Other Parts Discussed in Thread: SIMPLICITI
Hey guys i have adopted the sports watch code and peer to peer example to communicate with two watches ,there are no compilation errors but the SMPL_init() never intialises ... can you help..... i have pasted the complete code the first part is the link device and the later is the listening device...
// Copyright (C) 2009 Texas Instruments Incorporated - http://www.ti.com/
// Redistribution and use in source and binary forms, with or without
// modification, are permitted provided that the following conditions
// are met:
// Redistributions of source code must retain the above copyright
// notice, this list of conditions and the following disclaimer.
// Redistributions in binary form must reproduce the above copyright
// notice, this list of conditions and the following disclaimer in the
// documentation and/or other materials provided with the
// distribution.
// Neither the name of Texas Instruments Incorporated nor the names of
// its contributors may be used to endorse or promote products derived
// from this software without specific prior written permission.
// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
// "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
// LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
// OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
// SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
// LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
// DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
// THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
// (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
// OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
// eZ430-Chronos
// Description: This is the standard software for the eZ430-Chronos
// P.Francisco
// Version 1.6
// Texas Instruments, Inc
// November 2010
// Known working builds:
// IAR Embedded Workbench (Version: 5.10.4)
// Code Composer Studio (Version 4.2.0.10012)
//Change Log (More detailed information can be found in change_record.txt):
//Version: 1.6
//Comments: Several bugs were fixed.
// LCD shows "done" after successfully received data
// rfBSL requires two button presses in order to update watch
// New method detects a long button press
// Removed file display1.c. The content is now in display.c
// Backlight of Chronos stays on for 3 sec after backlight button was pushed.
// After timeout the accelerometer menu shows "----"
//Version: 1.5
//Comments: Changed XT1 drive level to highest
// Modified key lock procedure.
// Negative °C are now converted correctly to Kelvin
// Enabled fast mode when changing altitude offset
// Disabled stopwatch stop when watch buttons are locked
// Added SimpliciTI sources to project. Upgraded to Version 1.1.1.
// Changed button names from M1/M2/S1/S2/BL to STAR/NUM/UP/DOWN/BACKLIGHT
//Version: 1.4
//Comments: Initial Release Version
// Defines section
#define TIMEOUT (10u)
// Conversion from msec to ACLK timer ticks
#define CONV_MS_TO_TICKS(msec) (((msec) * 32768) / 1000)
// U16
typedef unsigned short u16;
// Initialization and control of application.
// Include section
// system
#include "project.h"
#include <string.h>
// driver
#include "clock.h"
#include "display.h"
#include "vti_as.h"
#include "vti_ps.h"
#include "radio.h"
#include "buzzer.h"
#include "ports.h"
#include "timer.h"
#include "pmm.h"
#include "rf1a.h"
//simpli
#include "bsp.h"
#include "mrfi.h"
#include "nwk_types.h"
#include "nwk_api.h"
#include "bsp_leds.h"
#include "bsp_buttons.h"
#include "simpliciti.h"
// logic
#include "menu.h"
#include "date.h"
#include "alarm.h"
#include "stopwatch.h"
#include "battery.h"
#include "temperature.h"
#include "altitude.h"
#include "acceleration.h"
#include "bluerobin.h"
#include "rfsimpliciti.h"
#include "rfbsl.h"
#include "test.h"
#include "bsp.h"
// Prototypes section
static void linkTo(void);
void init_application(void);
void init_global_variables(void);
void wakeup_event(void);
void process_requests(void);
void display_update(void);
void idle_loop(void);
void configure_ports(void);
void read_calibration_values(void);
static uint8_t sTxTid=0, sRxTid=0;
// Defines section
// Number of calibration data bytes in INFOA memory
#define CALIBRATION_DATA_LENGTH (13u)
#define SPIN_ABOUT_A_SECOND NWK_DELAY(100)
// Global Variable section
// Variable holding system internal flags
volatile s_system_flags sys;
static linkID_t sLinkID1;
static uint8_t sRxCallback(linkID_t);
static void linkTo();
static linkID_t sLinkID1 = 0;
static volatile uint8_t sSemaphore = 0;
// Variable holding flags set by logic modules
volatile s_request_flags request;
// Variable holding message flags
volatile s_message_flags message;
// Global radio frequency offset taken from calibration memory
// Compensates crystal deviation from 26MHz nominal value
u8 rf_frequoffset;
// Function pointers for LINE1 and LINE2 display function
void (*fptr_lcd_function_line1)(u8 line, u8 update);
void (*fptr_lcd_function_line2)(u8 line, u8 update);
// Extern section
extern void start_simpliciti_sync(void);
extern u16 ps_read_register(u8 address, u8 mode);
extern u8 ps_write_register(u8 address, u8 data);
// @fn main
// @brief Main routine
// @param none
// @return none
int main(void)
// Init MCU
init_application();
// Assign initial value to global variables
init_global_variables();
// Branch to welcome screen
// test_mode();
// Main control loop: wait in low power mode until some event needs to be processed
// while (1)
// When idle go to LPM3
// idle_loop();
// Process wake-up events
// if (button.all_flags || sys.all_flags)
// wakeup_event();
// Process actions requested by logic modules
// if (request.all_flags)
// process_requests();
// Before going to LPM3, update display
// if (display.all_flags)
// display_update();
#ifdef I_WANT_TO_CHANGE_DEFAULT_ROM_DEVICE_ADDRESS_PSEUDO_CODE
addr_t lAddr;
createRandomAddress(&lAddr);
SMPL_Ioctl(IOCTL_OBJ_ADDR, IOCTL_ACT_SET, &lAddr);
#endif /* I_WANT_TO_CHANGE_DEFAULT_ROM_DEVICE_ADDRESS_PSEUDO_CODE */
/* This call will fail because the join will fail since there is no Access Point
* in this scenario. But we don't care -- just use the default link token later.
* We supply a callback pointer to handle the message returned by the peer.
while (SMPL_SUCCESS != SMPL_Init(0))
NWK_DELAY(1000);
// Service watchdog
WDTCTL = WDTPW + WDTIS__512K + WDTSSEL__ACLK + WDTCNTCL;
// Stop connecting after defined numbers of seconds (15)
// if (timeout++ > TIMEOUT)
display_symbol(LCD_ICON_BEEPER3,SEG_ON_BLINK_ON);
// Clean up SimpliciTI stack to enable restarting
// sInit_done = 0;
// simpliciti_flag = SIMPLICITI_STATUS_ERROR;
// return (0);
NWK_DELAY(200);
int i,j;
for(i=6;--i>=0;){
for(j=1;j<=3;j++){
display_symbol(LCD_ICON_BEEPER3,SEG_ON_BLINK_OFF);
NWK_DELAY(20) ;
linkTo();
while(1);
uint8_t msg[2], delay = 0;
while (SMPL_SUCCESS != SMPL_Link(&sLinkID1))
/* blink LEDs until we link successfully */
display_symbol(LCD_ICON_HEART,SEG_ON_BLINK_ON);
display_symbol(LCD_ICON_BEEPER1,SEG_ON_BLINK_ON);
NWK_DELAY(100);// SPIN_ABOUT_A_SECOND;
/* we're linked. turn off red LED. received messages will toggle the green LED. */
display_symbol(LCD_ICON_ALARM,SEG_ON_BLINK_ON);
/* turn on RX. default is RX off. */
SMPL_Ioctl( IOCTL_OBJ_RADIO, IOCTL_ACT_RADIO_RXON, 0);
/* put LED to toggle in the message */
msg[0] = 1; /* toggle red */
while (1)
if (delay > 0x00)
if (delay > 0x01)
if (delay > 0x02)
/* delay longer and longer -- then start over */
delay = (delay+1) & 0x03;
/* put the sequence ID in the message */
msg[1] = ++sTxTid;
SMPL_Send(sLinkID1, msg, sizeof(msg));
/* handle received frames. */
static uint8_t sRxCallback(linkID_t port)
uint8_t msg[2], len, tid;
/* is the callback for the link ID we want to handle? */
if (port == sLinkID1)
/* yes. go get the frame. we know this call will succeed. */
if ((SMPL_SUCCESS == SMPL_Receive(sLinkID1, msg, &len)) && len)
/* Check the application sequence number to detect
* late or missing frames...
tid = *(msg+1);
if (tid)
if (tid > sRxTid)
/* we're good. toggle LED in the message */
if(*msg==2)
display_symbol(LCD_ICON_ALARM, SEG_ON_BLINK_ON);
sRxTid = tid;
else
/* the wrap case... */
if (sRxTid)
if(*msg==1)
sRxTid = tid;
/* drop frame. we're done with it. */
return 1;
/* keep frame for later handling. */
return 0;
// @fn init_application
// @brief Initialize the microcontroller.
// @param none
// @return none
volatile unsigned char *ptr;
// Enable watchdog
// Watchdog triggers after 16 seconds when not cleared
#ifdef USE_WATCHDOG
WDTCTL = WDTPW + WDTIS__512K + WDTSSEL__ACLK;
#else
WDTCTL = WDTPW + WDTHOLD;
#endif
// Configure PMM
SetVCore(3);
// Set global high power request enable
PMMCTL0_H = 0xA5;
PMMCTL0_L |= PMMHPMRE;
PMMCTL0_H = 0x00;
// Enable 32kHz ACLK
P5SEL |= 0x03; // Select XIN, XOUT on P5.0 and P5.1
UCSCTL6 &= ~XT1OFF; // XT1 On, Highest drive strength
UCSCTL6 |= XCAP_3; // Internal load cap
UCSCTL3 = SELA__XT1CLK; // Select XT1 as FLL reference
UCSCTL4 = SELA__XT1CLK | SELS__DCOCLKDIV | SELM__DCOCLKDIV;
// Configure CPU clock for 12MHz
_BIS_SR(SCG0); // Disable the FLL control loop
UCSCTL0 = 0x0000; // Set lowest possible DCOx, MODx
UCSCTL1 = DCORSEL_5; // Select suitable range
UCSCTL2 = FLLD_1 + 0x16E; // Set DCO Multiplier
_BIC_SR(SCG0); // Enable the FLL control loop
// Worst-case settling time for the DCO when the DCO range bits have been
// changed is n x 32 x 32 x f_MCLK / f_FLL_reference. See UCS chapter in 5xx
// UG for optimization.
// 32 x 32 x 12 MHz / 32,768 Hz = 375000 = MCLK cycles for DCO to settle
__delay_cycles(375000);
// Loop until XT1 & DCO stabilizes, use do-while to insure that
// body is executed at least once
do
UCSCTL7 &= ~(XT2OFFG + XT1LFOFFG + XT1HFOFFG + DCOFFG);
SFRIFG1 &= ~OFIFG; // Clear fault flags
while ((SFRIFG1 & OFIFG));
// Configure port mapping
// Disable all interrupts
__disable_interrupt();
// Get write-access to port mapping registers:
PMAPPWD = 0x02D52;
// Allow reconfiguration during runtime:
PMAPCTL = PMAPRECFG;
// P2.7 = TA0CCR1A or TA1CCR0A output (buzzer output)
ptr = &P2MAP0;
*(ptr + 7) = PM_TA1CCR0A;
P2OUT &= ~BIT7;
P2DIR |= BIT7;
// P1.5 = SPI MISO input
ptr = &P1MAP0;
*(ptr + 5) = PM_UCA0SOMI;
// P1.6 = SPI MOSI output
*(ptr + 6) = PM_UCA0SIMO;
// P1.7 = SPI CLK output
*(ptr + 7) = PM_UCA0CLK;
// Disable write-access to port mapping registers:
PMAPPWD = 0;
// Re-enable all interrupts
__enable_interrupt();
// Configure ports
// Reset radio core
radio_reset();
radio_powerdown();
// Init acceleration sensor
as_init();
// Init LCD
lcd_init();
// Init buttons
init_buttons();
// Configure Timer0 for use by the clock and delay functions
Timer0_Init();
// Init pressure sensor
ps_init();
BSP_InitBoard();
// @fn init_global_variables
// @brief Initialize global variables.
// @param none
// @return none
// Apply default settings
// set menu pointers to default menu items
ptrMenu_L1 = &menu_L1_Time;
// ptrMenu_L1 = &menu_L1_Alarm;
// ptrMenu_L1 = &menu_L1_Heartrate;
// ptrMenu_L1 = &menu_L1_Speed;
// ptrMenu_L1 = &menu_L1_Temperature;
// ptrMenu_L1 = &menu_L1_Altitude;
// ptrMenu_L1 = &menu_L1_Acceleration;
ptrMenu_L2 = &menu_L2_Date;
// ptrMenu_L2 = &menu_L2_Stopwatch;
// ptrMenu_L2 = &menu_L2_Rf;
// ptrMenu_L2 = &menu_L2_Ppt;
// ptrMenu_L2 = &menu_L2_Sync;
// ptrMenu_L2 = &menu_L2_Distance;
// ptrMenu_L2 = &menu_L2_Calories;
// ptrMenu_L2 = &menu_L2_Battery;
// ptrMenu_L2 = &menu_L2_RFBSL;
// Assign LINE1 and LINE2 display functions
fptr_lcd_function_line1 = ptrMenu_L1->display_function;
fptr_lcd_function_line2 = ptrMenu_L2->display_function;
// Init system flags
button.all_flags = 0;
sys.all_flags = 0;
request.all_flags = 0;
display.all_flags = 0;
message.all_flags = 0;
// Force full display update when starting up
display.flag.full_update = 1;
#ifndef ISM_US
// Use metric units when displaying values
sys.flag.use_metric_units = 1;
#endif
// Read calibration values from info memory
read_calibration_values();
// Set system time to default value
reset_clock();
// Set date to default value
reset_date();
// Set alarm time to default value
reset_alarm();
// Set buzzer to default value
reset_buzzer();
// Reset stopwatch
reset_stopwatch();
// Reset altitude measurement
reset_altitude_measurement();
// Reset acceleration measurement
reset_acceleration();
// Reset BlueRobin stack
reset_bluerobin();
// Reset SimpliciTI stack
reset_rf();
// Reset temperature measurement
reset_temp_measurement();
// Reset battery measurement
reset_batt_measurement();
battery_measurement();
// @fn wakeup_event
// @brief Process external / internal wakeup events.
// @param none
// @return none
// Enable idle timeout
sys.flag.idle_timeout_enabled = 1;
// If buttons are locked, only display "buttons are locked" message
if (button.all_flags && sys.flag.lock_buttons)
// Show "buttons are locked" message synchronously with next second tick
if (!(BUTTON_NUM_IS_PRESSED && BUTTON_DOWN_IS_PRESSED))
message.flag.prepare = 1;
message.flag.type_locked = 1;
// Clear buttons
// Process long button press event (while button is held)
else if (button.flag.star_long)
// Clear button event
button.flag.star_long = 0;
display_symbol(LCD_ICON_BEEPER1, SEG_ON_BLINK_OFF);
// Call sub menu function
ptrMenu_L1->mx_function(LINE1);
// Set display update flag
else if (button.flag.num_long)
button.flag.num_long = 0;
ptrMenu_L2->mx_function(LINE2);
// Process single button press event (after button was released)
else if (button.all_flags)
// M1 button event ---------------------------------------------------------------------
// (Short) Advance to next menu item
if (button.flag.star)
// Clean up display before activating next menu item
fptr_lcd_function_line1(LINE1, DISPLAY_LINE_CLEAR);
// Go to next menu entry
ptrMenu_L1 = ptrMenu_L1->next;
// Assign new display function
// Set Line1 display update flag
display.flag.line1_full_update = 1;
// Clear button flag
button.flag.star = 0;
// NUM button event ---------------------------------------------------------------------
else if (button.flag.num)
// Clear rfBSL confirmation flag
rfBSL_button_confirmation = 0;
fptr_lcd_function_line2(LINE2, DISPLAY_LINE_CLEAR);
ptrMenu_L2 = ptrMenu_L2->next;
// Set Line2 display update flag
display.flag.line2_full_update = 1;
button.flag.num = 0;
// UP button event ---------------------------------------------------------------------
// Activate user function for Line1 menu item
else if (button.flag.up)
// Call direct function
ptrMenu_L1->sx_function(LINE1);
button.flag.up = 0;
// DOWN button event ---------------------------------------------------------------------
// Activate user function for Line2 menu item
else if (button.flag.down)
if (ptrMenu_L2 == &menu_L2_RFBSL)
ptrMenu_L2->sx_function(LINE2);
button.flag.down = 0;
// Process internal events
if (sys.all_flags)
// Idle timeout ---------------------------------------------------------------------
if (sys.flag.idle_timeout)
// Clear timeout flag
sys.flag.idle_timeout = 0;
// Clear display
clear_display();
// Set display update flags
// Disable idle timeout
sys.flag.idle_timeout_enabled = 0;
// @fn process_requests
// @brief Process requested actions outside ISR context.
// @param none
// @return none
// Do temperature measurement
if (request.flag.temperature_measurement)
temperature_measurement(FILTER_ON);
// Do pressure measurement
if (request.flag.altitude_measurement)
do_altitude_measurement(FILTER_ON);
// Do acceleration measurement
if (request.flag.acceleration_measurement)
do_acceleration_measurement();
// Do voltage measurement
if (request.flag.voltage_measurement)
// Generate alarm (two signals every second)
if (request.flag.buzzer)
start_buzzer(2, BUZZER_ON_TICKS, BUZZER_OFF_TICKS);
// Reset request flag
// @fn display_update
// @brief Process display flags and call LCD update routines.
// @param none
// @return none
u8 line;
u8 string[8];
// Call Line1 display function
if (display.flag.full_update || display.flag.line1_full_update)
clear_line(LINE1);
fptr_lcd_function_line1(LINE1, DISPLAY_LINE_UPDATE_FULL);
} else if (ptrMenu_L1->display_update())
// Update line1 only when new data is available
fptr_lcd_function_line1(LINE1, DISPLAY_LINE_UPDATE_PARTIAL);
// If message text should be displayed on Line2, skip normal update
if (message.flag.show)
line = LINE2;
// Select message to display
if (message.flag.type_locked)
memcpy(string, " LO?T", 6);
else if (message.flag.type_unlocked)
memcpy(string, " OPEN", 6);
else if (message.flag.type_lobatt)
memcpy(string, "LOBATT", 6);
else if (message.flag.type_alarm_on)
memcpy(string, " ON", 4);
line = LINE1;
} else if (message.flag.type_alarm_off)
memcpy(string, " OFF", 4);
line = LINE1;
// Clear previous content
clear_line(line);
fptr_lcd_function_line2(line, DISPLAY_LINE_CLEAR);
if (line == LINE2)
display_chars(LCD_SEG_L2_5_0, string, SEG_ON);
else
display_chars(LCD_SEG_L1_3_0, string, SEG_ON);
// Next second tick erases message and repaints original screen content
message.flag.erase = 1;
// Call Line2 display function
else if (display.flag.full_update || display.flag.line2_full_update)
clear_line(LINE2);
fptr_lcd_function_line2(LINE2, DISPLAY_LINE_UPDATE_FULL);
} else if (ptrMenu_L2->display_update() && !message.all_flags)
// Update line2 only when new data is available
fptr_lcd_function_line2(LINE2, DISPLAY_LINE_UPDATE_PARTIAL);
// Restore blinking icons (blinking memory is cleared when calling set_value)
if (display.flag.full_update)
if (is_bluerobin() == BLUEROBIN_CONNECTED)
// Turn on beeper icon to show activity
display_symbol(LCD_ICON_BEEPER2, SEG_ON_BLINK_OFF);
display_symbol(LCD_ICON_BEEPER3, SEG_ON_BLINK_OFF);
// Clear display flag
// @fn to_lpm
// @brief Go to LPM0/3.
// @param none
// @return none
void to_lpm(void)
// Go to LPM3
_BIS_SR(LPM3_bits + GIE);
__no_operation();
// @fn idle_loop
// @brief Go to LPM. Service watchdog timer when waking up.
// @param none
// @return none
// To low power mode
to_lpm();
#ifdef USE_WATCHDOG
// Service watchdog
#endif
// @fn read_calibration_values
// @brief Read calibration values for temperature measurement, voltage measurement
// and radio from INFO memory.
// @param none
// @return none
u8 cal_data[CALIBRATION_DATA_LENGTH]; // Temporary storage for constants
u8 i;
u8 *flash_mem; // Memory pointer
// Read calibration data from Info D memory
flash_mem = (u8 *) 0x1800;
for (i = 0; i < CALIBRATION_DATA_LENGTH; i++)
cal_data[i] = *flash_mem++;
if (cal_data[0] == 0xFF)
// If no values are available (i.e. INFO D memory has been erased by user), assign
// experimentally derived values
rf_frequoffset = 4;
sTemp.offset = -250;
sBatt.offset = -10;
simpliciti_ed_address[0] = 0x79;
simpliciti_ed_address[1] = 0x56;
simpliciti_ed_address[2] = 0x34;
simpliciti_ed_address[3] = 0x12;
sAlt.altitude_offset = 0;
} else
// Assign calibration data to global variables
rf_frequoffset = cal_data[1];
// Range check for calibrated FREQEST value (-20 .. + 20 is ok, else use default value)
if ((rf_frequoffset > 20) && (rf_frequoffset < (256 - 20)))
rf_frequoffset = 0;
sTemp.offset = (s16) ((cal_data[2] << 8) + cal_data[3]);
sBatt.offset = (s16) ((cal_data[4] << 8) + cal_data[5]);
simpliciti_ed_address[0] = cal_data[6];
simpliciti_ed_address[1] = cal_data[7];
simpliciti_ed_address[2] = cal_data[8];
simpliciti_ed_address[3] = cal_data[9];
// S/W version byte set during calibration?
if (cal_data[12] != 0xFF)
sAlt.altitude_offset = (s16) ((cal_data[10] << 8) + cal_data[11]);
} else
THE CODE FOR THE LISTENING MOTE
// are met:
// distribution.
// eZ430-Chronos
// P.Francisco
// Version 1.6
// November 2010
//Version: 1.6
//Version: 1.5
//Version: 1.4
// Defines section
// U16
// Include section
// system
#include <string.h>
// driver
#include "clock.h"
#include "vti_as.h"
#include "vti_ps.h"
#include "radio.h"
#include "buzzer.h"
#include "ports.h"
#include "timer.h"
#include "pmm.h"
#include "rf1a.h"
//simpli
#include "bsp.h"
#include "mrfi.h"
// logic
#include "menu.h"
#include "date.h"
#include "alarm.h"
#include "rfbsl.h"
#include "test.h"
#include "bsp.h"
static void linkFrom(void);
static uint8_t sRxTid=0;
// Defines section
#define SPIN_ABOUT_A_SECOND NWK_DELAY(1000)
static linkID_t sLinkID2;
//static void linkTo();
static linkID_t sLinkID2 = 0;
u8 rf_frequoffset;
// Extern section
// @fn main
// @param none
// @return none
int main(void)
// Init MCU
init_application();
// test_mode();
// start_buzzer(2, BUZZER_ON_TICKS, BUZZER_OFF_TICKS);
// while (1)
// idle_loop();
// wakeup_event();
//if (request.all_flags)
addr_t lAddr;
NWK_DELAY(1000);
display_symbol(LCD_ICON_BEEPER1, SEG_ON_BLINK_ON);
// Service watchdog
// sInit_done = 0;
// return (0);
/* turn on LEDs. */
NWK_DELAY(500);
NWK_DELAY(100);
display_symbol(LCD_ICON_HEART, SEG_ON_BLINK_OFF);
/* wait for a button press... */
//do {
//while(1){
// if (BUTTON_NUM_IS_PRESSED)
// display_symbol(LCD_ICON_ALARM, SEG_ON_BLINK_ON);
//while(1)
// break;
/* never coming back... */
linkFrom();
/* but in case we do... */
while (1) ;
static void linkFrom()
uint8_t msg[2], tid = 0;
/* Turn off one LED so we can tell the device is now listening.
* Received messages will toggle the other LED.
/* listen for link forever... */
while (1)
if (SMPL_SUCCESS == SMPL_LinkListen(&sLinkID2))
break;
/* Implement fail-to-link policy here. otherwise, listen again. */
/* turn on LED1 on the peer in response to receiving a frame. */
*msg = 0x01;
while (1)
/* Wait for a frame to be received. The Rx handler, which is running in
* ISR thread, will post to this semaphore allowing the application to
* send the reply message in the user thread.
if (sSemaphore)
*(msg+1) = ++tid;
SMPL_Send(sLinkID2, msg, 2);
/* Reset semaphore. This is not properly protected and there is a race
* here. In theory we could miss a message. Good enough for a demo, though.
sSemaphore = 0;
/* handle received messages */
if (port == sLinkID2)
if ((SMPL_SUCCESS == SMPL_Receive(sLinkID2, msg, &len)) && len)
tid = *(msg+1);
if (tid)
if (tid > sRxTid)
/* we're good. toggle LED */
if(*msg==1)
sRxTid = tid;
else
/* wrap case... */
if (sRxTid)
sRxTid = tid;
/* Post to the semaphore to let application know so it sends
* the reply
sSemaphore = 1;
return 1;
/* keep frame for later handling */
return 0;
// @param none
// @return none
// Enable watchdog
#ifdef USE_WATCHDOG
#else
#endif
// Configure PMM
SetVCore(3);
PMMCTL0_H = 0xA5;
PMMCTL0_H = 0x00;
do
PMAPPWD = 0x02D52;
ptr = &P2MAP0;
P2OUT &= ~BIT7;
P2DIR |= BIT7;
ptr = &P1MAP0;
PMAPPWD = 0;
// Configure ports
// Reset radio core
radio_reset();
radio_powerdown();
as_init();
// Init LCD
lcd_init();
// Init buttons
init_buttons();
Timer0_Init();
ps_init();
BSP_InitBoard();
// @param none
// @return none
sys.all_flags = 0;
#ifndef ISM_US
#endif
reset_clock();
reset_date();
reset_alarm();
reset_buzzer();
// Reset stopwatch
reset_stopwatch();
reset_bluerobin();
reset_rf();
// @fn wakeup_event
// @param none
// @return none
// Clear buttons
button.flag.up = 0;
if (sys.all_flags)
// Clear display
clear_display();
// @param none
// @return none
// @param none
// @return none
u8 line;
u8 string[8];
clear_line(LINE1);
line = LINE2;
line = LINE1;
line = LINE1;
clear_line(line);
if (line == LINE2)
else
clear_line(LINE2);
// @fn to_lpm
// @param none
// @return none
void to_lpm(void)
// Go to LPM3
__no_operation();
// @fn idle_loop
// @param none
// @return none
to_lpm();
#ifdef USE_WATCHDOG
// Service watchdog
#endif
// @param none
// @return none
u8 i;
rf_frequoffset = 4;
sBatt.offset = -10;
} else
rf_frequoffset = 0;
} else
