MSP430: Error initializing emulator: No USB FET was found
Other Parts Discussed in Thread: MSP430WARE
I have a MSP430F5529LP. When trying to run the one of the examples (MSP430ware_1_95_00_32/examples/devices/5xx_6xx/ MSP430F55xx_Code_Examples/C/MSP430F55xx_1.c)  in CCS 6 running on Ubuntu 14.04, I get that error. What should I do? The label on the board does not start with 1401, so firmware upgrade is not required, right?
  • The LP identifies itself as an MSP430 ezFET device. If you have the proper drivers installed. The IDE looks for such a device. And apparently doesn’t find one.
    Unfortunately, I don’t know how the driver installation and device identification works on Linux.
    If a firmware upgrade is required, the MSP430 library will tell you - once it has found a device that needs an upgrade. In your case, it doesn’t find a device at all.
  • Thank you for your help. After reading the docs for Linux, and trying several "solutions", I've finally decided to install CCS in a XP laptop. After installing the ezFET drivers in the laptop, I've been able to make it work.
