Other Parts Discussed in Thread: MSPM0G3507, SYSCONFIG
Hi Expert,
I use
HW: LP-MSPM0G3507
sdk: 1.30.0.03
example: timx_timer_mode_capture_edge_capture_LP_MSPM0G3507_nortos_ticlang
the default project has no issue and works correctly.
I change input to TIMA0 channel 0. it works correctly.
I change input to TIMA0 channel 2. the interrupt doesn't trigger anymore.
i already confirm the interrupt setting in sysconfig and code. it should be ok. Can someone tell me what's wrong?
BR,
frank
timx_timer_mode_capture_edge_capture.syscfg
/* * Copyright (c) 2020, Texas Instruments Incorporated * All rights reserved. * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions * are met: * * * Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer. * * * Redistributions in binary form must reproduce the above copyright * notice, this list of conditions and the following disclaimer in the * documentation and/or other materials provided with the distribution. * * * Neither the name of Texas Instruments Incorporated nor the names of * its contributors may be used to endorse or promote products derived * from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */ #include "ti_msp_dl_config.h" #define TIMER_CAPTURE_DURATION (CAPTURE_0_INST_LOAD_VALUE) volatile bool gCheckEdgeCaptureTime; int main(void) { __attribute__((unused)) volatile static uint32_t edgeCapture; SYSCFG_DL_init(); NVIC_EnableIRQ(CAPTURE_0_INST_INT_IRQN); gCheckEdgeCaptureTime = false; DL_TimerG_startCounter(CAPTURE_0_INST); /* * LED_1 is turned on to indicate edge capture has started */ DL_GPIO_clearPins( GPIO_LEDS_PORT, GPIO_LEDS_USER_LED_1_PIN | GPIO_LEDS_USER_TEST_PIN); while (1) { while (false == gCheckEdgeCaptureTime) { __WFE(); } gCheckEdgeCaptureTime = false; /* * When the timer is operating in DL_TIMER_CAPTURE_MODE_EDGE_TIME mode, * the timer counts from TIMER_CAPTURE_DURATION to 0 (timer is * configured in count down mode) * When an edge is detected the current timer count is loaded in to the * timer CaptureCompare register. */ edgeCapture = TIMER_CAPTURE_DURATION - (DL_Timer_getCaptureCompareValue( CAPTURE_0_INST, DL_TIMER_CC_2_INDEX)); /* * LED_1 is toggled every time a capture is detected */ DL_GPIO_togglePins(GPIO_LEDS_PORT, GPIO_LEDS_USER_LED_1_PIN | GPIO_LEDS_USER_TEST_PIN); __BKPT(0); /* Setting timer count manually due to TIMER_ERR_01 errata */ DL_TimerG_setTimerCount(CAPTURE_0_INST, TIMER_CAPTURE_DURATION); } } void CAPTURE_0_INST_IRQHandler(void) { switch (DL_TimerG_getPendingInterrupt(CAPTURE_0_INST)) { case DL_TIMERA_IIDX_CC2_DN: gCheckEdgeCaptureTime = true; break; default: break; } }
BR,
frank
