Part Number: MSP430FR2676
My customer want measure SNR without "Design center GUI" because the structure of their application makes it impossible to connect wiring for communication.
How do they measure SNR without GUI?
Sasaki
Sasaki
Hi Sasaki,
Which SNR? ADC module? or others?
Could you help to provide more details about this?
Thanks!
Best Regards
Johnson
Hi Sasaki,
This function is design for check if the hardware design is good, thus I think offline function is OK.
Why customer need this function without GUI?
Thanks!
Best Regards
Johnson
Hi Hohnson-san,
Thank you for your repoly.
The structure of their application makes it impossible to connect wiring for communication.
Sasaki
Hi Sasaki,
It is difficult for porting SNR Measure function from GUI to MCU, but there are another method can read the Noise Level in MCU:
/* --COPYRIGHT--,BSD
* Copyright (c) 2017, Texas Instruments Incorporated
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* * Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* * Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* * Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
* THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
* --/COPYRIGHT--*/
// Development main.c for MSP430FR2522 and MSP430FR2512 CapTIvate devices.
// This starter application initializes the CapTIvate touch library
// for the touch panel specified by CAPT_UserConfig.c/.h via a call to
// CAPT_appStart(), which initializes and calibrates all sensors in the
// application, and starts the CapTIvate interval timer.
// Then, the capacitive touch interface is driven by calling the CapTIvate
// application handler, CAPT_appHandler(). The application handler manages
// whether the user interface (UI) is running in full active scan mode, or
// in a low-power wake-on-proximity mode.
// \version 1.80.00.30
// Released on March 26, 2019
#include <msp430.h> // Generic MSP430 Device Include
#include "driverlib.h" // MSPWare Driver Library
#include "captivate.h" // CapTIvate Touch Software Library
#include "CAPT_App.h" // CapTIvate Application Code
#include "CAPT_BSP.h" // CapTIvate EVM Board Support Package
#include "AJB.h"
#include "CAPT_EMC.h"
#include "CAPT_Type.h"
char NoiseState = 0;
uint16_t NoiseLevel = 0;
uint16_t NoiseCount = 0;
uint16_t buffer[2];
void EMCLevel_Change(void)
if(NoiseState == 3)
g_EMCConfig.selfModeOversamplingStyle = e16xOversampling;
g_EMCConfig.coeffA = _IQ31(0.01087),
MAP_CAPT_loadEMCConfig(&g_EMCConfig);
// BTN00.ui8CntBeta = 2;
// BTN00_E00.ui8TouchThreshold = 5;
// BTN00_E01.ui8TouchThreshold = 5;
// BTN00_E02.ui8TouchThreshold = 5;
// BTN00_E03.ui8TouchThreshold = 5;
else if(NoiseState == 2)
g_EMCConfig.coeffA = _IQ31(0.01088),
else if(NoiseState == 1)
g_EMCConfig.coeffA = _IQ31(0.01092),
// BTN00_E00.ui8TouchThreshold = 7;
// BTN00_E01.ui8TouchThreshold = 7;
// BTN00_E02.ui8TouchThreshold = 7;
// BTN00_E03.ui8TouchThreshold = 7;
else
g_EMCConfig.selfModeOversamplingStyle = e4xOversampling;
// BTN00_E00.ui8TouchThreshold = 6;
// BTN00_E01.ui8TouchThreshold = 6;
// BTN00_E02.ui8TouchThreshold = 6;
// BTN00_E03.ui8TouchThreshold = 6;
uint16_t lastnoiseState= 0;
void EMCLevel_Evaluation(void)
NoiseLevel = CAPT_getGlobalFilteredNoiseLevel();
lastnoiseState = NoiseState;
if( NoiseLevel>60)
NoiseState = 3;
if( NoiseLevel>46)
NoiseState = 2;
if( NoiseLevel>5)
NoiseState = 1;
else
NoiseState = 0;
if (NoiseState != lastnoiseState)
EMCLevel_Change();
void main(void)
// Initialize the MCU
// BSP_configureMCU() sets up the device IO and clocking
// The global interrupt enable is set to allow peripherals
// to wake the MCU.
WDTCTL = WDTPW | WDTHOLD;
BSP_configureMCU();
Panel_Init();
__bis_SR_register(GIE);
// Start the CapTIvate application
CAPT_appStart();
// Background Loop
while(1)
// Run the captivate application handler.
CAPT_appHandler();
// buffer[1] = NoiseState;
buffer[0] = NoiseLevel;
CAPT_writeGeneralPurposeData(&buffer[0], 1);
// This is a great place to add in any
// background application code.
__no_operation();
// End of background loop iteration
// Go to sleep if there is nothing left to do
} // End background loop
} // End main()
Step1: Enable noise immunity
Step2: Run CAPT_getGlobalFilteredNoiseLevel();
Thanks!
Best Regards
Johnson
