I have used a code written for MSP430 tutorial to run the MSP430F5529 Launchpad MCLK at 8MHz.
I used the code below as a separate C file to initialize the clock and in the main program it just blinks it every second. Unfortunately when I set a breakpoint and watch the value of "myMCLK ", It shows a value of 8,192,000Hz after initialization. I was expecting to get a value of 8,388,608Hz which which should be the case when we set the value of UCSCTL2 to 249 . Where did this value come from?
// myClocks.c (for lab_04a_clock project)
// ACLK is set
//***** Header Files **********************************************************
//#include <stdbool.h>
#include <driverlib.h>
#include "myClocks.h"
//***** Defines ***************************************************************
#define LF_CRYSTAL_FREQUENCY_IN_HZ 32768
#define HF_CRYSTAL_FREQUENCY_IN_HZ 4000000
#define MCLK_DESIRED_FREQUENCY_IN_KHZ 8 * 1000
#define MCLK_FLLREF_RATIO MCLK_DESIRED_FREQUENCY_IN_KHZ / ( UCS_REFOCLK_FREQUENCY/1024 ) // ratio = 250 , (UCS_REFOCLK_FREQUENCY=32768)
//***** Global Variables ******************************************************
uint32_t myACLK = 0;
uint32_t mySMCLK = 0;
uint32_t myMCLK = 0;
//***** Functions **************************************************************
void initClocks(void) {
// Initialize the XT1 and XT2 crystal frequencies being used
// so driverlib knows how fast they are
UCS_setExternalClockSource( UCS_BASE, //This function is called only because UCS_getACLK.. is used. Otherwise remove it
LF_CRYSTAL_FREQUENCY_IN_HZ,
// Verify if the default clock settings are as expected
myACLK = UCS_getACLK( UCS_BASE ); // only used for checking purposes
mySMCLK = UCS_getSMCLK( UCS_BASE );
myMCLK = UCS_getMCLK( UCS_BASE );
// Setup ACLK to use REFO as its oscillator source
UCS_clockSignalInit( UCS_BASE,
UCS_ACLK, // Clock you're configuring
UCS_REFOCLK_SELECT, // Clock source
UCS_CLOCK_DIVIDER_1 // Divide down clock source by this much
// Set the FLL's clock reference clock source
UCS_FLLREF, // Clock you're configuring
// Configure the FLL's frequency and set MCLK & SMCLK to use the FLL as their source
UCS_initFLLSettle( UCS_BASE,
MCLK_DESIRED_FREQUENCY_IN_KHZ, // MCLK frequency
MCLK_FLLREF_RATIO // Ratio between MCLK and FLL's reference clock source
// // Optional lab step set MCLK to run from REFO
// // This will make the LED blink very sloooowly in our while{} loop
// UCS_clockSignalInit( UCS_BASE,
// UCS_MCLK, // Clock you're configuring
// UCS_REFOCLK_SELECT, // Clock source
// UCS_CLOCK_DIVIDER_1 // Divide down clock source by this much
// Verify that the modified clock settings are as expected
myACLK = UCS_getACLK( UCS_BASE ); // Only for test purposes
void initPowerMgmt(void) {
// Set core voltage level to handle 8MHz clock rate
PMM_setVCore( PMM_BASE, PMM_CORE_LEVEL_1 );
