Below  text is the content of Linker_CC430f6137.cmd  file.I think this might help.
/* lnk_cc430f6137.cmd - LINKER COMMAND FILE FOR LINKING CC430F6137 PROGRAMS */
/* Usage: lnk430 <obj files...> -o <out file> -m <map file> lnk.cmd */
/* cl430 <src files...> -z -o <out file> -m <map file> lnk.cmd */
/* These linker options are for command line linking only. For IDE linking, */
/* you should set your linker options in Project Properties */
/* -c LINK USING C CONVENTIONS */
/* -stack 0x0100 SOFTWARE STACK SIZE */
/* -heap 0x0100 HEAP AREA SIZE */
/* SPECIFY THE SYSTEM MEMORY MAP */
MEMORY
 SFR : origin = 0x0000, length = 0x0010
 PERIPHERALS_8BIT : origin = 0x0010, length = 0x00F0
 PERIPHERALS_16BIT : origin = 0x0100, length = 0x0100
 RAM : origin = 0x1C00, length = 0x0FFE
 INFOA : origin = 0x1980, length = 0x0080
 INFOB : origin = 0x1900, length = 0x0080
 INFOC : origin = 0x1880, length = 0x0080
 INFOD : origin = 0x1800, length = 0x0080
 FLASH_VL_OV : origin = 0x8000, length = 0x0360
 FLASH_VL_ISFS : origin = 0x8360, length = 0x00A0
 FLASH_VL_GFB : origin = 0x8400, length = 0x0400
 FLASH_VL_ISF : origin = 0x8800, length = 0x0800
 FLASH_VL_EXT : origin = 0x9000, length = 0x0800
 FLASH : origin = 0x9800, length = 0x6780
 INT00 : origin = 0xFF80, length = 0x0002
 INT01 : origin = 0xFF82, length = 0x0002
 INT02 : origin = 0xFF84, length = 0x0002
 INT03 : origin = 0xFF86, length = 0x0002
 INT04 : origin = 0xFF88, length = 0x0002
 INT05 : origin = 0xFF8A, length = 0x0002
 INT06 : origin = 0xFF8C, length = 0x0002
 INT07 : origin = 0xFF8E, length = 0x0002
 INT08 : origin = 0xFF90, length = 0x0002
 INT09 : origin = 0xFF92, length = 0x0002
 INT10 : origin = 0xFF94, length = 0x0002
 INT11 : origin = 0xFF96, length = 0x0002
 INT12 : origin = 0xFF98, length = 0x0002
 INT13 : origin = 0xFF9A, length = 0x0002
 INT14 : origin = 0xFF9C, length = 0x0002
 INT15 : origin = 0xFF9E, length = 0x0002
 INT16 : origin = 0xFFA0, length = 0x0002
 INT17 : origin = 0xFFA2, length = 0x0002
 INT18 : origin = 0xFFA4, length = 0x0002
 INT19 : origin = 0xFFA6, length = 0x0002
 INT20 : origin = 0xFFA8, length = 0x0002
 INT21 : origin = 0xFFAA, length = 0x0002
 INT22 : origin = 0xFFAC, length = 0x0002
 INT23 : origin = 0xFFAE, length = 0x0002
 INT24 : origin = 0xFFB0, length = 0x0002
 INT25 : origin = 0xFFB2, length = 0x0002
 INT26 : origin = 0xFFB4, length = 0x0002
 INT27 : origin = 0xFFB6, length = 0x0002
 INT28 : origin = 0xFFB8, length = 0x0002
 INT29 : origin = 0xFFBA, length = 0x0002
 INT30 : origin = 0xFFBC, length = 0x0002
 INT31 : origin = 0xFFBE, length = 0x0002
 INT32 : origin = 0xFFC0, length = 0x0002
 INT33 : origin = 0xFFC2, length = 0x0002
 INT34 : origin = 0xFFC4, length = 0x0002
 INT35 : origin = 0xFFC6, length = 0x0002
 INT36 : origin = 0xFFC8, length = 0x0002
 INT37 : origin = 0xFFCA, length = 0x0002
 INT38 : origin = 0xFFCC, length = 0x0002
 INT39 : origin = 0xFFCE, length = 0x0002
 INT40 : origin = 0xFFD0, length = 0x0002
 INT41 : origin = 0xFFD2, length = 0x0002
 INT42 : origin = 0xFFD4, length = 0x0002
 INT43 : origin = 0xFFD6, length = 0x0002
 INT44 : origin = 0xFFD8, length = 0x0002
 INT45 : origin = 0xFFDA, length = 0x0002
 INT46 : origin = 0xFFDC, length = 0x0002
 INT47 : origin = 0xFFDE, length = 0x0002
 INT48 : origin = 0xFFE0, length = 0x0002
 INT49 : origin = 0xFFE2, length = 0x0002
 INT50 : origin = 0xFFE4, length = 0x0002
 INT51 : origin = 0xFFE6, length = 0x0002
 INT52 : origin = 0xFFE8, length = 0x0002
 INT53 : origin = 0xFFEA, length = 0x0002
 INT54 : origin = 0xFFEC, length = 0x0002
 INT55 : origin = 0xFFEE, length = 0x0002
 INT56 : origin = 0xFFF0, length = 0x0002
 INT57 : origin = 0xFFF2, length = 0x0002
 INT58 : origin = 0xFFF4, length = 0x0002
 INT59 : origin = 0xFFF6, length = 0x0002
 INT60 : origin = 0xFFF8, length = 0x0002
 INT61 : origin = 0xFFFA, length = 0x0002
 INT62 : origin = 0xFFFC, length = 0x0002
 RESET : origin = 0xFFFE, length = 0x0002
/* SPECIFY THE SECTIONS ALLOCATION INTO MEMORY */
SECTIONS
 .bss : {} > RAM /* GLOBAL & STATIC VARS */
 .sysmem : {} > RAM /* DYNAMIC MEMORY ALLOCATION AREA */
 .stack : {} > RAM (HIGH) /* SOFTWARE SYSTEM STACK */
 .vl_ov : {} > FLASH_VL_OV /* All VL data is for the filesystem */
 .vl_isfs : {} > FLASH_VL_ISFS
 .vl_gfb : {} > FLASH_VL_GFB
 .vl_isf : {} > FLASH_VL_ISF
 .vl_ext : {} > FLASH_VL_EXT
 .text : {} > FLASH /* CODE */
 .cinit : {} > FLASH /* INITIALIZATION TABLES */
 .const : {} > FLASH /* CONSTANT DATA */
 .cio : {} > RAM /* C I/O BUFFER */
 .pinit : {} > FLASH /* C++ CONSTRUCTOR TABLES */
 .infoA : {} > INFOA /* MSP430 INFO FLASH MEMORY SEGMENTS */
 .infoB : {} > INFOB
 .infoC : {} > INFOC
 .infoD : {} > INFOD
 .int00 : {} > INT00 /* MSP430 INTERRUPT VECTORS */
 .int01 : {} > INT01
 .int02 : {} > INT02
 .int03 : {} > INT03
 .int04 : {} > INT04
 .int05 : {} > INT05
 .int06 : {} > INT06
 .int07 : {} > INT07
 .int08 : {} > INT08
 .int09 : {} > INT09
 .int10 : {} > INT10
 .int11 : {} > INT11
 .int12 : {} > INT12
 .int13 : {} > INT13
 .int14 : {} > INT14
 .int15 : {} > INT15
 .int16 : {} > INT16
 .int17 : {} > INT17
 .int18 : {} > INT18
 .int19 : {} > INT19
 .int20 : {} > INT20
 .int21 : {} > INT21
 .int22 : {} > INT22
 .int23 : {} > INT23
 .int24 : {} > INT24
 .int25 : {} > INT25
 .int26 : {} > INT26
 .int27 : {} > INT27
 .int28 : {} > INT28
 .int29 : {} > INT29
 .int30 : {} > INT30
 .int31 : {} > INT31
 .int32 : {} > INT32
 .int33 : {} > INT33
 .int34 : {} > INT34
 .int35 : {} > INT35
 .int36 : {} > INT36
 .int37 : {} > INT37
 .int38 : {} > INT38
 .int39 : {} > INT39
 .int40 : {} > INT40
 .int41 : {} > INT41
 .int42 : {} > INT42
 .int43 : {} > INT43
 .int44 : {} > INT44
 .int45 : {} > INT45
 .int46 : {} > INT46
 .int47 : {} > INT47
 .int48 : {} > INT48
 .int49 : {} > INT49
 .int50 : {} > INT50
 .int51 : {} > INT51
 .int52 : {} > INT52
 .int53 : {} > INT53
 .int54 : {} > INT54
 .int55 : {} > INT55
 .int56 : {} > INT56
 .int57 : {} > INT57
 .int58 : {} > INT58
 .int59 : {} > INT59
 .int60 : {} > INT60
 .int61 : {} > INT61
 .int62 : {} > INT62
 .reset : {} > RESET /* MSP430 RESET VECTOR */
/* INCLUDE PERIPHERALS MEMORY MAP */
-l cc430f6137.cmd
Thanks and regards,
JAGAS EDARA.
