Part Number: MSP430FR4133
Other Parts Discussed in Thread: MSP430G2553
Hi I have found a library that used the MSP430G2553 to connect the an ILI9341 SPI display. I have made some adjustments to the pins to configure it for my MSP430FR4133 but I cannot seem to get it working. I have a feeling that it is to do with the interrupt in the ILI9341_SPI_init function, but from looking at the datasheet and user guide I cannot seem to figure out if I am doing this correctly. I have attached my code; any help will be appreciated.
#include <msp430.h>
#include <driverlib.h>
#include <stdint.h>
#include "ili9341.h"
void main(void)
WDTCTL = WDTPW + WDTHOLD;
PMM_unlockLPM5();
PMM_unlockLPM5();
__bis_SR_register(GIE); // makes timer interrupts work unsure why
ILI9341_SPI_init(); // init. USCI (SPI)
ILI9341_Init(ILI9341_RED); // init. Display
__enable_interrupt(); // enable global interrupts
while(1)
__delay_cycles(DELAY_10ms);
ILI9341_GraphDemo();
}#include "ili9341.h"
#include "ascii.h"
// ILI9341_SPI_init()
// Initialisiert SPI-UCB0 des Mikrocontrollers MSP430G2553. Beachte der MSP430G2553 besitzt zusätzlich den UCA0 für SPI.
void ILI9341_SPI_init(void)
P5DIR &=~ ILI9341_MOSI + ILI9341_SCK;
P5SEL0 |= ILI9341_MOSI + ILI9341_SCK; // SCK, MOSI
P1DIR |= ILI9341_RST; // RST
P8DIR |= ILI9341_CS; // CS
P5DIR |= ILI9341_DC; // DC
P1OUT &=~ ILI9341_RST;
P8OUT &=~ ILI9341_CS;
P5OUT &=~ ILI9341_DC;
// SPI settings
UCB0CTL1 |= UCSWRST; // Reset
UCB0CTL0 |= UCMST + UCSYNC + UCCKPH + UCMSB; // 3-pin, 8-bit SPI master
UCB0CTL1 |= UCSSEL_2; // SMCLK
UCB0CTL1 &=~ UCSWRST; // USCI released for operation
__delay_cycles(DELAY_100ms); // Wait 100ms
while (!(UCTXIFG0 & UCB0IFG)); // Wait until transmission is complete
UCB0TXBUF = 0x00; // Send dummy
// ILI9341_SPI_transmit()
// Senden und Empfangen über SPI-UCB0.
// Variablen
// @ data : Unsigned 8-Bit-Datensatz der über UCB0 via SPI gesendet werden soll
// @ return : Unsigned 8-Bit-Datensatz der über UCB0 via SPI empfangen wird
unsigned char ILI9341_SPI_transmit(unsigned char data)
UCB0TXBUF = data; // Sende Datensatz
while(UCB0STAT & UCBUSY); // Warte bist übermittelt
return UCB0RXBUF; // Gebe empfangenen Datensatz zurück
// ILI9341_SendComand()
// Sende dem ILI9341 einen Befehl über SPI-UCB0.
// Variablen
// @ cmd : Unsigned 8-Bit-Befehl der über UCB0 via SPI gesendet werden soll
void ILI9341_SendComand(uint8_t cmd)
P5OUT &=~ ILI9341_DC; // Signalisiere das ein Befehl gesendet wird. ...
P8OUT &=~ ILI9341_CS; // Starte Frame in dem ich !CS auf Low Ziehe. Sende ...
ILI9341_SPI_transmit(cmd); // sende Befehl ...
P8OUT |= ILI9341_CS; // Beende den Frame in dem ich !CS wieder auf High setze.-
// ILI9341_SendData8()
// Sende dem ILI9341 einen 8-Bit-Datensatz über SPI-UCB0.
// Variablen
// @ data : Unsigned 8-Bit-Daten der über UCB0 via SPI gesendet werden soll
void ILI9341_SendData8(uint8_t data)
P5OUT |= ILI9341_DC; // Signalisiere das ein Daten gesendet werden. ...
ILI9341_SPI_transmit(data); // sende Daten ...
// ILI9341_SendData16()
// Sende dem ILI9341 einen 16-Bit-Datensatz über SPI-UCB0.
// Variablen
// @ data : Unsigned 16-Bit-Daten der über UCB0 via SPI gesendet werden soll
void ILI9341_SendData16(uint16_t data)
ILI9341_SPI_transmit(data >> 8); // Sende Low und High byte über SPI ...
ILI9341_SPI_transmit(data & 0xff); // .-
// ILI9341_SendPackage()
// Sende dem ILI9341 eine Packet aud Daten (Array).
// Variablen
// @ data : Unsigned 16-Bit-Daten-Array der über UCB0 via SPI gesendet werden soll
// @ data : Anzahl der Daten des Arrays die gesendet werden sollen
void ILI9341_SendPackage(uint16_t *data, uint8_t howmany)
uint8_t count=0; // Zähler
for(count=0; count < howmany; count++) // Sänder alle Daten aus Array
ILI9341_SPI_transmit(data[count]>>8); // Sende Low und High byte über SPI ...
ILI9341_SPI_transmit(data[count]&0xff); // .-
} // for
// ILI9341_Init()
// Initialisiert das Display. Beachte SPI sollte schon vorher initialisiert sein.
// Für die LCD-Initialisierung: * Resete LCD
// * Sende Startsequenz zum LCD
// * Verlasse Standby und stelle Farbe ein
// * Stelle die Ausrichtung vom Display (portrait, landscape, ...)
// Variablen
// @ color : Farbauswahl siehe #defines in der ili9341.h
void ILI9341_Init(uint16_t color)
uint8_t byte = 0, bit_num = 0, h_index = 0, w_index = 0; // Schleifen-Zähler für Daten/Befehls-Arrays
// 1. LCD Reset
for(char i = 0; i < 3; i++) // Reset-Sequenz für das Display. Beachte i muss ungerade Zahl sein. ...
{ // Ohne Sequenz funktioniert LCD nicht (schon getestet). ...
P1OUT ^= ILI9341_RST; // RST-Pin Toggeln ...
__delay_cycles(DELAY_1ms); // Warte 1ms.-
} // for
// 2. Schalte nun die Startsequenz für das Display an
const uint8_t init_cmd[]={0xCB,0xCF,0xE8,0xEA,0xED,0xF7,0xC0,0xC1,0xC5,0xC7, // Befehls-Array ...
0x36,0x3A,0xB1,0xB6,0xF2,0x26,0xE0,0xE1}; // .-
const uint8_t init_data[]={0x39,0x2C,0x00,0x34,0x02,0x00,0xC1,0x30,0x85,0x00, // Daten-Array ...
0x78,0x00,0x00,0x64,0x03,0x12,0x81,0x20,0x23,0x10, // ...
0x3E,0x28,0x86,0x88,0x55,0x00,0x18,0x08,0x82,0x27, // ...
0x00,0x01,0x0F,0x31,0x2B,0x0C,0x0E,0x08,0x4E,0xF1, // ...
0x37,0x07,0x10,0x03,0x0E,0x09,0x00,0x00,0x0E,0x14, // ...
0x03,0x11,0x07,0x31,0xC1,0x48,0x08,0x0F,0x0C,0x31, // ...
0x36,0x0F}; // .-
const uint8_t init_data_count[]={5,3,3,2,4,1,1,1,2,1,1,1,2,3,1,1,15,15};
while(byte < sizeof(init_cmd)) // Für byte < 18 (= Länge vom Array)
ILI9341_SendComand(init_cmd[byte++]); // Schreibe-Befehl im Register ...
while(h_index < init_data_count[bit_num]) // h_index für Größe von init_data Befels-Zähler ...
{ // bit_num für init_data_count Zähler ...
ILI9341_SendData8(init_data[w_index++]); // w_index für init_data Zähler ...
h_index++; // ...
} // while
bit_num++; // ...
h_index = 0; // ..-
} // while
// 3. Komme aus dem Standby (Sleep-Mode -> Siehe auch §8.2.12, ILI9341-Datenblatt, Seite 101)
ILI9341_SendComand(ILI9341_SLPOUT); // Komme aus den Sleep-Out ...
__delay_cycles(2 * DELAY_100ms); // warte mindestens 120ms (sehe description Seite 101).-
ILI9341_FillScreen(color); // Befülle das ganze Display mit der gewünschten Farbe
ILI9341_SendComand(ILI9341_DISPON); // Mache Dsiplay an
ILI9341_SendComand(ILI9341_RAMWR); // Schreibe-Befehl im Memory Register
ILI9341_Orientation(LCD_ORIENTATION); // Setze Orientations des Display (Portrait oder Landscape)
// ILI9341_Orientation()
// Stellt die Ausrichtung vom Display (portrait, landscape, ...). Siehe dazu auch ili9341.h das #define LCD_ORIENTATION. Default ist 0°.
// Siehe auch §8.2.29, ILI9341-Datenblatt, Seite 127.
// Variablen
// @ deg : Ausrichtung vom Display <<LCD_ORIENTATION>> (siehe auch #defines in ili9341.h)
void ILI9341_Orientation (int deg)
unsigned dat = 0; // Variable zum Beschreiben der Adresse MADCTL vom ILI9341
switch(deg) // Anhand der erwünschen Ausrichtung, stelle MEM_X, MEM_Y, MEM_V, MEM_L und MEM_BGR. ...
{ // Siehe auch Tabelle auf Seite 127. ...
case 0: // ...
dat = (1 << MEM_X) | (1 << MEM_BGR); // ...
break; // ...
} // case // ...
case 90: // ...
dat = (0<<MEM_Y) | (0<<MEM_X) | (1<<MEM_V) | (0<<MEM_L) | (1<<MEM_BGR); // ...
break; // ...
} // case // ...
case 180: // ...
dat = (1 << MEM_Y) | (1 << MEM_BGR); // ...
break; // ...
} // case // ...
case 270: // ...
dat = (1 << MEM_Y) | (1<<MEM_X) | (1<<MEM_V) | (1 << MEM_BGR); // ...
break; // ...
} // case // ...
default: // ...
} // default // .-
} // switch
ILI9341_SendComand (ILI9341_MADCTL); // Siehe auch Flow-Chart, Seite 128. Sende Befehl zuerst, dann ...
ILI9341_SendData8 (dat); // den Datensatz.-
// ILI9341_DisplayINV()
// Regelt das Inventieren der Farben des Displays.
// Variablen
// @ inv : Variable fürs Inventieren des Displays; TRUE für an - FALSE für aus
void ILI9341_DisplayINV(char inv)
if(inv == TRUE) ILI9341_SendComand (ILI9341_INVON); // Display-Farben inventieren
else ILI9341_SendComand (ILI9341_INVOFF); // Display-Farben NICHT inventieren
// ILI9341_DisplayONorOFF()
// Regelt das ein- oder auschalten des Displays.
// Variablen
// @ ONorOFF : Variable fürs ein- oder auschalten des Displays; TRUE für an - FALSE für aus
void ILI9341_DisplayONorOFF(char ONorOFF)
if(ONorOFF == TRUE) ILI9341_SendComand (ILI9341_DISPON); // Display Anschalten
else ILI9341_SendComand (ILI9341_DISPOFF); // Display Ausschalten
// ILI9341_SetX()
// Die Funktion sollte zusammen mit ILI9341_SetY() genutzt werden. Damit wird im RAM die Pixelposition der Y-Koordinate reserviert (siehe Datenblatt - Seite 110 und 111). Beachte Y
// sollte auch eingestellt werden. Beachte der Datensatz wird noch nicht mit dem ILI9341_RAMWR-Befehl abgeschlossen.
// Variablen
// @ x : X-Position aus kartesischen XY-Koordinatensystem
void ILI9341_SetX(uint16_t StartCol,uint16_t EndCol)
ILI9341_SendComand(ILI9341_CASET); // Befehl für die X-Koordinate, siehe Datenblatt - Seite 110 und 111
ILI9341_SendData16(StartCol); // Startwert
ILI9341_SendData16(EndCol); // Endwert (Beachte kein Abschließen durch ILI9341_RAMWR)
// ILI9341_SetY()
// Die Funktion sollte zusammen mit ILI9341_SetX() genutzt werden. Damit wird im RAM die Pixelposition der X-Koordinate reserviert (siehe Datenblatt - Seite 112 und 112). Beachte X
// Variablen
// @ y : Y-Position aus kartesischen XY-Koordinatensystem
void ILI9341_SetY(uint16_t StartPage,uint16_t EndPage)
ILI9341_SendComand(ILI9341_PASET); // Befehl für die Y-Koordinate, siehe Datenblatt - Seite 112 und 113
ILI9341_SendData16(StartPage); // Startwert
ILI9341_SendData16(EndPage); // Endwert (Beachte kein Abschließen durch ILI9341_RAMWR)
// ILI9341_SetXY()
// Stellt die X und Y-Koordinaten für das Pixel ein und schreibte es in der Memory (ILI9341_RAMWR). Beachte das Ergebnis ist nicht auf dem Display sichtbar, da noch die Farbe einge-
// stellt werden sollte.
// Variablen
void ILI9341_SetXY(uint16_t x, uint16_t y)
ILI9341_SetX(x, x); // Stelle X- und ...
ILI9341_SetY(y, y); // Y-Koordinate ...
ILI9341_SendComand(ILI9341_RAMWR); // Schreibe es im Memory des ILI9341.-
// ILI9341_SetPixel()
// Zeichnet dem Display einzelne Pixels ein.
// Variablen
// @ color : Farbe für das Pixels
void ILI9341_SetPixel(uint16_t poX, uint16_t poY,uint16_t color)
ILI9341_SetXY(poX, poY); // Wähle Pixel aus XY-Koordinatensystem
ILI9341_SendData16(color); // Sende erwünschte Farbe
// ILI9341_DrawPixel()
// Zeichnet dem Display einzelne Pixels ein (Funktion ist identisch mit ILI9341_SetPixel(), mache eine logische Trennung).
// Variablen
void ILI9341_DrawPixel(int16_t x, int16_t y, uint16_t color)
ILI9341_SetXY(x, y); // Wähle Pixel aus XY-Koordinatensystem
ILI9341_SendData16 (color); // Sende erwünschte Farbe
// ILI9341_DrawPixelXY()
// Zeichnet dem Display mehrere Pixels ein.
// Variablen
// @ sx : Breite für die X-Komponente einstellen
// @ sy : Breite für die Y-Komponente einstellen
void ILI9341_DrawPixelXY(int16_t x, int16_t y, uint8_t sx, uint8_t sy, uint16_t color)
if(sx || sy) ILI9341_FillRectangle(x, x + sx, y, y + sy, color); // Setze hiermit ganzen Bereich aus Pixel
else
ILI9341_SetX(x, x); // Setze einzelnt Y und ...
ILI9341_SetY(y, y); // Y-Koordinate.-
ILI9341_SendData16 (color); // Abschließend erwünschte Farbe senden
} // else
// ILI9341_DrawChar()
// Zeichnet ein einzelnes Zeichen auf ds Display.
// Variablen
// @ ascii : Nummer aus der ACII-Tabelle
// @ x : X-Position auf das Display
// @ y : Y-Position auf das Display
// @ size : Breite und Länge des Zeichens
// @ color : Farbe für das Zeichen
void ILI9341_DrawChar(uint8_t ascii, uint16_t x, uint16_t y,uint16_t size, uint16_t color)
if((ascii>=32)&&(ascii<=127)) ;
else
ascii = '?'-32;
} // else
for (int i =0; i<FONT_X; i++ )
uint8_t temp = simpleFont[ascii-0x20][i];
for(uint8_t f=0;f<8;f++)
if((temp>>f)&0x01)
ILI9341_FillRectangle(x+i*size, y+f*size, size, size, color);
} // if
} // for/f
} // for/i
// ILI9341_DrawString()
// Zeichnet ein string (Zeichen-Array) auf ds Display.
// Variablen
// @ string : String was auf das Display gezeichnet werden soll
void ILI9341_DrawString(char *string,uint16_t x, uint16_t y, uint16_t size,uint16_t color)
while(*string)
ILI9341_DrawChar(*string, x, y, size, color);
*string++;
if(x < MAX_X)
x += FONT_SPACE*size;
} // if
} // while
// ILI9341_DrawHLine()
// Zeichnet einne horizontale Linie ein.
// Variablen
// @ x : X-Position der Linie
// @ y : Y-Position der Linie
// @ length : Länge der Linie
// @ color : Farbe der Linie
void ILI9341_DrawHLine(uint16_t x, uint16_t y, uint16_t length,uint16_t color)
ILI9341_SetX(x,x + length);
ILI9341_SetY(y,y);
for(int i=0; i<length; i++) ILI9341_SendData16(color);
// ILI9341_DrawVLine()
// Zeichnet einne vertikale Linie ein.
// Variablen
void ILI9341_DrawVLine( uint16_t x, uint16_t y, uint16_t length,uint16_t color)
ILI9341_SetX(x,x);
ILI9341_SetY(y,y+length);
// ILI9341_DrawLine()
// Zeichnet einne Linie ein.
// Variablen
// @ x0 : X-Startposition der Linie
// @ y0 : Y-Startposition der Linie
// @ x1 : X-Endposition der Linie
// @ y2 : Y-Endposition der Linie
void ILI9341_DrawLine(uint16_t x0,uint16_t y0,uint16_t x1, uint16_t y1,uint16_t color)
int x = x1-x0;
int y = y1-y0;
int dx = abs(x), sx = x0<x1 ? 1 : -1;
int dy = -abs(y), sy = y0<y1 ? 1 : -1;
int err = dx+dy, e2; // error value e_xy
for (;;)
{ // loop
ILI9341_SetPixel(x0,y0,color);
e2 = 2*err;
if (e2 >= dy) { // e_xy+e_x > 0
if (x0 == x1) break;
err += dy; x0 += sx;
} // if
if (e2 <= dx) { // e_xy+e_y < 0
if (y0 == y1) break;
err += dx; y0 += sy;
} // if
} // for
// ILI9341_DrawRectangle()
// Zeichnet ein Rechteck auf das Display ein.
// Variablen
// @ length : Länge des Rechtecks
// @ width : Breite des Rechtecks
// @ color : Farbe des Rechtecks
void ILI9341_DrawRectangle(uint16_t x, uint16_t y, uint16_t length, uint16_t width,uint16_t color)
ILI9341_DrawHLine(x, y, length, color);
ILI9341_DrawHLine(x, y+width, length, color);
ILI9341_DrawVLine(x, y, width,color);
ILI9341_DrawVLine(x + length, y, width,color);
// ILI9341_DrawCircle()
// Zeichnet ein Kreis auf das Display ein.
// Variablen
// @ pox : X-Position auf das Display
// @ poy : Y-Position auf das Display
// @ r : Radius des Kreises
// @ color : Farbe des Kreises
void ILI9341_DrawCircle(int poX, int poY, int r,uint16_t color)
int x = -r, y = 0, err = 2-2*r, e2;
do {
ILI9341_SetPixel(poX-x, poY+y,color);
ILI9341_SetPixel(poX+x, poY+y,color);
ILI9341_SetPixel(poX+x, poY-y,color);
ILI9341_SetPixel(poX-x, poY-y,color);
e2 = err;
if (e2 <= y) {
err += ++y*2+1;
if (-x == y && e2 <= x) e2 = 0;
} // if
if (e2 > x) err += ++x*2+1;
} while (x <= 0);
// ILI9341_FillScreen()
// Zeichnet das ganze Display ein
// Variablen
// @ color : Farbe für das ganze Display
void ILI9341_FillScreen(uint16_t color)
ILI9341_SetX(0, LCD_WIDTH - 1); // Wähle alle aus der X- und
ILI9341_SetY(0, LCD_HEIGH - 1); // Y-Koordinate aus.-
ILI9341_SendComand(ILI9341_RAMWR); // Schreibe die Info in der Memory
P5OUT |= ILI9341_DC; // Daten werden nun manuel gesendet ...
P8OUT &=~ ILI9341_CS; // Frame startet ...
uint8_t high = color>>8; // Farbe in Low und High unterteilen ...
uint8_t low = color&0xff; // ...
for(long int i=0; i < ILI9341_PIXEL; i++) // Für ILI9341_PIXEL = 320 x 240 Pixels ausführen ...
ILI9341_SPI_transmit(high); // Sende High- und ...
ILI9341_SPI_transmit(low); // Sende Low-Byte ...
} // for
P8OUT |= ILI9341_CS; // Frame endet
// ILI9341_FillRectangle()
// Füll ein Rechteck auf das Display ein.
// Variablen
void ILI9341_FillRectangle(uint16_t x, uint16_t y, uint16_t length, uint16_t width, uint16_t color)
unsigned long XY=0;
unsigned long i=0;
uint16_t XL = x, XR = x+length, YU = y, YD = y+width;
if(XL > XR)
XL = XL^XR;
XR = XL^XR;
XL = XL^XR;
} // if
if(YU > YD)
YU = YU^YD;
YD = YU^YD;
YU = YU^YD;
} // if
XY = (XR-XL+1);
XY = XY*(YD-YU+1);
ILI9341_SetX(XL,XR);
ILI9341_SetY(YU, YD);
uint8_t Hcolor = color>>8;
uint8_t Lcolor = color&0xff;
for(i=0; i < XY; i++)
ILI9341_SPI_transmit(Hcolor);
ILI9341_SPI_transmit(Lcolor);
// ILI9341_FillCircle()
// Füllt ein Kreis auf das Display ein.
// Variablen
void ILI9341_FillCircle(int poX, int poY, int r,uint16_t color)
do {
ILI9341_DrawVLine(poX-x, poY-y, 2*y, color);
ILI9341_DrawVLine(poX+x, poY-y, 2*y, color);
e2 = err;
if (e2 <= y) {
err += ++y*2+1;
} // if
} while (x <= 0);
// ILI9341_GraphDemo()
// Demo-Funktion zeigt dem Anwender alle wichtigen grafischen Funktionen.
void ILI9341_GraphDemo(void)
// 1. Some Colors
ILI9341_FillScreen(ILI9341_BLACK);
ILI9341_FillScreen(ILI9341_RED);
ILI9341_FillScreen(ILI9341_GREEN);
ILI9341_FillScreen(ILI9341_YELLOW);
ILI9341_FillScreen(ILI9341_ORANGE);
ILI9341_FillScreen(ILI9341_BLUE);
ILI9341_FillScreen(ILI9341_GREY);
// 2. Draw
for (int i = 0; i < 1000; i++)
int x = rand() % LCD_WIDTH;
int y = rand() % LCD_HEIGH;
ILI9341_DrawPixel(x, y, ILI9341_RED);
} // for
ILI9341_DrawPixel(x, y, ILI9341_BLUE);
} // for
ILI9341_DrawPixel(x, y, ILI9341_YELLOW);
} // for
// 3. Rectangel
ILI9341_FillRectangle(0, 60, 60, 60,ILI9341_YELLOW);
ILI9341_FillRectangle(90, 60, 60, 60,ILI9341_BLUE);
ILI9341_FillRectangle(180, 60, 60, 60,ILI9341_RED);
ILI9341_FillCircle(30, 180, 30,ILI9341_YELLOW);
ILI9341_FillCircle(120, 180, 30,ILI9341_BLUE);
ILI9341_FillCircle(210, 180, 30,ILI9341_RED);
ILI9341_DrawString("Follow me",85, 120, 1, ILI9341_BLUE);
__delay_cycles(DELAY_1s);
ILI9341_DrawString("on",117, 120, 1, ILI9341_BLUE);
for(int i = 0; i < 10; i++)
ILI9341_DrawString("www.electrodummies.net",57, 120, 1, ILI9341_BLUE);
} // fo
