EVM430-FR6043: Wrong Volume Flow Rate measurements using "USSSWLib_template_example"
Part Number: EVM430-FR6043
Other Parts Discussed in Thread: TIDM-02005
I'm working on the Water Flow Measurement project for EVM430FR6043. I am measuring flow water correctly with Design Center GUI. I changed to the "USSSWLib_template_example" to automate the process. To do this, I generated headers in the GUI and copy them to the corresponding headers files of this new project, but I'm not getting the same results. Moreover, I'm obtaining almost volume flow rate zero values, as well as deltaTOF, totalTOF_UPS and totalTOF_DNS, whereas the GUI VFR values are still correct (around 520 L/h).
The way I'm getting VFR value is accesing to algResults.volumeFlowRate value.
I attach the "main.c" and the corresponding files, although thery are self generated.
/* --COPYRIGHT--,BSD
 * Copyright (C) 2019 Texas Instruments Incorporated - http://www.ti.com/
 *  Redistribution and use in source and binary forms, with or without
 *  modification, are permitted provided that the following conditions
 *  are met:
 *    Redistributions of source code must retain the above copyright
 *    Redistributions in binary form must reproduce the above copyright
 *    documentation and/or other materials provided with the
 *    distribution.
 *    Neither the name of Texas Instruments Incorporated nor the names of
 *  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
 *  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
 *  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
 *  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
 *  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
 *  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
 *  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
 *  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
 *  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
 *  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
 *  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
 * --/COPYRIGHT--*/
#include <msp430.h>
#include "main.h"
USS_Algorithms_Results algorithms_Results;
static void checkCode(USS_message_code code, USS_message_code expectedCode);
static void handlePllUnlockEvent(void);
static void disableApplicationInterrupts(void);
static void enableApplicationInterrupts(void);
#if APPLICATION_ENABLE_UART_DEBUG
static void uartTxByte(char string);
static void uartTxHexByte(uint8_t Data);
static uint8_t nibbleToHex(uint8_t nibble);
static void uartTxUSSResult(uint8_t delimiter, float *data);
#endif
int main(void)
#if (APPLICATION_ENABLE_CHANNEL_SWAP == true)
    uint16_t appSwapInterval = APPLICATION_CHANNEL_SWAP_INTERVAL;
#endif
#if (APPLICATION_ENABLE_ABSTOF_DTOF_OFFSET_CALIBRATION == true)
    USS_dTof_absTof_offset_results abstoFDtofTestResults;
    USS_dTof_absTof_offset_test_config abstoFDtofTestConfig =
         .numOfTestIterations        = APPLICATION_ABSTOF_DTOF_OFFSET_UPDATE_INTERVAL,
         .isUseLPMCapture            = APPLICATION_ABSTOF_DTOF_OFFSET_LPM_CAPTURE,
         .isCalculateUpsAbsTofOffset = APPLICATION_ABSTOF_DTOF_OFFSET_CALC_UPS_ABSTOF,
         .isCalculateDnsAbsTofOffset = APPLICATION_ABSTOF_DTOF_OFFSET_CALC_DNS_ABSTOF,
         .isCalculateDToFOffset      = APPLICATION_ABSTOF_DTOF_OFFSET_CALC_DTOF,
#endif
    volatile USS_message_code code;
    USS_Algorithms_Results algResults;
    USS_calibration_hspll_results testResults;
    // Register PLL unlock event
    USS_registerHSPLLInterruptCallback(USS_HSPLL_Interrupt_PLLUNLOCK,
                                       &handlePllUnlockEvent);
    code = USS_configureUltrasonicMeasurement(&gUssSWConfig);
    checkCode(code, USS_message_code_no_error);
#if((USS_ALG_ABS_TOF_COMPUTATION_MODE == USS_ALG_ABS_TOF_COMPUTATION_MODE_LOBE_WIDE) || \
    (USS_ALG_ABS_TOF_COMPUTATION_MODE == USS_ALG_ABS_TOF_COMPUTATION_MODE_HILBERT_WIDE))
    // Reference binary pattern are only needed by
    // USS_Alg_AbsToF_Calculation_Option_lobeWide and
    // USS_Alg_AbsToF_Calculation_Option_hilbertWide AbsToF computation options
    if((USS_Alg_AbsToF_Calculation_Option_lobeWide ==
            gUssSWConfig.algorithmsConfig->absToFOption)
       || (USS_Alg_AbsToF_Calculation_Option_hilbertWide ==
               gUssSWConfig.algorithmsConfig->absToFOption))
#if defined(__MSP430_HAS_SAPH_A__)
        if(USS_measurement_pulse_generation_mode_multi_tone ==
                gUssSWConfig.measurementConfig->pulseConfig->pulseGenMode)
            code = USS_generateMultiToneBinaryPattern(&gUssSWConfig);
#endif
        if(USS_measurement_pulse_generation_mode_multi_tone !=
            code = USS_generateMonoDualToneBinaryPattern(&gUssSWConfig);
#if (APPLICATION_ENABLE_BINARY_PATTERN_SIZE_SCALING == true)
    gUssSWConfig.algorithmsConfig->binaryPatternLength =
            (gUssSWConfig.captureConfig->sampleSize / APPLICATION_BINARY_PATTERN_SCALE_FACTOR);
#endif
#endif
    // Application must ensure no application level interrupts occur while
    // verifying HSPLL Frequency
    disableApplicationInterrupts();
    code = USS_verifyHSPLLFrequency(&gUssSWConfig, &testResults);
    // Application can re-enable interrupts after HSPLL verification
    enableApplicationInterrupts();
    gUssSWConfig.algorithmsConfig->clockRelativeError = _IQ27div((int32_t)(testResults.actualTestCount -
            testResults.expectedResult),testResults.expectedResult);
    code = USS_initAlgorithms(&gUssSWConfig);
#if (APPLICATION_ENABLE_SIGNAL_GAIN_CALIBRATION == true)
    code = USS_calibrateSignalGain(&gUssSWConfig);
    checkCode(code, USS_message_code_Signal_Gain_Calibration_successful);
#endif
    code = USS_calculateOffsets(&gUssSWConfig, &abstoFDtofTestResults,
                                &abstoFDtofTestConfig);
    code = USS_updateAdditionalCaptureDelay(&gUssSWConfig,
          ((abstoFDtofTestResults.upsAbsToFOffset + abstoFDtofTestResults.dnsAbsToFOffset) /2.0f) -
          APPLICATION_ABSTOF_REFERENCE);
    code = USS_updateDtoFOffset(&gUssSWConfig, (-1.0f *abstoFDtofTestResults.dToFOffset));
#endif
    // Set the background timer period to 1 second
    USS_configAppTimerPeriod(&gUssSWConfig, gUssSWConfig.systemConfig->measurementPeriod);
    while(1)
        code = USS_startLowPowerUltrasonicCapture(&gUssSWConfig);
        code = USS_runAlgorithms(&gUssSWConfig,&algResults);
        checkCode(code, USS_message_code_valid_results);
        if(appSwapInterval == 0)
            code = USS_swapCaptureChannels(&gUssSWConfig);
            code = USS_swapAlgorithmsCaptureBuffers(&gUssSWConfig);
        }else{
            appSwapInterval--;
#endif
        uartTxUSSResult(APPLICATION_UART_ABSTOF_UPS_DELIM,&algResults.totalTOF_UPS);
        uartTxUSSResult(APPLICATION_UART_ABSTOF_DNS_DELIM,&algResults.totalTOF_DNS);
        uartTxUSSResult(APPLICATION_UART_DTOF_DELIM,&algResults.deltaTOF);
        uartTxUSSResult(APPLICATION_UART_VFR_DELIM,&algResults.volumeFlowRate);
        if(algResults.volumeFlowRate>100)
            puts("Caudal");
#endif
        // Wait for timer to elapse
        USS_waitForAppTimerElapse(&gUssSWConfig,USS_low_power_mode_option_low_power_mode_3);
    while(!(UCA1IFG & UCTXIFG));
    UCA1TXBUF = string;
    uartTxByte(nibbleToHex(Data >> 4));
    uartTxByte(nibbleToHex(Data & 0x0F));
    uint8_t ret = nibble;
    if(nibble < 10)
        ret += '0';
    else
        ret += 'A' - 10;
    return(ret);
    uint8_t *ptr;
    // Send delimiter
    uartTxByte(delimiter);
    // Send comma
    uartTxByte(',');
    ptr = (uint8_t *) data;
    // Send float values
    uartTxHexByte(ptr[3]);
    uartTxHexByte(ptr[2]);
    uartTxHexByte(ptr[1]);
    uartTxHexByte(ptr[0]);
    // Send new line return
    uartTxByte('\n');
    uartTxByte('\r');
#endif
    // If USS PLL unlock event is detected rest USS Module and reconfigure
    // measurement
    USS_resetUSSModule(&gUssSWConfig, true);
// This is a place holder for the application to disable interrupts which might
// be triggered during HSPLL verification
void disableApplicationInterrupts(void){
// This is a place holder for the application to enable interrupts once
// HSPLL verification has completed
void enableApplicationInterrupts(void){
    if(code != expectedCode)
        // Trap code
        while(1);
3731.USS_userConfig.h
1273.USS_intrplCorrLUT.h
0525.USS_meterVFRCalibFlow.h
