How do I use the BSL-Scripter on Windows 10 to do a simple TX_BSL_VERSION so I can see the BSL invoke sequence on TEST/RST and capture a command/response?
-Mike
Hi Mike
Please check Bootloader (BSL) Scripter User's Guide (Rev. G) as the reference
There is 4.1 Invoke Sequence chaptor on this document.
Thanks!
Hi Mike
If you need capture the BSL invoke sequence on TEST/RST, could you please kindly explain your solution in detailed?
I was able to use Uniflash to generate what I needed. Turns out my issue was to use even parity in the data.
Hi Mike
Thanks for your feedback!
if there is no more issue now, Please press "resolved" button.
