Part Number: MSP430FR2633
Hello ,
I am using MSP430FR266 for our capacitive touch keypad application which has 16 touch button using mutual capacitance. Currently , it works perfectly fine when the user touches keys softly, but whenever the touch is hard just like one presses the physical button, touch is not detected and it hangs for few seconds. I am attaching my captouch config file.
Please let me know if more information is required for this purpose.
/* --COPYRIGHT--,BSD
* Copyright (c) 2017, Texas Instruments Incorporated
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* * Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* * Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* * Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
* THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
* --/COPYRIGHT--*/
// Generated by Captivate Design Center v1_83_00_08 on Mon Nov 08 13:52:58 IST 2021
// CAPT_UserConfig.c
// \version 1.83.00.05
// Released on May 15, 2020
// NOTE: This is an automatically generated source code file! The Captivate
// Design Center generates the User Configuration file automatically based
// upon the sensor layout that was created.
// Changes to this file will be OVERWRITTEN if a you select
// "Update Existing Project" under "Generate Source Code" in the Design Center.
// To avoid interference with the code generation process, keep ALL application
// code external to this file.
#include "CAPT_UserConfig.h"
//! Captivate Element Definitions
//! All elements in this application are defined below.
//! Each element has 3 components:
//! 1) a raw count array (One index per freq. scanned) (uint16_t)
//! 2) a tuning array (One index per freq. scanned) (tCaptivateElementTuning)
//! 3) a element structure (tElement)
// Sensor: BTN00, Element: E02
uint16_t BTN00_E02_RawCnts[CAPT_MUTUAL_FREQ_CNT];
tCaptivateElementTuning BTN00_E02_Tuning[CAPT_MUTUAL_FREQ_CNT];
tElement BTN00_E02 = //KEY 7
.ui8TxPin = 1,
.ui8TxBlock = 2,
.ui8RxPin = 1,
.ui8RxBlock = 3,
.ui8TouchThreshold = 42,
.pRawCount = BTN00_E02_RawCnts,
.pTuning = BTN00_E02_Tuning,
// Sensor: BTN00, Element: E00
uint16_t BTN00_E00_RawCnts[CAPT_MUTUAL_FREQ_CNT];
tCaptivateElementTuning BTN00_E00_Tuning[CAPT_MUTUAL_FREQ_CNT];
tElement BTN00_E00 = // KEY 1
.ui8TxPin = 1,
.ui8TxBlock = 2,
.ui8RxPin = 2,
.ui8RxBlock = 2,
.ui8TouchThreshold = 31,
.pRawCount = BTN00_E00_RawCnts,
.pTuning = BTN00_E00_Tuning,
// Sensor: BTN00, Element: E01
uint16_t BTN00_E01_RawCnts[CAPT_MUTUAL_FREQ_CNT];
tCaptivateElementTuning BTN00_E01_Tuning[CAPT_MUTUAL_FREQ_CNT];
tElement BTN00_E01 = // KEY 4
.ui8TxPin = 1,
.ui8TxBlock = 2,
.ui8RxPin = 3,
.ui8RxBlock = 2,
.ui8TouchThreshold = 28,
.pRawCount = BTN00_E01_RawCnts,
.pTuning = BTN00_E01_Tuning,
// Sensor: BTN00, Element: E03
uint16_t BTN00_E03_RawCnts[CAPT_MUTUAL_FREQ_CNT];
tCaptivateElementTuning BTN00_E03_Tuning[CAPT_MUTUAL_FREQ_CNT];
tElement BTN00_E03 = // key esc
.ui8TxPin = 1,
.ui8TxBlock = 2,
.ui8RxPin = 3,
.ui8RxBlock = 3,
.ui8TouchThreshold = 33,
.pRawCount = BTN00_E03_RawCnts,
.pTuning = BTN00_E03_Tuning,
// Sensor: BTN00, Element: E06
uint16_t BTN00_E06_RawCnts[CAPT_MUTUAL_FREQ_CNT];
tCaptivateElementTuning BTN00_E06_Tuning[CAPT_MUTUAL_FREQ_CNT];
tElement BTN00_E06 = //key 8
.ui8TxPin = 0,
.ui8TxBlock = 2,
.ui8RxPin = 1,
.ui8RxBlock = 3,
.ui8TouchThreshold = 39,
.pRawCount = BTN00_E06_RawCnts,
.pTuning = BTN00_E06_Tuning,
// Sensor: BTN00, Element: E04
uint16_t BTN00_E04_RawCnts[CAPT_MUTUAL_FREQ_CNT];
tCaptivateElementTuning BTN00_E04_Tuning[CAPT_MUTUAL_FREQ_CNT];
tElement BTN00_E04 = //key 2
.ui8TxPin = 0,
.ui8TxBlock = 2,
.ui8RxPin = 2,
.ui8RxBlock = 2,
.ui8TouchThreshold = 25, //38,
.pRawCount = BTN00_E04_RawCnts,
.pTuning = BTN00_E04_Tuning,
// Sensor: BTN00, Element: E05
uint16_t BTN00_E05_RawCnts[CAPT_MUTUAL_FREQ_CNT];
tCaptivateElementTuning BTN00_E05_Tuning[CAPT_MUTUAL_FREQ_CNT];
tElement BTN00_E05 = // key 5
.ui8TxPin = 0,
.ui8TxBlock = 2,
.ui8RxPin = 3,
.ui8RxBlock = 2,
.ui8TouchThreshold = 30, //37,
.pRawCount = BTN00_E05_RawCnts,
.pTuning = BTN00_E05_Tuning,
// Sensor: BTN00, Element: E07
uint16_t BTN00_E07_RawCnts[CAPT_MUTUAL_FREQ_CNT];
tCaptivateElementTuning BTN00_E07_Tuning[CAPT_MUTUAL_FREQ_CNT];
tElement BTN00_E07 = //key 0
.ui8TxPin = 0,
.ui8TxBlock = 2,
.ui8RxPin = 3,
.ui8RxBlock = 3,
.pRawCount = BTN00_E07_RawCnts,
.pTuning = BTN00_E07_Tuning,
// Sensor: BTN00, Element: E10
uint16_t BTN00_E10_RawCnts[CAPT_MUTUAL_FREQ_CNT];
tCaptivateElementTuning BTN00_E10_Tuning[CAPT_MUTUAL_FREQ_CNT];
tElement BTN00_E10 = //key 9
.ui8TxPin = 3,
.ui8TxBlock = 0,
.ui8RxPin = 1,
.ui8RxBlock = 3,
.ui8TouchThreshold = 38,
.pRawCount = BTN00_E10_RawCnts,
.pTuning = BTN00_E10_Tuning,
// Sensor: BTN00, Element: E08
uint16_t BTN00_E08_RawCnts[CAPT_MUTUAL_FREQ_CNT];
tCaptivateElementTuning BTN00_E08_Tuning[CAPT_MUTUAL_FREQ_CNT];
tElement BTN00_E08 = // key 3
.ui8TxPin = 3,
.ui8TxBlock = 0,
.ui8RxPin = 2,
.ui8RxBlock = 2,
.ui8TouchThreshold = 35,
.pRawCount = BTN00_E08_RawCnts,
.pTuning = BTN00_E08_Tuning,
// Sensor: BTN00, Element: E09
uint16_t BTN00_E09_RawCnts[CAPT_MUTUAL_FREQ_CNT];
tCaptivateElementTuning BTN00_E09_Tuning[CAPT_MUTUAL_FREQ_CNT];
tElement BTN00_E09 = //key 6
.ui8TxPin = 3,
.ui8TxBlock = 0,
.ui8RxPin = 3,
.ui8RxBlock = 2,
.ui8TouchThreshold = 36,
.pRawCount = BTN00_E09_RawCnts,
.pTuning = BTN00_E09_Tuning,
// Sensor: BTN00, Element: E11
uint16_t BTN00_E11_RawCnts[CAPT_MUTUAL_FREQ_CNT];
tCaptivateElementTuning BTN00_E11_Tuning[CAPT_MUTUAL_FREQ_CNT];
tElement BTN00_E11 = // key enter
.ui8TxPin = 3,
.ui8TxBlock = 0,
.ui8RxPin = 3,
.ui8RxBlock = 3,
.pRawCount = BTN00_E11_RawCnts,
.pTuning = BTN00_E11_Tuning,
// Sensor: BTN00, Element: E14
uint16_t BTN00_E14_RawCnts[CAPT_MUTUAL_FREQ_CNT];
tCaptivateElementTuning BTN00_E14_Tuning[CAPT_MUTUAL_FREQ_CNT];
tElement BTN00_E14 = // key reset
.ui8TxPin = 1,
.ui8TxBlock = 0,
.ui8RxPin = 1,
.ui8RxBlock = 3,
.ui8TouchThreshold = 40,
.pRawCount = BTN00_E14_RawCnts,
.pTuning = BTN00_E14_Tuning,
// Sensor: BTN00, Element: E12
uint16_t BTN00_E12_RawCnts[CAPT_MUTUAL_FREQ_CNT];
tCaptivateElementTuning BTN00_E12_Tuning[CAPT_MUTUAL_FREQ_CNT];
tElement BTN00_E12 = // key arm
.ui8TxPin = 1,
.ui8TxBlock = 0,
.ui8RxPin = 2,
.ui8RxBlock = 2,
.pRawCount = BTN00_E12_RawCnts,
.pTuning = BTN00_E12_Tuning,
// Sensor: BTN00, Element: E13
uint16_t BTN00_E13_RawCnts[CAPT_MUTUAL_FREQ_CNT];
tCaptivateElementTuning BTN00_E13_Tuning[CAPT_MUTUAL_FREQ_CNT];
tElement BTN00_E13 = // key disarm
.ui8TxPin = 1,
.ui8TxBlock = 0,
.ui8RxPin = 3,
.ui8RxBlock = 2,
.ui8TouchThreshold = 34,
.pRawCount = BTN00_E13_RawCnts,
.pTuning = BTN00_E13_Tuning,
// Sensor: BTN00, Element: E15
uint16_t BTN00_E15_RawCnts[CAPT_MUTUAL_FREQ_CNT];
tCaptivateElementTuning BTN00_E15_Tuning[CAPT_MUTUAL_FREQ_CNT];
tElement BTN00_E15 = // key settings
.ui8TxPin = 1,
.ui8TxBlock = 0,
.ui8RxPin = 3,
.ui8RxBlock = 3,
.pRawCount = BTN00_E15_RawCnts,
.pTuning = BTN00_E15_Tuning,
//! Captivate Time Cycle Definitions
//! All time cycles in this application are defined below. Time cycles are
//! groups of elements that are measured together in parallel in one time slot.
//! Each cycle has 2 components:
//! 1) an element pointer array to the member elements (tElement*)
//! 2) a cycle structure (tCycle)
// Time Cycle: BTN00_C00
tElement* BTN00_C00_Elements[1] =
&BTN00_E02,
tCycle BTN00_C00 =
.ui8NrOfElements = 1,
.pElements = BTN00_C00_Elements,
// Time Cycle: BTN00_C01
tElement* BTN00_C01_Elements[1] =
&BTN00_E00,
tCycle BTN00_C01 =
.pElements = BTN00_C01_Elements,
// Time Cycle: BTN00_C02
tElement* BTN00_C02_Elements[2] =
&BTN00_E01,
&BTN00_E03,
tCycle BTN00_C02 =
.ui8NrOfElements = 2,
.pElements = BTN00_C02_Elements,
// Time Cycle: BTN00_C03
tElement* BTN00_C03_Elements[1] =
&BTN00_E06,
tCycle BTN00_C03 =
.pElements = BTN00_C03_Elements,
// Time Cycle: BTN00_C04
tElement* BTN00_C04_Elements[1] =
&BTN00_E04,
tCycle BTN00_C04 =
.pElements = BTN00_C04_Elements,
// Time Cycle: BTN00_C05
tElement* BTN00_C05_Elements[2] =
&BTN00_E05,
&BTN00_E07,
tCycle BTN00_C05 =
.pElements = BTN00_C05_Elements,
// Time Cycle: BTN00_C06
tElement* BTN00_C06_Elements[1] =
&BTN00_E10,
tCycle BTN00_C06 =
.pElements = BTN00_C06_Elements,
// Time Cycle: BTN00_C07
tElement* BTN00_C07_Elements[1] =
&BTN00_E08,
tCycle BTN00_C07 =
.pElements = BTN00_C07_Elements,
// Time Cycle: BTN00_C08
tElement* BTN00_C08_Elements[2] =
&BTN00_E09,
&BTN00_E11,
tCycle BTN00_C08 =
.pElements = BTN00_C08_Elements,
// Time Cycle: BTN00_C09
tElement* BTN00_C09_Elements[1] =
&BTN00_E14,
tCycle BTN00_C09 =
.pElements = BTN00_C09_Elements,
// Time Cycle: BTN00_C10
tElement* BTN00_C10_Elements[1] =
&BTN00_E12,
tCycle BTN00_C10 =
.pElements = BTN00_C10_Elements,
// Time Cycle: BTN00_C11
tElement* BTN00_C11_Elements[2] =
&BTN00_E13,
&BTN00_E15,
tCycle BTN00_C11 =
.pElements = BTN00_C11_Elements,
//! Captivate Sensor Definitions
//! All sensors in this application are defined below. Sensors are
//! groups of time cycles that utilize raw measurement data to create an
//! abstract sensor type, such as a button, slider, wheel, or prox sensor.
//! Each sensor has 3 components:
//! 1) a cycle pointer array to the member time cycles (tCycle*)
//! 2) a sensor-specific parameter structure (tGenericSensorParams)
//! 3) a sensor structure (tSensor)
//Sensor: BTN00
const tCycle* BTN00_Cycles[12] =
&BTN00_C00,
&BTN00_C01,
&BTN00_C02,
&BTN00_C03,
&BTN00_C04,
&BTN00_C05,
&BTN00_C06,
&BTN00_C07,
&BTN00_C08,
&BTN00_C09,
&BTN00_C10,
&BTN00_C11,
tButtonSensorParams BTN00_Params;
tSensor BTN00 =
// Basic Properties
.TypeOfSensor = eButtonGroup,
.SensingMethod = eProjected,
.DirectionOfInterest = eDOIUp,
.pvCallback = NULL,
.ui8NrOfCycles = 12,
.pCycle = BTN00_Cycles,
.pSensorParams = (tGenericSensorParams*)&BTN00_Params,
// Conversion Control Parameters
.ui16ConversionCount = 500,
.ui16ConversionGain = 100,
.ui8FreqDiv = 2,
.ui8ChargeLength = 0,
.ui8TransferLength = 0,
.bModEnable = false,
.ui8BiasControl = 3,
.bCsDischarge = true,
.bLpmControl = false,
.ui8InputSyncControl = 0,
.bTimerSyncControl = false,
.bIdleState = true,
// Tuning Parameters
.ui16ProxThreshold = 50,
.ui16NegativeTouchThreshold = 30,
.ui16ErrorThreshold = 1500,
.ui16TimeoutThreshold = 1980,//3960,
.ProxDbThreshold.DbIn = 2,
.ProxDbThreshold.DbOut = 2,
.TouchDbThreshold.DbIn = 2,
.TouchDbThreshold.DbOut = 2,
.bCountFilterEnable = true,
.ui8CntBeta = 1,
.bSensorHalt = false,
.bPTSensorHalt = true,
.bPTElementHalt = true,
.ui8LTABeta = 7,
.bReCalibrateEnable = true,
#if (CAPT_CONDUCTED_NOISE_IMMUNITY_ENABLE==true)
//! \var g_EMCConfig
//! This structure stores the EMC configuration for this application.
const tEMCConfig g_EMCConfig =
// Conversion Style
.selfModeConversionStyle = CAPT_SELF_MODE_CONVERSION_STYLE,
.projModeConversionStyle = CAPT_PROJ_MODE_CONVERSION_STYLE,
// Oversampling Style
.selfModeOversamplingStyle = CAPT_SELF_MODE_OVERSAMPLING_STYLE,
.projModeOversamplingStyle = CAPT_PROJ_MODE_OVERSAMPLING_STYLE,
// Jitter Filter Enable
.bJitterFilterEnable = true,
// Noise Thresholds and Calibration Noise Limits
.ui8NoiseThreshold = CAPT_NOISE_THRESHOLD,
.ui16CalibrationNoiseLimit = CAPT_CALIBRATION_NOISE_LIMIT,
.ui8CalibrationTestSampleSize = 8,
// Dynamic Threshold Adjustment Parameters
.bEnableDynamicThresholdAdjustment = CAPT_DYNAMIC_THRESHOLD_ADJUSTMENT,
.ui8MaxRelThreshAdj = 76,
.ui8NoiseLevelFilterEntryThresh = 40,
.ui8NoiseLevelFilterExitThresh = 0,
.ui8NoiseLevelFilterDown = 6,
.ui8NoiseLevelFilterUp = 1,
.coeffA = _IQ31(0.0065),
.coeffB = _IQ31(0.050)
#endif
//! \var g_pCaptivateSensorArray
//! This array allows for indexed access to any
//! sensor in the configuration.
tSensor* g_pCaptivateSensorArray[CAPT_SENSOR_COUNT] =
&BTN00,
//! \var g_uiApp
//! This structure stores the global settings for this application.
tCaptivateApplication g_uiApp =
.state = eUIActive,
.pSensorList = &g_pCaptivateSensorArray[0],
.ui8NrOfSensors = CAPT_SENSOR_COUNT,
.ui8AppLPM = CAPT_LOW_POWER_MODE,
.bElementDataTxEnable = true,
.bSensorDataTxEnable = true,
.ui16ActiveModeScanPeriod = 33,
.ui16WakeOnProxModeScanPeriod = 100,
.ui16InactivityTimeout = 32,
.ui8WakeupInterval = 5,
