Other Parts Discussed in Thread: MSP-FET
Hello!
I hope this question find you well.
I am actually working on the EVM-F6736.
I successfully generated a code using EMDC and flashed it with CCS (20.0.2).
After that, I disconnected the MSP-FET and wired the setup as described in the online Energy Measurement Technology Guide (version 1.40.00.03).
Then, I launched EMDC, clicked on the MSP icon, and connected successfully. The firmware version was displayed. I went to the 'Results' section and started reading the data, which updates every second, though calibration is still needed. The following image shows the result :
After one or two minutes, the results stop updating, and the GUI freezes at the last received values. No new data comes in, even though nothing in the system has changed.
I disconnected the HID and repeated the test, but the same issue occurred. The results stream for a while, then suddenly stop.
Do you have any idea what might be causing this?
Thank you in advance for your response!
I wish you an excellent day!
Fathi Chelly
