MSP430FR6047: MSP430FR6047
Part Number: MSP430FR6047
Hello!
We are having a problem with the MSP430FR6047. Everything works fine except when the pipe is moving.
We have found a test case in which the system fails. For example, we have a small closed pipe filled with water, so the flow rate is 0. If we shake the pipe by hand the MSP430FR6047 reads the sensors and detects random flow.
We test if the problem is vibration, by hitting the metal pipe with a metal key, no problem here.
We checked that the soldering was ok and the wires were not moving, everything ok.
So the problem appears just when we shake the pipe.
Is there any filter or solution to solve this problem? Or is it a normal behaviour?
Regards.
