There is a 470nF cap between gnd and Vcore ,if pin is open ,nothing connected or put wrong cap ,or change value while power is on , does microcontroller is damaged ?
MEHMET SADIK SEN said:There is a 470nF cap between gnd and Vcore ,if pin is open ,nothing connected or put wrong cap ,or change value while power is on , does microcontroller is damaged ?
Most probably microcontroller is not damaged, but you better put right cap in place and test.
MEHMET SADIK SEN said:change value while power is on
Wow... what you are actually doing there? :D
Removing the heart temporarily while the patient was conscious was damaging the patient. Surprise.MEHMET SADIK SEN said:i want to ask why chip is so fragile , removing one cap damaged the chip
The VCORE cap is the charging capacitor for the core voltage regulator. If you remove it or change it while the device is under power, this will certainly make the core regulator running wild. Perhaps pushing massive overvoltage peaks into the CPU core.
