how to install Grace 3?
Just re-installing the toolchains onto a Windows 10 machine, but I'm having real problems installing/finding Grace.
In the latest CCS, it seems Grace is no longer available from the AppCenter. I read somewhere that its been removed and we should use the stand-alone version. However, the only stand-alone version is v2.2 of Grace, which then complains about not supporting Windows 10 upon install.
Is there any way to obtain Grace 3, or do I need to completely downgrade to Win7/CCS5.5?
cheers
Mat
  • Hi Mat,
    You are correct that the GRACE plug-in is no longer supported in CCS v6.1.3 and that the stand-alone version is not supported inside of Windows 10. However GRACE is still supported in CCS v6.1.2 which can be downloaded from the CCS Wiki: processors.wiki.ti.com/.../Download_CCS
    Ryan
    As Ryan stated, you can still run Grace 3 from CCS version 6.1.2. Once you have that version installed and running, here is how you can install the Grace Plug-in:
    • Open CCS App Center (Help -> CCS App Center).
    • Using the search box inside CCS App Center, search for “Grace”.
    • Check the select button for the Grace component and click the “Install Software” button.
    Hope this helps,
    Scott
