I'm starting development on a bootloader for the CC430F5137. There's a bunch of articles all over the place so I thought I would summarize the steps that I took and ask a few simple questions.
- There is some sample bootloader code in here for the MSP430F5438, which has CCS support (super important for poor folks like me who use CCS)
- This has the explanations on the memory mapping in the linker file lnk_msp430f5418a.cmd, which explains what ZArea means.
- I modified the linker file to suit the CC430F5137, namely, I changed the RAM size and then the size of FLASH2. The file is as follows:
/* ============================================================================ */ /* Copyright (c) 2013, Texas Instruments Incorporated */ /* All rights reserved. */ /* */ /* Redistribution and use in source and binary forms, with or without */ /* modification, are permitted provided that the following conditions */ /* are met: */ /* */ /* * Redistributions of source code must retain the above copyright */ /* notice, this list of conditions and the following disclaimer. */ /* */ /* * Redistributions in binary form must reproduce the above copyright */ /* notice, this list of conditions and the following disclaimer in the */ /* documentation and/or other materials provided with the distribution. */ /* */ /* * Neither the name of Texas Instruments Incorporated nor the names of */ /* its contributors may be used to endorse or promote products derived */ /* from this software without specific prior written permission. */ /* */ /* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" */ /* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, */ /* THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR */ /* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR */ /* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, */ /* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, */ /* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; */ /* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, */ /* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR */ /* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */ /* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */ /* ============================================================================ */ /******************************************************************************/ /* lnk_msp430f5418a.cmd - LINKER COMMAND FILE FOR LINKING MSP430F5418A PROGRAMS */ /* */ /* Usage: lnk430 <obj files...> -o <out file> -m <map file> lnk.cmd */ /* cl430 <src files...> -z -o <out file> -m <map file> lnk.cmd */ /* */ /*----------------------------------------------------------------------------*/ /* These linker options are for command line linking only. For IDE linking, */ /* you should set your linker options in Project Properties */ /* -c LINK USING C CONVENTIONS */ /* -stack 0x0100 SOFTWARE STACK SIZE */ /* -heap 0x0100 HEAP AREA SIZE */ /* */ /*----------------------------------------------------------------------------*/ /****************************************************************************/ /* SPECIFY THE SYSTEM MEMORY MAP */ /****************************************************************************/ MEMORY { SFR : origin = 0x0000, length = 0x0010 PERIPHERALS_8BIT : origin = 0x0010, length = 0x00F0 PERIPHERALS_16BIT : origin = 0x0100, length = 0x0100 RAM : origin = 0x1C00, length = 0x0FFC INFOA : origin = 0x1980, length = 0x0080 INFOB : origin = 0x1900, length = 0x0080 INFOC : origin = 0x1880, length = 0x0080 INFOD : origin = 0x1800, length = 0x0080 ZAREA : origin = 0x1000, length = 0x0010 BSL430_VERSION_VENDOR : origin = 0x1010, length = 0x0001 BSL430_VERSION_CI : origin = 0x1011, length = 0x0001 BSL430_VERSION_API : origin = 0x1012, length = 0x0001 BSL430_VERSION_PI : origin = 0x1013, length = 0x0001 ZAREA_CODE : origin = 0x1014, length = 0x002E FLASH : origin = 0x1042, length = 0x07AE BSLSIG : origin = 0x17F0, length = 0x000C JTAGLOCK_KEY : origin = 0x17FC, length = 0x0004 FLASH2 : origin = 0x8000, length = 0x7F80 INT00 : origin = 0xFF80, length = 0x0002 INT01 : origin = 0xFF82, length = 0x0002 INT02 : origin = 0xFF84, length = 0x0002 INT03 : origin = 0xFF86, length = 0x0002 INT04 : origin = 0xFF88, length = 0x0002 INT05 : origin = 0xFF8A, length = 0x0002 INT06 : origin = 0xFF8C, length = 0x0002 INT07 : origin = 0xFF8E, length = 0x0002 INT08 : origin = 0xFF90, length = 0x0002 INT09 : origin = 0xFF92, length = 0x0002 INT10 : origin = 0xFF94, length = 0x0002 INT11 : origin = 0xFF96, length = 0x0002 INT12 : origin = 0xFF98, length = 0x0002 INT13 : origin = 0xFF9A, length = 0x0002 INT14 : origin = 0xFF9C, length = 0x0002 INT15 : origin = 0xFF9E, length = 0x0002 INT16 : origin = 0xFFA0, length = 0x0002 INT17 : origin = 0xFFA2, length = 0x0002 INT18 : origin = 0xFFA4, length = 0x0002 INT19 : origin = 0xFFA6, length = 0x0002 INT20 : origin = 0xFFA8, length = 0x0002 INT21 : origin = 0xFFAA, length = 0x0002 INT22 : origin = 0xFFAC, length = 0x0002 INT23 : origin = 0xFFAE, length = 0x0002 INT24 : origin = 0xFFB0, length = 0x0002 INT25 : origin = 0xFFB2, length = 0x0002 INT26 : origin = 0xFFB4, length = 0x0002 INT27 : origin = 0xFFB6, length = 0x0002 INT28 : origin = 0xFFB8, length = 0x0002 INT29 : origin = 0xFFBA, length = 0x0002 INT30 : origin = 0xFFBC, length = 0x0002 INT31 : origin = 0xFFBE, length = 0x0002 INT32 : origin = 0xFFC0, length = 0x0002 INT33 : origin = 0xFFC2, length = 0x0002 INT34 : origin = 0xFFC4, length = 0x0002 INT35 : origin = 0xFFC6, length = 0x0002 INT36 : origin = 0xFFC8, length = 0x0002 INT37 : origin = 0xFFCA, length = 0x0002 INT38 : origin = 0xFFCC, length = 0x0002 INT39 : origin = 0xFFCE, length = 0x0002 INT40 : origin = 0xFFD0, length = 0x0002 INT41 : origin = 0xFFD2, length = 0x0002 INT42 : origin = 0xFFD4, length = 0x0002 INT43 : origin = 0xFFD6, length = 0x0002 INT44 : origin = 0xFFD8, length = 0x0002 INT45 : origin = 0xFFDA, length = 0x0002 INT46 : origin = 0xFFDC, length = 0x0002 INT47 : origin = 0xFFDE, length = 0x0002 INT48 : origin = 0xFFE0, length = 0x0002 INT49 : origin = 0xFFE2, length = 0x0002 INT50 : origin = 0xFFE4, length = 0x0002 INT51 : origin = 0xFFE6, length = 0x0002 INT52 : origin = 0xFFE8, length = 0x0002 INT53 : origin = 0xFFEA, length = 0x0002 INT54 : origin = 0xFFEC, length = 0x0002 INT55 : origin = 0xFFEE, length = 0x0002 INT56 : origin = 0xFFF0, length = 0x0002 INT57 : origin = 0xFFF2, length = 0x0002 INT58 : origin = 0xFFF4, length = 0x0002 INT59 : origin = 0xFFF6, length = 0x0002 INT60 : origin = 0xFFF8, length = 0x0002 INT61 : origin = 0xFFFA, length = 0x0002 INT62 : origin = 0xFFFC, length = 0x0002 RESET : origin = 0xFFFE, length = 0x0002 } /****************************************************************************/ /* SPECIFY THE SECTIONS ALLOCATION INTO MEMORY */ /****************************************************************************/ SECTIONS { .bss : {} > RAM /* GLOBAL & STATIC VARS */ .data : {} > RAM /* GLOBAL & STATIC VARS */ .sysmem : {} > RAM /* DYNAMIC MEMORY ALLOCATION AREA */ .stack : {} > RAM (HIGH) /* SOFTWARE SYSTEM STACK */ .ZAREA : {} > ZAREA .BSL430_VERSION_VENDOR : {} > BSL430_VERSION_VENDOR .BSL430_VERSION_CI : {} > BSL430_VERSION_CI .BSL430_VERSION_API : {} > BSL430_VERSION_API .BSL430_VERSION_PI : {} > BSL430_VERSION_PI .ZAREA_CODE : {} > ZAREA_CODE .BSLSIG : {} > BSLSIG .JTAGLOCK_KEY : {} > JTAGLOCK_KEY .text : {}>> FLASH | FLASH2 /* CODE */ .text:_isr : {} > FLASH /* ISR CODE SPACE */ #ifdef __LARGE_DATA_MODEL__ .cinit : {} > FLASH | FLASH2 /* INITIALIZATION TABLES */ .const : {} > FLASH | FLASH2 /* CONSTANT DATA */ #else .cinit : {} > FLASH /* INITIALIZATION TABLES */ .const : {} > FLASH /* CONSTANT DATA */ #endif .cio : {} > RAM /* C I/O BUFFER */ .pinit : {} > FLASH /* C++ CONSTRUCTOR TABLES */ .init_array : {} > FLASH /* C++ CONSTRUCTOR TABLES */ .mspabi.exidx : {} > FLASH /* C++ CONSTRUCTOR TABLES */ .mspabi.extab : {} > FLASH /* C++ CONSTRUCTOR TABLES */ .infoA : {} > INFOA /* MSP430 INFO FLASH MEMORY SEGMENTS */ .infoB : {} > INFOB .infoC : {} > INFOC .infoD : {} > INFOD /* MSP430 INTERRUPT VECTORS */ .int00 : {} > INT00 .int01 : {} > INT01 .int02 : {} > INT02 .int03 : {} > INT03 .int04 : {} > INT04 .int05 : {} > INT05 .int06 : {} > INT06 .int07 : {} > INT07 .int08 : {} > INT08 .int09 : {} > INT09 .int10 : {} > INT10 .int11 : {} > INT11 .int12 : {} > INT12 .int13 : {} > INT13 .int14 : {} > INT14 .int15 : {} > INT15 .int16 : {} > INT16 .int17 : {} > INT17 .int18 : {} > INT18 .int19 : {} > INT19 .int20 : {} > INT20 .int21 : {} > INT21 .int22 : {} > INT22 .int23 : {} > INT23 .int24 : {} > INT24 .int25 : {} > INT25 .int26 : {} > INT26 .int27 : {} > INT27 .int28 : {} > INT28 .int29 : {} > INT29 .int30 : {} > INT30 .int31 : {} > INT31 .int32 : {} > INT32 .int33 : {} > INT33 .int34 : {} > INT34 .int35 : {} > INT35 .int36 : {} > INT36 .int37 : {} > INT37 .int38 : {} > INT38 .int39 : {} > INT39 .int40 : {} > INT40 RTC : { * ( .int41 ) } > INT41 type = VECT_INIT PORT2 : { * ( .int42 ) } > INT42 type = VECT_INIT .int43 : {} > INT43 .int44 : {} > INT44 USCI_B1 : { * ( .int45 ) } > INT45 type = VECT_INIT USCI_A1 : { * ( .int46 ) } > INT46 type = VECT_INIT PORT1 : { * ( .int47 ) } > INT47 type = VECT_INIT TIMER1_A1 : { * ( .int48 ) } > INT48 type = VECT_INIT TIMER1_A0 : { * ( .int49 ) } > INT49 type = VECT_INIT DMA : { * ( .int50 ) } > INT50 type = VECT_INIT .int51 : {} > INT51 .int52 : {} > INT52 TIMER0_A1 : { * ( .int53 ) } > INT53 type = VECT_INIT TIMER0_A0 : { * ( .int54 ) } > INT54 type = VECT_INIT ADC12 : { * ( .int55 ) } > INT55 type = VECT_INIT USCI_B0 : { * ( .int56 ) } > INT56 type = VECT_INIT USCI_A0 : { * ( .int57 ) } > INT57 type = VECT_INIT WDT : { * ( .int58 ) } > INT58 type = VECT_INIT TIMER0_B1 : { * ( .int59 ) } > INT59 type = VECT_INIT TIMER0_B0 : { * ( .int60 ) } > INT60 type = VECT_INIT UNMI : { * ( .int61 ) } > INT61 type = VECT_INIT SYSNMI : { * ( .int62 ) } > INT62 type = VECT_INIT .reset : {} > RESET /* MSP430 RESET VECTOR */ } /****************************************************************************/ /* INCLUDE PERIPHERALS MEMORY MAP */ /****************************************************************************/ -l cc430f5137.cmd
Questions:
- In the linker file, FLASH starts at 0x1042 and FLASH2 starts at 0x8000 on the MSP430F5438. Does this mean that FLASH is used for the bootloader and FLASH2 is used for the actual application? If so, does FLASH2 = 32kB or FLASH + FLASH2 = 32kB (FLASH on CC430F5137 is 32kB)
- I assume that flashing the bootloader is no different from flashing user application code and that you build the application and hit the Debug button in CCS and that will download the BSL to the CC430. Is this a valid assumption?
- What happens if there is a bug in the custom bootloader that I made? If so, doesn't that mean that the CC430 is completely bricked? I don't believe there is any way to reflash a BSL, is there? Or in other words, since the TI BSL that accepts SBW is gone, I will not be able to reflash the CC430 via SBW any more?
