MSPM0-SDK: How to read the entire contents of the MCU flash
Part Number: MSPM0-SDK
Other Parts Discussed in Thread: MSPM0G1107, UNIFLASH
 I would like to ask what tools can read the entire flash contents of the MSPM0G1107TRHB
    The easiest way to read an unlocked MSPM0G1107 is by using Uniflash.  There is a cloud based version and a standalone downloadable version.  You will need a launchpad or supported JTAG programmer and then just launch Uniflash and select your target and tool.  Then there is a memory tab where you can connect and read the memory, as well as export it.
    You can also read the memory with a debugger through CCS or probably all supported IDEs.
    JD
