[FAQ] Important note for early MSPM0 customer
Other Parts Discussed in Thread: SYSCONFIG, UNIFLASH, MSPM0-SDK
Important note for early MSPM0 customers
TI recently launched a new family of Arm Cortex-M0+ MCUs, including the MSPM0L series and MSPM0G series. These MCUs are accompanied by a comprehensive amount of collateral and tools support which might not be compatible for early adopters.
This guide is intended to clarify which documentation and tools should be used for early samples and production samples.
 Update: The repository for MSPM0 early samples on My Secure Resources has been deprecated. It's recommended to use production samples moving forward and all documentation and tools will continue being released on TI.com and dev.ti.com. Please contact your local sales if you need access to early samples content.
How to determine MSPM0 Sample versions
You have production samples if:
  • You were able to order samples directly from ti.com and didn’t need to contact a TI sales office.
  • Your device is marked as MSPM0Lxxx/MSPM0Gxxx/M0Lxxx/M0Gxxx/Lxxx/Gxxx (depending on package)
  • Your LaunchPad is marked as Rev A
  • The VERSION bit fields (31-28) in the DEVICEID Register (see Technical Reference Manual) is 0x1
  • Note that MSPM0L production devices are sampling now; however, MSPM0G devices are not available yet in production silicon.
You have early samples if:
  • You did not order samples directly from ti.com and to order samples through a TI sales office.
  • Your device is marked as XM0L/XM0G
  • Your LaunchPad is marked as Rev 1.0
  • The VERSION bit fields (31-28) in the DEVICEID Register (see Technical Reference Manual) is 0x0
Documentation
Production Samples
Early Samples (see update above)
MSPM0L Technical Reference Manual
TI.com (SLAU847)
My Secure Resources
MSPM0L34x/L130x datasheet
TI.com (SLASEX0)
My Secure Resources
MSPM0L110x datasheet
TI.com (SLASEX5)
My Secure Resources
MSPM0G Technical Reference Manual
TI.com (SLAU846)
My Secure Resources
MSPM0G150x datasheet
TI.com (SLASEW9)
My Secure Resources
MSPM0G350x datasheet
TI.com (SLASEX6)
My Secure Resources
MSPM0G110x datasheet
TI.com (SLASF11)
My Secure Resources
MSPM0G310x datasheet
TI.com (SLASF12)
My Secure Resources
Application Notes, migration guides, white papers, etc.
Multiple documents available on TI.com
Most documents available on TI.com are applicable to early samples, but are intended for production samples.
Software and Tools
Production Samples
MSPM0 SDK
TI.com (MSPM0-SDK)
Version: 1.xx.xx.xx
My Secure Resources
Version: 0.xx.xx.xx
CCS Theia
TI.com (CCSTUDIO-THEIA)
Version: 1.0.0+.
Includes support package 1.x.x.x
My Secure Resources
Version: 0.90
Includes support package 0.x.x.x
CCS (Eclipse)
TI.com (CCSTUDIO)
Version: 12.2+. 12.4 preferred
12.2 includes support package 0.2.0.x
12.3 includes support package 1.0.x.x
12.4 includes support package 1.1.x.x
TI.com (CCSTUDIO 12.1 or older)
Version: 11.x to 12.1
Requires manual installation of support package available through My Secure Resources
SysConfig
TI.com (SYSCONFIG)
Version 1.15.0.2826+. 1.17.x.x preferred
CCS Theia 1.0.x includes 1.16.x.x
CCS 12.2 includes 1.15.0.2826
CCS 12.3 includes 1.16.x.x
CCS 12.4 includes 1.17.x.x
My Secure Resources
Version 1.15.0.2729
UniFlash
TI.com (UNIFLASH)
Version: 8.2.x+
TI.com (UNIFLASH 8.0.0)
Version 8.0.0
MSPM0-SDK on TI-Rex
dev.ti.com
Not available
MSPM0-ACADEMY on TI-Rex
dev.ti.com
Not available
IAR Embedded workbench for Arm
IAR.com
Version: 9.40.1 preferred.
IAR.com
Version: 9.20.1 (recommended and validated with SDK)
Keil MDK-Arm with uVision
Keil.com
Version: 5.38a+
CMSIS-Pack 1.1.0.x available now
Keil.com
Version: 5.36 (recommended and validated with SDK)
CMSIS-Pack available through My Secure Resources
