Other Parts Discussed in Thread: MSP430G2452, MSP430F1121, MSP430G2231
.cdecls C,LIST, "msp430g2231.h"
.text ; Progam Start
; MSP�FET430X110 Demo � Decode RC5 IR Remote Control / TX to PC @ 2400
; Description: Decode 12�bit bi�phase RC5 format IR packet using Timer_A.
; Timer_A CCR1 is used to decode IR packet, capture mode to detect mid�bit
; edge and compare mode to latch data bit. CCR2 is used for decoder
; over�run detection. Received packet is TXed to PC using Timer_A CCR0 as
; a UART function. Packet sent as four ACII bytes, preceded by a CR and LF
; character. P1.0 is set if channel+ is RXed, reset if not.
; IR data are received MSB first. 2 Start, C and 11�bits of data.
; S1�S2�C�A4�A3�A2�A1�A0�C5�C4�C3�C2�C1�C0
; Demonstrate with IR monitor � TX IRData as CR, LF, 4 ASCII Bytes
; MSP430F1121
; /|\| XIN|�
; | | | 32kHz
; ��|RST XOUT|�
; IR Receiver�>|P1.2/CCR1 P1.0|��> LED
; | P1.1|��> 2400 8N1
; Bit pattern as seen at MSP430
; 1.78ms
; ^Start^Start^ 1 ^ 0 ^ 0 ^
; CPU registers used
RXTXData .equ R4
BitCnt .equ R5
IRData .equ R6
IRBit .equ R7
; Conditions for 2400 Baud SW UART, ACLK = 32768
Bitime_5 .equ 06 ; .5 bit length + small adj.
Bitime .equ 014 ; 427us bit length ~ 2341 baud
mit1 .equ 039h ; my own
LED0 .equ 001h ; LED0 on P1.0
TXD .equ 002h ; TXD on P1.1
IRIN .equ 004h ; IR input on P1.2
Bit_50 .equ 29 ; 890 us @ 32768 ACLK
Bit_75 .equ 44 ; 1348 us @ 32768 ACLK
Ch_up .equ 32 ;
Ch_dwn .equ 33 ;
LF .equ 0ah ; ASCII Line Feed
CR .equ 0dh ; ASCII Carriage Return
; M. Buccini
; Texas Instruments, Inc
; July 2001
.text ; Program Start
RESET mov.w #0280h,SP ; Initialize stackpointer
call #Init_Sys ; Initialize System Peripherals
Mainloop call #IR_Ready ; Ready IR decoder
bis.w #LPM3,SR ; Enter LPMx, stop, save power
call #TXIR_2_PC ; TX received command
call #LED_Disp ; Test for Channel +/�
jmp Mainloop ;
Init_Sys; Initialize System Peripherals
StopWDT mov.w #WDTPW+WDTHOLD,&WDTCTL ; Stop WDT
SetupTA mov.w #TASSEL0+MC1,&TACTL ; ACLK, continuous
SetupC0 mov.w #OUT,&CCTL0 ; TXD Idle as Mark
SetupP1 bis.b #IRIN+TXD,&P1SEL ; P1.2 CCR1, P1.1 CCR0
bis.b #LED0+TXD,&P1DIR ; P1.0, TXD outputs
bic.b #LED0,&P1OUT ; P1.0, low, LED off
eint ;
ret ; Return from subroutine
IR_Ready; Subroutine to prepare to receive 12�bit RC5 into IRData
clr.w IRData ;
mov.w #014,IRBit ; 12 data + 1 start + completion
SetupC1 mov.w #CM1+SCS+CAP+CCIE,&CCTL1 ; CAP CCI1A, falling edge, int
ret ;
TXIR_2_PC; Subroutine to send CR, LF and IRData as four ASCII bytes to PC
; R15 used as working register and not saved
mov #CR,RXTXData ; CR to UART buffer
call #TX_Byte ; CR ��> PC/user
mov #LF,RXTXData ; LF to UART buffer
TX_Word_ASCII; TX Word from IRData as four ASCII bytes
swpb IRData ; IRData = 3412
call #TX_Byte_ASCII ;
swpb IRData ; IRData = 1234
TX_Byte_ASCII; TX Byte from IRData as two ASCII bytes
mov.b IRData,R15 ; transmit ..x. of value
call #NUM_ASCIR ;
mov.b IRData,R15 ; transmit ...x of value
jmp NUM_ASCIA ;
NUM_ASCIR rrc.b R15 ; 1. and 3. pass
rrc.b R15 ;
rrc.b R15 ;
rrc.b R15 ;
NUM_ASCIA and.b #0fh,R15 ; 2. and 4. pass
add.b #030h,R15 ;
cmp.b #03ah,R15 ;
jlo NUM_End ;
add.b #mit1,R15 ;
NUM_End mov.b R15,RXTXData ; load transmit buffer, FALL
TX_Byte; Subroutine to TX Byte from RXTXData Buffer using CCR0 UART
mov.w &TAR,&CCR0 ; Current state of TA Counter
add.w #Bitime,&CCR0 ; Some time till first bit
bis.w #0100h, RXTXData ; Add mark stop bit to RXTXData
rla.w RXTXData ; Add space start bit
mov.w #10,BitCnt ; Load Bit Counter, 8 data + SP
mov.w #OUTMOD0+CCIE,&CCTL0 ; TXD = mark = idle
TX_Wait tst.w BitCnt ; Wait for TX completion
jnz TX_Wait ;
;ret
TA0_ISR ; RXTXData Buffer holds UART Data.
add.w #Bitime,&CCR0 ; Time to Next Bit
UART_TX bic.w #OUTMOD2,&CCTL0 ; TX Mark
rra.w RXTXData ; LSB is shifted to carry
jc TX_Test ; Jump ��> bit = 1
TX_Space bis.w #OUTMOD2,&CCTL0 ; TX Space
TX_Test dec.w BitCnt ; All bits sent (or received)?
jnz TX_Next ; Next bit?
bic.w #CCIE,&CCTL0 ; All Bits TX/RX, Disable Int.
TX_Next reti ;
TAX_ISR; Common ISR � CCR1�4 and overflow
add.w &TAIV,PC ; Add Timer_A offset vector
reti ; CCR0 � no source
jmp TA1_ISR ; CCR1
jmp TA2_ISR ; CCR2
; reti ; CCR3
; reti ; CCR4
;TA_over reti ; Return from overflow ISR
TA1_ISR bit.w #CAP,&CCTL1 ;
jc RX_edge ; Jump �> Edge captured
RX_Bit dec.w IRBit ;
jz RX_Comp ; Test of end of packet
RX_Cont bit.w #SCCI,&CCTL1 ; Carry = Data bit in SCCI
rlc.w IRData ; Carry �> IRData
mov.w #CM1+CM0+CAP+CCIE+SCS,&CCTL1 ; CAP CCI1A,both edges, int
push.w &CCR1 ; Max time till next edge
add.w #Bit_50,0(SP) ;
pop.w &CCR2 ;
mov.w #CCIE,&CCTL2 ; Enable timeout interrupt
;reti
RX_Comp clr.w &CCTL1 ; Disable CCR1
and.w #0FFFh,IRData ; Isolate 12�bit packet
mov.w #GIE,0(SP) ; Decode = Active in Mainloop
;reti
RX_edge clr.w &CCTL2 ; Disable CCR2 timeout
mov.w #CCIE,&CCTL1 ; Compare mode w/ int.
add.w #Bit_75,&CCR1 ; Time to middle of data bit
;reti
TA2_ISR clr.w &CCTL2 ; Disable CCR2 timeout
call #IR_Ready ; ERROR � restart RX sequence
reti ; Return from interrupt
LED_Disp; LED0 (P1.0) set if IRData = Channel+ code (32)
and.w #03Fh,IRData ; Isolate 6�bit command code
LED_off bic.b #01h,&P1OUT ; LED0 off
LED0_tst cmp.w #Ch_up,IRData ; Test for Channel+ (32)
jne LED_exit ;
bis.b #01h,&P1OUT ; LED0 on
LED_exit ret ; Return from subroutine
; Interrupt Vectors
.sect ".reset" ; MSP430 RESET Vector
.short RESET ;
.sect ".int09" ; Timer_A0 Vector
.short TA0_ISR ;
.end
Hi All,
I'm working on low cost IR REMOTE PROJECT, I'm referring ti app notes attached for decode ir signal, the app note solution is based on MSP430F1121 but I want to port this code to value line MSP430G2452. I've made necessary changes to code which i've attached. My program gives below error please help me to remove this. My pin selection is similar to app note pin configuration all pin remains the same.6320.slaa134.pdf
**** Build of configuration Debug for project 2452 ****
C:\Program Files\Texas Instruments\ccsv4\utils\gmake\gmake -k all
'Building file: ../2452.asm'
'Invoking: Compiler'
"C:/Program Files/Texas Instruments/ccsv4/tools/compiler/msp430/bin/cl430" -vmsp -g -O0 --define=__MSP430G2452__ --include_path="C:/Program Files/Texas Instruments/ccsv4/msp430/include" --include_path="C:/Program Files/Texas Instruments/ccsv4/tools/compiler/msp430/include" --diag_warning=225 --printf_support=minimal --preproc_with_compile --preproc_dependency="2452.pp" "../2452.asm"
"../2452.asm", ERROR! at EOF: [E0300] The following symbols are undefined:
1 Assembly Error, No Assembly Warnings
CCTL2
CCR2
Errors in Source - Assembler Aborted
>> Compilation failure
gmake: *** [2452.obj] Error 1
gmake: Target `all' not remade because of errors.
Build complete for project 2452
Thanks & Regards
Mithun
; MSP430F1121
; /|\| XIN|�
; | | | 32kHz
; ��|RST XOUT|�
; 1.78ms
RXTXData .equ R4
BitCnt .equ R5
IRData .equ R6
IRBit .equ R7
Ch_up .equ 32 ;
Ch_dwn .equ 33 ;
; M. Buccini
; July 2001
jmp Mainloop ;
eint ;
clr.w IRData ;
ret ;
call #NUM_ASCIR ;
jmp NUM_ASCIA ;
rrc.b R15 ;
rrc.b R15 ;
rrc.b R15 ;
add.b #030h,R15 ;
cmp.b #03ah,R15 ;
jlo NUM_End ;
add.b #mit1,R15 ;
jnz TX_Wait ;
;ret
TX_Next reti ;
jmp TA1_ISR ; CCR1
jmp TA2_ISR ; CCR2
; reti ; CCR3
; reti ; CCR4
pop.w &CCR2 ;
;reti
;reti
;reti
jne LED_exit ;
; Interrupt Vectors
.short RESET ;
.short TA0_ISR ;
.end
