Other Parts Discussed in Thread: MSP430G2553
How can I perform a software reset with my MSP430G2553?
I try to apply:
SVSCTL |= PORON;
But this register and value are not recognized.
Yael
I try to apply:
SVSCTL |= PORON;
Yael
Yael Oz said:How can I perform a software reset with my MSP430G2553?
I try to apply:
SVSCTL |= PORON;
This is not how the PORON bit in the SVSCTL is meant to be used. As the MSP430x2xx Family User's Guide (SLAU144) indicates in Chapter 9, the PORON bit is an enable for the SVSFG flag to generate a POR. Figure 9-1 illustrates this.
To generate a reset from software, one method is to use the Watchdog Timer module. In Section 10.2, the above document indicates any write to WDTCTL with any value other than 05Ah in the upper byte is a security key violation and triggers a PUC system reset regardless of timer mode.
Thank you for your answer! it works!
I have one more open issue - I need a non-volatile place in the memory in order to save a value after the reset I performed.
Where can I find the address mapping of the LaunchPad? Which section is non-volatile?
Yael
I saw the memory organization in the datasheet. Thanks,
Can you please tell me which section is non-volatile? This information is not in the datasheet.
Yael
Please notice that a watchdog reset causes a PUC and not a POR. That means, some registers aren't initialized to power-on-defaults. Especially the SVS and timer registers are untouched (to allow timing consistency across a watchdog event).Yael Oz said:Thank you for your answer! it works!
