Other Parts Discussed in Thread: MSP430F5638
In my application i often need speed. One month ago, i was a bit frustrated by my MSP430F5638 attached to a color LCD. So i tried to push up the CLK frequency..
(FLL ON+external XTAL 32768)
This family is specified at 20Mhz. My first attempt was at 25Mhz, and after a week of test with alla timers, SPI JTAG ports capture compare working, everything seems to works perfectly(No CRC erroers). Then i tried 30Mhz(!) And results were the same.
Well i thought i found a special CPU? I did the same experiment on CPU taken from different lots...and the results were still with no errors. Now i have 50 boards running at 33Mhz by 4 days with all the peripherals engaged, and it is all ok. I also checked the ACLK with an oscillscope, just to see the jitter on the bus, and at 30Mhz it's almost perfect. Of course i will never sell my products, with the CPU outside its specification...
All this test(just for curiosity) have been made in a climate chamber in the range 0-70°
The MSP430F5xxx running at 30Mhz it's a very powerful machine !!
Does anybody did experiment on overclock?
does TI specifi this CPU at 20Mhz only for commercial purpose?
Alessandro Fulignani
