MSP430UIF Problem Under Linux
I have installed CCS 5.4.0.00091 for linux,
Linux localhost.localdomain 3.9.4-200.fc18.x86_64 #1 SMP Fri May 24 20:10:49 UTC 2013 x86_64 x86_64 x86_64 GNU/Linux
about a week ago. I am now trying to get a debug session to connect to an MSP430-EXP5438 Experimenter's Board via a brand new MSP430UIF debugger.
In all cases, lsusb reports that the MSP430UIF has been recognized:
Bus 001 Device 020: ID 2047:0010 Texas Instruments
The first time I tried, I got "msp430: error initializing emulator: no usb fet was found." I found on-line where the initial firmware version in the msp430uif does not work with linux, so i connected to the device with the SmartRF flash programmer tool. That tool reported that the uif firmware was out-of-date and i updated it.
Then i tried again with linux but now am getting:
MSP430: Error initializing emulator: Could not set device Vcc
The MSP430-EXP5438 board powers on (from the battery) just fine and the preprogrammed application runs perfectly.
I'm also including some output from dmesg that looks relevent. Any help would be appreciated.
--Randy
[138186.053798] usb 1-5.3: new full-speed USB device number 12 using ehci-pci
[138186.151493] usb 1-5.3: New USB device found, idVendor=0451, idProduct=f430
[138186.151504] usb 1-5.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[138186.151512] usb 1-5.3: Product: MSP-FET430UIF JTAG Tool
[138186.151518] usb 1-5.3: Manufacturer: Texas Instruments
[138186.151523] usb 1-5.3: SerialNumber: TUSB34102B0617BE1B4AFF71
[138186.288032] usbcore: registered new interface driver ti_usb_3410_5052
[138186.288073] usbserial: USB Serial support registered for TI USB 3410 1 port adapter
[138186.288103] usbserial: USB Serial support registered for TI USB 5052 2 port adapter
[138186.288143] ti_usb_3410_5052 1-5.3:1.0: TI USB 3410 1 port adapter converter detected
[138186.864306] usb 1-5.3: reset full-speed USB device number 12 using ehci-pci
[138186.948227] usb 1-5.3: device firmware changed
[138186.948490] ti_usb_3410_5052: probe of 1-5.3:1.0 failed with error -5
[138186.949218] usb 1-5.3: USB disconnect, device number 12
[138187.015377] usb 1-5.3: new full-speed USB device number 13 using ehci-pci
[138187.138827] usb 1-5.3: New USB device found, idVendor=0451, idProduct=f430
[138187.138839] usb 1-5.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[138187.138846] usb 1-5.3: Product: MSP-FET430UIF JTAG Tool
[138187.138852] usb 1-5.3: Manufacturer: Texas Instruments
[138187.138857] usb 1-5.3: SerialNumber: TUSB34102B0617BE1B4AFF71
[138187.140183] ti_usb_3410_5052 1-5.3:1.0: TI USB 3410 1 port adapter converter detected
[138187.140215] ti_usb_3410_5052: probe of 1-5.3:1.0 failed with error -5
[138187.141959] ti_usb_3410_5052 1-5.3:2.0: TI USB 3410 1 port adapter converter detected
[138187.142223] usb 1-5.3: TI USB 3410 1 port adapter converter now attached to ttyUSB1
[149046.893520] ti_usb_3410_5052_1 ttyUSB1: TI USB 3410 1 port adapter converter now disconnected from ttyUSB1
[149046.893563] ti_usb_3410_5052 1-5.3:2.0: device disconnected
[149073.214360] ti_usb_3410_5052 1-5.3:1.0: TI USB 3410 1 port adapter converter detected
[149073.214408] ti_usb_3410_5052: probe of 1-5.3:1.0 failed with error -5
[149073.216805] ti_usb_3410_5052 1-5.3:2.0: TI USB 3410 1 port adapter converter detected
[149073.217014] usb 1-5.3: TI USB 3410 1 port adapter converter now attached to ttyUSB1
[149073.218120] ti_usb_3410_5052_1 ttyUSB1: TI USB 3410 1 port adapter converter now disconnected from ttyUSB1
[149073.218158] ti_usb_3410_5052 1-5.3:2.0: device disconnected
[149144.427168] usb 1-5.3: USB disconnect, device number 13
[149158.878953] usb 1-5.3: new full-speed USB device number 14 using ehci-pci
[149158.992777] usb 1-5.3: New USB device found, idVendor=2047, idProduct=0010
[149158.992788] usb 1-5.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[149158.992795] usb 1-5.3: Product: Texas Instruments MSP430-JTAG
[149158.992800] usb 1-5.3: Manufacturer: Texas Instruments
[149158.992805] usb 1-5.3: SerialNumber: 71FF4A1BBE17062B
[149159.174628] cdc_acm 1-5.3:1.0: This device cannot do calls on its own. It is not a modem.
[149159.174705] cdc_acm 1-5.3:1.0: ttyACM0: USB ACM device
[149159.176693] usbcore: registered new interface driver cdc_acm
[149159.176701] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[149159.794747] usb 1-5.3: USB disconnect, device number 14
[149161.380501] usb 1-5.3: new full-speed USB device number 15 using ehci-pci
[149161.484571] usb 1-5.3: New USB device found, idVendor=2047, idProduct=0010
[149161.484582] usb 1-5.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[149161.484589] usb 1-5.3: Product: Texas Instruments MSP430-JTAG
[149161.484595] usb 1-5.3: Manufacturer: Texas Instruments
[149161.484600] usb 1-5.3: SerialNumber: 71FF4A1BBE17062B
[149161.486328] cdc_acm 1-5.3:1.0: This device cannot do calls on its own. It is not a modem.
[149161.486371] cdc_acm 1-5.3:1.0: ttyACM0: USB ACM device
[149210.762263] usb 1-5.3: USB disconnect, device number 15
[149222.207915] usb 1-5.3: new full-speed USB device number 16 using ehci-pci
[149222.312314] usb 1-5.3: New USB device found, idVendor=2047, idProduct=0010
[149222.312325] usb 1-5.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[149222.312333] usb 1-5.3: Product: Texas Instruments MSP430-JTAG
[149222.312339] usb 1-5.3: Manufacturer: Texas Instruments
[149222.312344] usb 1-5.3: SerialNumber: 71FF4A1BBE17062B
[149222.314077] cdc_acm 1-5.3:1.0: This device cannot do calls on its own. It is not a modem.
[149222.314119] cdc_acm 1-5.3:1.0: ttyACM0: USB ACM device
[149863.100307] usb 1-5.3: USB disconnect, device number 16
[149871.829288] usb 1-5.3: new full-speed USB device number 17 using ehci-pci
[149871.932986] usb 1-5.3: New USB device found, idVendor=2047, idProduct=0010
[149871.932997] usb 1-5.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[149871.933005] usb 1-5.3: Product: Texas Instruments MSP430-JTAG
[149871.933011] usb 1-5.3: Manufacturer: Texas Instruments
[149871.933016] usb 1-5.3: SerialNumber: 71FF4A1BBE17062B
[149871.934729] cdc_acm 1-5.3:1.0: This device cannot do calls on its own. It is not a modem.
[149871.934769] cdc_acm 1-5.3:1.0: ttyACM0: USB ACM device
[149883.846032] usb 1-5.3: USB disconnect, device number 17
[149889.963159] usb 1-5.3: new full-speed USB device number 18 using ehci-pci
[149890.067345] usb 1-5.3: New USB device found, idVendor=2047, idProduct=0010
[149890.067357] usb 1-5.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[149890.067364] usb 1-5.3: Product: Texas Instruments MSP430-JTAG
[149890.067370] usb 1-5.3: Manufacturer: Texas Instruments
[149890.067375] usb 1-5.3: SerialNumber: 71FF4A1BBE17062B
[149890.069178] cdc_acm 1-5.3:1.0: This device cannot do calls on its own. It is not a modem.
[149890.069219] cdc_acm 1-5.3:1.0: ttyACM0: USB ACM device
[149899.469104] usb 1-5.3: USB disconnect, device number 18
[149906.976379] usb 1-5.3: new full-speed USB device number 19 using ehci-pci
[149907.080305] usb 1-5.3: New USB device found, idVendor=2047, idProduct=0010
[149907.080317] usb 1-5.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[149907.080325] usb 1-5.3: Product: Texas Instruments MSP430-JTAG
[149907.080330] usb 1-5.3: Manufacturer: Texas Instruments
[149907.080335] usb 1-5.3: SerialNumber: 71FF4A1BBE17062B
[149907.082126] cdc_acm 1-5.3:1.0: This device cannot do calls on its own. It is not a modem.
[149907.082172] cdc_acm 1-5.3:1.0: ttyACM0: USB ACM device
[149912.531227] usb 1-5.3: USB disconnect, device number 19
[149922.734769] usb 1-5.3: new full-speed USB device number 20 using ehci-pci
[149922.838953] usb 1-5.3: New USB device found, idVendor=2047, idProduct=0010
[149922.838965] usb 1-5.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[149922.838973] usb 1-5.3: Product: Texas Instruments MSP430-JTAG
[149922.838978] usb 1-5.3: Manufacturer: Texas Instruments
[149922.838983] usb 1-5.3: SerialNumber: 71FF4A1BBE17062B
[149922.840994] cdc_acm 1-5.3:1.0: This device cannot do calls on its own. It is not a modem.
[149922.841043] cdc_acm 1-5.3:1.0: ttyACM0: USB ACM device
