Hello Jesse Frey (1474738) and Cameron LaFollette (3712600) ,
I am also facing related problem, My PMM configuration is
PMMCTL0_H=PMMPW_H; PMMCTL0_L|=PMMCOREV_3; //check voltage level switch(PMMCTL0&PMMCOREV_3) { //settings for highest core voltage settings case PMMCOREV_3: //setup high side supervisor and monitor SVSMHCTL=SVMHE|SVSHE|SVSHRVL_3|SVSMHRRL_7; break; } //clear interrupt flags PMMIFG&=~(SVMLIFG|SVMHIFG|SVMHVLRIFG|SVMLVLRIFG); //setup interrupts PMMRIE|=SVMLIE|SVMHIE|SVMHVLRIE|SVMLVLRIE; //lock PMM PMMCTL0_H=0;
and
My ISR is
#pragma vector = SYSNMI_VECTOR __interrupt void SYS_NMI(void) { switch(SYSSNIV) { case SYSSNIV_SVMLIFG: break; case SYSSNIV_SVMHIFG: write_SegC(); //Funtion to be called break; case SYSSNIV_DLYLIFG: break; case SYSSNIV_DLYHIFG: break; case SYSSNIV_VMAIFG: break; case SYSSNIV_JMBINIFG: break; case SYSSNIV_JMBOUTIFG: break; case SYSSNIV_VLRLIFG: PMMCTL0_H=PMMPW_H; //clear interrupt flags PMMIFG&=~(SVMLIFG|SVMLVLRIFG); //lock PMM PMMCTL0_H=0; break; case SYSSNIV_VLRHIFG: PMMCTL0_H=PMMPW_H; //clear interrupt flags PMMIFG&=~(SVMHIFG|SVMHVLRIFG); //lock PMM PMMCTL0_H=0; break; } }
Problem I am facing is I want to go into write_SegC() function while my supply goes down but instead of this it goes into it while I power it up.
Abhishek
