Dear Team,
I am working with the MSP430F67691 controller in one of our projects. We are facing a critical issue where the device shuts down automatically after approximately one month of operation. The shutdown time is not consistent, and we are unable to determine the exact trigger for this behavior.
After the shutdown occurs, we observed that the program memory inside the controller appears to be erased. Using UniFlash, we verified that the code stored in the device is missing. We are not sure why or how the code erase is happening.
For your reference, I have attached the following files:
• The original application HEX file that we programmed into the device
original application HEX file.txt
• The HEX file read back from the controller using UniFlash after the failure
HEX file read back from the controller.txt
Note : I converted .hex to .txt file for uploading
We kindly request your assistance in analyzing this issue and helping us identify the possible root cause and solution.
Please let me know if you need any additional details, logs, or hardware information.
Thank you for your support.
