Constants at specific flash locations
I want to have some constants be in the same block as some code that I specifically locate in memory.
I have defined a block called .flasher and have method definitions like...
#pragma CODE_SECTION(writeflash, ".flasher")
void writeflash()
Then I want to do something like...
#pragma DATA_SECTION(flashmodStr2, ".flasher")
char flashmodStr2[] = "aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa";
and have flashmodStr2 be located in the same block as the above method.
The method gets located just fine, but not the constants.
I see in the FlashMonitor sample code that the assembly uses liens like
CmdTable:   DB  "CDEGIU"
How is this done in C code in Code Composer Essentials?
