Dear All,
I'm ESD-testing a product that uses MSP430FR5969 as the sole micro controller.
The product is battery-powered and wakes up every 10 minutes, 24/7.
The product fails the ESD test. After the failed test, the MSP is found with it's correct supply voltage and its oscillator running, however it's not doing anything and has an increased current draw.
A test pulse (1/s) that is present on P1.3 during normal operation is no longer present.
The MSP's watchdog is being used but it seems unable to restore normal operation. When I pull nRESET, everything goes back to normal.
What can you recommend to improve ESD performance of the MSP ?
Are there any known weak spots of the device or typical engineering errors ?
It is acceptable that the product passes out for a few minutes, as long as it recovers by itself. Maybe this facilitates a solution.
If an external watchdog is the way to go, which device can be recommended ?
Appreciate any suggestions.
Martin
