Part Number: MSPM0L1117
Hi team,
I am using MSPM0L1117 as host controller for an application requireing secure boot and firmware update. I need some clarifications about some BCR configurations:
- if
bootloaderModeisBCR_CFG_BOOTLOADER_MODE_DISthenbslPinInvokeEnableis ignored. I saw from GUI that as long asbootloaderModeisBCR_CFG_BOOTLOADER_MODE_DISthebslPinInvokeEnabledo not change in the BCRConfig. Could you confirm? Also what will happen in case of a glitch attack thebootloaderModeis bypassed? Shall I also manually changebslPinInvokeEnabletoBCR_CFG_BSL_PIN_INVOKE_DISor this configuration will be useless? - Could you add some clarifications about
secureBootMode? Is this seeting relevant since we are using CSC(customer secure code)? - If
debugAcessis BCR_CFG_DEBUG_ACCESS_DIS andswdpModeis BCR_CFG_SWDP_DIS we were wondering if there is any effect of setting the passwords to a value different from default. Our concern is still a glitch attack which could bypass thedebugAcessandswdpMode.
