Other Parts Discussed in Thread: SIMPLICITI
Hello all,
I am trying to debug a code and repeatedly getting this error message - "This project contains unresolved buildable linked resources. It might not build as expected."
What should be done?
Hello all,
You should add the linked resource definition in your workspace then.
Please refer to the following wiki page:
http://processors.wiki.ti.com/index.php/Portable_Projects#To_create_a_Linked_Resource_path_variable:
Just out of coriousity, are you trying to compile SimpliciTI with CCS? If yes, you should add the DEV_ROOT path as described in the SWRA243 SimpliciTI Sample Application User's Guide - chapter 2.3.2 "Using Code Composer Studio" (usually can be found at C:\Texas Instruments\SimpliciTI-CCS-1.1.1\Documents).
Hope this helps.
