LP-MSPM0G3519: warning: archive symbol directory is missing from archive
Part Number: LP-MSPM0G3519
Hello Team,
While linking, i am facing the following warning "warning: archive symbol directory is missing from archive".
Also i have gone through the other  thread - https://e2e.ti.com/support/tools/code-composer-studio-group/ccs/f/code-composer-studio-forum/1057190/error-archive-symbol-directory-is-missing-from-archive
but not found any solution. Can you please assist to resolve.
SDK version i am using - mspm0_sdk_2_03_00_07
Micro - MSPM0G359
  • Hi Kiran,
    What tool are you using to get this output? Also what are you trying to do?
    I am not clear on the setup here so please indicate the steps you take to get this behavior so we can start root-causing the issue.
  • I am using cmake to compile the code. I am trying to compile my application by including the SDK driverlib and devices files. The cmake generates the libraries (libstartup.a and libplatformstub.a) as you see in the image. Finally i am generating the .ELF file by linking all these libraries. During linking i am getting this warning. Is it something to do with tiarmar ? where its failed to identify the library location?
  • I see. Unfortunately we do not have any documentation or guidance for using cmake with our SDK. Looking at the information here I am not clear on what the exact issue is. I would recommend taking a look at the cmake documentation to help resolve the issue.
