MSP-GANG: Problem 1: The eight-way writer can only use four at the same time; Problem 2: Channel 4 cannot use the burn function.
Part Number: MSP-GANG
Order T05140293 Order model MSP-GANG, the quantity is 1pcs
The customer testing process found two problems: Problem 1: eight-way burner, can only use four at the same time. Problem 2: Channel 4 cannot use the burn function.
What is the reason for asking the engineering to help deal wi th it, thank you
