MSP430F5438A: Stack Size
Part Number: MSP430F5438A
How to increase stack size?
  • Hi Anburaja,
    You can right click on the project > Properties > C/C++ Build > Linker > Basic Options and change/increase the stack size.
    Amruta
  • The CPU cares not at all about the stack size set in some tool. It will grow downward from its initial value, usually at the top of SRAM.There is nothing in the  hardware that will limit its value short of running off the bottom of SRAM.
    It may or may not run into locations being used for some other purpose. It is up to you to manage things so that there isn't a conflict. If it turns out that your application absolutely requires more stack space than a part has, you will have to switch to a part with more SRAM.
