MSPM0G1507: Internal pull-up/down resistors confirmation
Part Number: MSPM0G1507
Hi Ti team,
I am working with the MSPM0G1507 microcontroller and have a question regarding the integrated pull-up and pull-down resistors in the IOMUX module.
According to the technical reference manual (SLAU846), the IOMUX provides programmable pull-up (PIPU) and pull-down (PIPD) resistors on most digital IOs . However, I am trying to find the specific electrical specifications for these internal resistors but have been unable to locate the exact resistance value in either the datasheet or the user guide.
Resistor Value: Could you please confirm the typical resistance value (in Ohms) of the internal pull-up and pull-down resistors when enabled?
Selection Method: Is this resistance value fixed, or does the MSPM0G1507 offer any method to select between different resistor strengths (e.g., weak vs. strong pull-up) via software? From the register descriptions, I only see bits to enable/disable the resistor (PIPU/PIPD), but not to change its value .
Thank you for your support.
Best regards,
Pakho
