How to add a header file to library in IAR???
hi, i'm using IAR workbench 2002-2013 ,
whenever i use io310.h it gives error saying header file not found ,..
how to rectify it ..... How to modify header files
  • actually correct syntax is  #include "io310.h"
    anyways if you paste your code i can tell what is the problem exactly
    for more information regarding header files you just go through it
    https://hps.hs-regensburg.de/~scg39398/mc_lab/pdf/msp430/MSP430%20C%20Compiler%20Programming%20Guide.pdf
