Other Parts Discussed in Thread: CSD
I am having a compile problem with the below syntax in IAR. I testing the same block under a regular c compiler and it compiled fine. I am assuming there is some logical error. Please help.
I get the following error: Error[e27]: Entry "CSD" in module main ( C:\Documents and Settings\Robot\Desktop\temp\slaa281b\usage_example_IAR\Debug\Obj\main.r43 ) redefined in module mmc ( C:\Documents and ...)
union {
unsigned char csdBytes[16];
struct{
unsigned char csdStructure : 2;
unsigned char reserved1 : 6;
unsigned char taac : 8;
unsigned char nsac : 8;
unsigned char transSpeed : 8;
unsigned short ccc : 12;
unsigned char readBlLen : 4;
unsigned char ReadBlPartial : 1;
unsigned char WriteBlkMisalign : 1;
unsigned char ReadBlkMisalign : 1;
unsigned char dsrImp : 1;
unsigned char reserved2 : 2;
unsigned short cSize : 12;
unsigned char vddRCurrMin : 3;
unsigned char vddRCurrMax : 3;
unsigned char vddWCurrMin : 3;
unsigned char vddWCurrMax : 3;
unsigned char cSizeMult : 3;
unsigned char eraseBlkEn : 1;
unsigned char sectorSize : 7;
unsigned char wpGrpSize : 7;
unsigned char wpGrpEnable : 1;
unsigned char reserved3 : 2;
unsigned char r2wFactor : 3;
unsigned char writeBlLen : 4;
unsigned char WriteBlPartial : 1;
unsigned char reserved4 : 5;
unsigned char fileFormatGrp : 1;
unsigned char copy : 1;
unsigned char permWriteProtect : 1;
unsigned char tmpWriteProtect : 1;
unsigned char fileFormat : 2;
unsigned char reserved5 : 2;
unsigned char crc : 7;
unsigned char reserved6 : 1;
} CSD_bit;
} CSD;
