I'm using the 6638 with the USB stack configured for MSC mode using an SD Card. Was wondering does anyone know if you can edit the code so that when you plug the device into your computer it comes up with a volume name instead of "Removable Disk E:" ?
I know if you right click on it from windows you can rename it & the name will stick, but can you do it from the embedded side?
Cheers
Paul
