Part Number: MSP430I2021
Other Parts Discussed in Thread: MSP430WARE
I'm looking for an example of C code implementation to retrieve the temperature value in degrees of MSP430i2021 integrated temperature sensor. The formula is given at chapter 13.2.11 of slau335.pdf (http://www.ti.com/lit/ug/slau335/slau335.pdf ), unfortunately I have not been able to get a realistic temperature value so far.
I have also seen in the user guide that it is recommended to re-calibrate the temperature sensor offset error. What would you recommend regarding the calibration in order to get a meaningful temperature value reading (+-5degC) over a wide ambient temperature range (0degC to 80degC for example)?
Thank you in advance for your help,
-nico
