MSP430F6777A: Phase Calibration Issue in Three Phase Meter
Part Number: MSP430F6777A
We are using MSP430F6777A chip in one of our meters and are having some issue during Phase calibration. As mentioned in the user manual and 3 Phase Metering application note we are using the DELAYINT register setting to achieve this. The ADC settings for the same are as given below.
Register Name
Clock Source Select
Clock Pre Div
Clock Div
REF Select
Overflow
Setting
SD24SSEL_SMCLK
SD24PDIV_4
SD24_B_CLOCKDIVIDER_1
SD24_B_REF_INTERNAL
SD24OV32_On_32
ADC Settings Advanced:
CH NO
CH Description
Converter
Alignment
Start Select
Conversion Mode
Data Format
Sample Delay
Over sampling Ratio
Gain
0
Current 3rd Channel
0
SD24ALGN
SD24SCS__GROUP0 (0x0008)
0x00
SD24DF_1
SD24INTDLY_0
256
SD24GAIN_1 (0)
1
Current 2nd Channel
1
SD24ALGN
0x00
SD24DF_1
SD24INTDLY_0
256
SD24GAIN_1 (0)
2
Current 1st Channel
2
SD24ALGN
0x00
SD24DF_1
SD24INTDLY_0
256
SD24GAIN_1 (0)
3
Voltage 3rd Channel
3
SD24ALGN
0x00
SD24DF_1
SD24INTDLY_0
256
SD24GAIN_1 (0)
4
Voltage 2nd Channel
4
SD24ALGN
0x00
SD24DF_1
SD24INTDLY_0
256
SD24GAIN_1 (0)
5
Voltage 1st Channel
5
SD24ALGN
0x00
SD24DF_1
SD24INTDLY_0
256
SD24GAIN_1 (0)
6
Neutral Voltage
6
SD24ALGN
0x00
SD24DF_1
SD24INTDLY_0
256
SD24GAIN_1 (0)
Preload Channel and Register Settings:-
CH NO
CH Description
Register Used
Load value
0
Current 3rd Channel
SD24BPRE0
172
1
Current 2nd Channel
SD24BPRE1
160
2
Current 1st Channel
SD24BPRE2
158
3
Voltage 3rd Channel
SD24BPRE3
128
4
Voltage 2nd Channel
SD24BPRE4
128
5
Voltage 1st Channel
SD24BPRE5
128
6
Neutral Voltage
SD24BPRE6
128
With Following ADC settings and keeping the ISR empty our ISR gets generated every 164 uSec(as expected). This is without Phase calibration in picture. We tried testing with fixed values in preload register for phase calibration and saw that the interrupt generation shifts from 164 uSec to 136 uSec. Please help us understand if we are missing some thing in setting up the ADC.
NOTE: The default preload value is 128
