning at compile something like:
<a href="file:/C:/ti/ccs1020/ccs/tools/compiler/dmed/HTML/17003.html">#17003-D</a>  relocation from function "<function name>" to symbol "log_data" overflowed; the 17-bit relocated address 0x16018 is too large to encode in the 16-bit field (type = 'R_MSP430X_ABS16' (15), file = "./main.obj", offset = 0x00000032, section = ".text:<function name>"
Customer configures the data memory model as "Large". Why above warning is generated?
Thanks and regards,
Koichiro Tashiro
  • Hi Kohichiro
    I changed my FR2676 project lnk_msp430fr2476.cmd file accoridng to your Screenshot and description. Could you please share the lnk_msp430fr2476.cmd file with me?
    Thanks!
  • Customer configures the data memory model as "Large". Why above warning is generated?
    Changing the --near_data=globals to --near_data=none should remove the #17003-D warning about the relocation overflowing. See CCS/MSP430F5435: Data located in higher memory above FLASH2 is causing #17003-D warning is large data model for an explanation.
  • Hi Chester,
    Thanks for your input. I will ask customer to use --near_data=none option.
    Hi Xiaodong,
    Please find below customer's cmd file (.cmd is changed to .txt).
    Data storage names are .info and .info2.
        .info : type = NOINIT{} > LOG
        .info2 : type = NOINIT{} > INFO
    * Copyright (C) 2012 - 2020 Texas Instruments Incorporated - http://www.ti.com/
    * Redistribution and use in source and binary forms, with or without
    * modification, are permitted provided that the following conditions
    * are met:
    *  Redistributions of source code must retain the above copyright
    *  notice, this list of conditions and the following disclaimer.
    *  Redistributions in binary form must reproduce the above copyright
    *  notice, this list of conditions and the following disclaimer in the
    *  documentation and/or other materials provided with the
    *  distribution.
    *  Neither the name of Texas Instruments Incorporated nor the names of
    *  its contributors may be used to endorse or promote products derived
    *  from this software without specific prior written permission.
    * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
    * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
    * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
    * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
    * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
    * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
    * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
    * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
    * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
    * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
    * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    * Default linker command file for Texas Instruments MSP430FR2676
    /*   Usage:  lnk430 <obj files...>    -o <out file> -m <map file> lnk.cmd     */
    /*           cl430  <src files...> -z -o <out file> -m <map file> lnk.cmd     */
    /* These linker options are for command line linking only.  For IDE linking,  */
    /* you should set your linker options in Project Properties                   */
    /* -c                                               LINK USING C CONVENTIONS  */
    /* -stack  0x0100                                   SOFTWARE STACK SIZE       */
    /* -heap   0x0100                                   HEAP AREA SIZE            */
    /* 1.210 */
    /* SPECIFY THE SYSTEM MEMORY MAP                                            */
    MEMORY
        BOOTCODE                : origin = 0x1C00, length = 0x400
        RAM                     : origin = 0x2000, length = 0x2000
        ROMLIB                  : origin = 0xC0000, length = 0x4000
        BSL1                    : origin = 0xFFC00, length = 0x400
        JTAGSIGNATURE           : origin = 0xFF80, length = 0x0004, fill = 0xFFFF
        BSLSIGNATURE            : origin = 0xFF84, length = 0x0004, fill = 0xFFFF
        BSLCONFIGURATIONSIGNATURE: origin = 0xFF88, length = 0x0002, fill = 0xFFFF
        BSLCONFIGURATION        : origin = 0xFF8A, length = 0x0002, fill = 0xFFFF
        BSLI2CADDRESS           : origin = 0xFFA0, length = 0x0002, fill = 0xFFFF
        INT00                   : origin = 0xFFA2, length = 0x0002
        INT01                   : origin = 0xFFA4, length = 0x0002
        INT02                   : origin = 0xFFA6, length = 0x0002
        INT03                   : origin = 0xFFA8, length = 0x0002
        INT04                   : origin = 0xFFAA, length = 0x0002
        INT05                   : origin = 0xFFAC, length = 0x0002
        INT06                   : origin = 0xFFAE, length = 0x0002
        INT07                   : origin = 0xFFB0, length = 0x0002
        INT08                   : origin = 0xFFB2, length = 0x0002
        INT09                   : origin = 0xFFB4, length = 0x0002
        INT10                   : origin = 0xFFB6, length = 0x0002
        INT11                   : origin = 0xFFB8, length = 0x0002
        INT12                   : origin = 0xFFBA, length = 0x0002
        INT13                   : origin = 0xFFBC, length = 0x0002
        INT14                   : origin = 0xFFBE, length = 0x0002
        INT15                   : origin = 0xFFC0, length = 0x0002
        INT16                   : origin = 0xFFC2, length = 0x0002
        INT17                   : origin = 0xFFC4, length = 0x0002
        INT18                   : origin = 0xFFC6, length = 0x0002
        INT19                   : origin = 0xFFC8, length = 0x0002
        INT20                   : origin = 0xFFCA, length = 0x0002
        INT21                   : origin = 0xFFCC, length = 0x0002
        INT22                   : origin = 0xFFCE, length = 0x0002
        INT23                   : origin = 0xFFD0, length = 0x0002
        INT24                   : origin = 0xFFD2, length = 0x0002
        INT25                   : origin = 0xFFD4, length = 0x0002
        INT26                   : origin = 0xFFD6, length = 0x0002
        INT27                   : origin = 0xFFD8, length = 0x0002
        INT28                   : origin = 0xFFDA, length = 0x0002
        INT29                   : origin = 0xFFDC, length = 0x0002
        INT30                   : origin = 0xFFDE, length = 0x0002
        INT31                   : origin = 0xFFE0, length = 0x0002
        INT32                   : origin = 0xFFE2, length = 0x0002
        INT33                   : origin = 0xFFE4, length = 0x0002
        INT34                   : origin = 0xFFE6, length = 0x0002
        INT35                   : origin = 0xFFE8, length = 0x0002
        INT36                   : origin = 0xFFEA, length = 0x0002
        INT37                   : origin = 0xFFEC, length = 0x0002
        INT38                   : origin = 0xFFEE, length = 0x0002
        INT39                   : origin = 0xFFF0, length = 0x0002
        INT40                   : origin = 0xFFF2, length = 0x0002
        INT41                   : origin = 0xFFF4, length = 0x0002
        INT42                   : origin = 0xFFF6, length = 0x0002
        INT43                   : origin = 0xFFF8, length = 0x0002
        INT44                   : origin = 0xFFFA, length = 0x0002
        INT45                   : origin = 0xFFFC, length = 0x0002
        RESET                   : origin = 0xFFFE, length = 0x0002
    /* SPECIFY THE SECTIONS ALLOCATION INTO MEMORY                              */
    SECTIONS
        GROUP(ALL_FRAM)
            GROUP(READ_WRITE_MEMORY)
                .TI.persistent : {}              /* For #pragma persistent            */
                .cio           : {}              /* C I/O Buffer                      */
                .sysmem        : {}              /* Dynamic memory allocation area    */
            } PALIGN(0x0400), RUN_START(fram_rw_start) RUN_END(fram_rx_start)
            GROUP(READ_ONLY_MEMORY)
                .cinit      : {}                   /* Initialization tables             */
                .pinit      : {}                   /* C++ constructor tables            */
                .binit      : {}                   /* Boot-time Initialization tables   */
                .init_array : {}                   /* C++ constructor tables            */
                .mspabi.exidx : {}                 /* C++ constructor tables            */
                .mspabi.extab : {}                 /* C++ constructor tables            */
                .const      : {}                   /* Constant data                     */
            GROUP(EXECUTABLE_MEMORY)
                .text:_isr  : {}                   /* Code ISRs                         */
        } > FRAM
    #ifndef __LARGE_DATA_MODEL__
        .const            : {} > FRAM           /* Constant data                     */
    #else
        .const            : {} >> FRAM | FRAM2  /* Constant data                     */
    #endif
    #ifndef __LARGE_CODE_MODEL__
        .text             : {} > FRAM           /* Code                              */
    #else
        .text             : {} >> FRAM2 | FRAM  /* Code                              */
    #endif
        #ifdef __TI_COMPILER_VERSION__
            #if __TI_COMPILER_VERSION__ >= 15009000
                    .TI.ramfunc : {} load=FRAM, run=RAM, table(BINIT)
                #else
                    .TI.ramfunc : {} load=FRAM | FRAM2, run=RAM, table(BINIT)
                #endif
            #endif
        #endif
        .jtagsignature      : {} > JTAGSIGNATURE
        .bslsignature       : {} > BSLSIGNATURE
        .bslconfigsignature : {} > BSLCONFIGURATIONSIGNATURE
        .bslconfig          : {} > BSLCONFIGURATION
        .bsli2caddress      : {} > BSLI2CADDRESS
        .bss        : {} > RAM                  /* Global & static vars              */
        .data       : {} > RAM                  /* Global & static vars              */
        .TI.noinit  : {} > RAM                  /* For #pragma noinit                */
        .stack      : {} > RAM (HIGH)           /* Software system stack             */
        .tinyram    : {} > TINYRAM              /* Tiny RAM                          */
        /* MSP430 interrupt vectors */
        .int00       : {}               > INT00
        .int01       : {}               > INT01
        .int02       : {}               > INT02
        .int03       : {}               > INT03
        .int04       : {}               > INT04
        .int05       : {}               > INT05
        .int06       : {}               > INT06
        .int07       : {}               > INT07
        .int08       : {}               > INT08
        .int09       : {}               > INT09
        .int10       : {}               > INT10
        .int11       : {}               > INT11
        .int12       : {}               > INT12
        .int13       : {}               > INT13
        .int14       : {}               > INT14
        .int15       : {}               > INT15
        .int16       : {}               > INT16
        .int17       : {}               > INT17
        .int18       : {}               > INT18
        CAPTIVATE    : { * ( .int19 ) } > INT19 type = VECT_INIT
        ECOMP0       : { * ( .int20 ) } > INT20 type = VECT_INIT
        PORT6        : { * ( .int21 ) } > INT21 type = VECT_INIT
        PORT5        : { * ( .int22 ) } > INT22 type = VECT_INIT
        PORT4        : { * ( .int23 ) } > INT23 type = VECT_INIT
        PORT3        : { * ( .int24 ) } > INT24 type = VECT_INIT
        PORT2        : { * ( .int25 ) } > INT25 type = VECT_INIT
        PORT1        : { * ( .int26 ) } > INT26 type = VECT_INIT
        ADC          : { * ( .int27 ) } > INT27 type = VECT_INIT
        EUSCI_B1     : { * ( .int28 ) } > INT28 type = VECT_INIT
        EUSCI_B0     : { * ( .int29 ) } > INT29 type = VECT_INIT
        EUSCI_A1     : { * ( .int30 ) } > INT30 type = VECT_INIT
        EUSCI_A0     : { * ( .int31 ) } > INT31 type = VECT_INIT
        WDT          : { * ( .int32 ) } > INT32 type = VECT_INIT
        RTC          : { * ( .int33 ) } > INT33 type = VECT_INIT
        TIMER0_B1    : { * ( .int34 ) } > INT34 type = VECT_INIT
        TIMER0_B0    : { * ( .int35 ) } > INT35 type = VECT_INIT
        TIMER3_A1    : { * ( .int36 ) } > INT36 type = VECT_INIT
        TIMER3_A0    : { * ( .int37 ) } > INT37 type = VECT_INIT
        TIMER2_A1    : { * ( .int38 ) } > INT38 type = VECT_INIT
        TIMER2_A0    : { * ( .int39 ) } > INT39 type = VECT_INIT
        TIMER1_A1    : { * ( .int40 ) } > INT40 type = VECT_INIT
        TIMER1_A0    : { * ( .int41 ) } > INT41 type = VECT_INIT
        TIMER0_A1    : { * ( .int42 ) } > INT42 type = VECT_INIT
        TIMER0_A0    : { * ( .int43 ) } > INT43 type = VECT_INIT
        UNMI         : { * ( .int44 ) } > INT44 type = VECT_INIT
        SYSNMI       : { * ( .int45 ) } > INT45 type = VECT_INIT
        .reset       : {}               > RESET  /* MSP430 reset vector         */
    /* FRAM WRITE PROTECTION SEGMENT DEFINITONS                                 */
    #ifdef _FRWP_ENABLE
        __mpu_enable=1;
        start_protection_offset_address = (fram_rx_start - fram_rw_start) >> 10;
        program_fram_protection = 0x1;
        #ifdef _INFO_FRWP_ENABLE
            info_fram_protection = 0x1;
        #else
            info_fram_protection = 0x0;
        #endif
    #endif
    /* INCLUDE PERIPHERALS MEMORY MAP                                           */
    -l msp430fr2676.cmd
    Thanks and regards,
    Koichiro Tashiro
  • Hi Kohichiro
    I think Chester comment is the approach.
    May I know if "--near_data=none option" can solver user question?
    Thanks!
  • Hi Xiaodong, Chester,
    Yes, using "--near_data=none" option solved the issue.
    Thanks a lot!
    Thanks and regards,
    Koichiro Tashiro
