Part Number: MSP430F425A
Dear Forum Members,
I am interested in the the SD16 operation / charteristics and i would like tos some help.
First I would like to fully understand ist analog input.
Whether analog input is fully differential (on chip PGA performs differential to signle ended conversion to SD modulator)?
If so, external instrumentation amplifier may not needed when bridge sensor differential signal needs to be measured (of course - common mode range must be
kept in 0..VFREF range).
Can the AI+ and AI- be below the AVSS level? However, this would suggest analog input shall be ground (AVSS) referenced.
Therefore, not clear for me, whether signal input handling fully differential or AVSS refrenced allowing negative swing.
Other question referred to SD operation itself. Unfortunately, I am familar only with 1st order sigma-delta architecture. In this case for 10 bit equivalent resoulution
1024 clk cycle needed for 1 conversion. How many needed in case of SD16 (conversion speed)?
I know the oversampling principle but I cannot accociate with MSP430 SD16 or sigma-delta operation. Generally, OSR=fs/(2*fmax), where fmax is the upper frequency limit of the incoming signal spectra to be digitalized (Nyquist frequency, for sampling, fs= 2*fmax needed minimum avoiding spectral aliasing)
Thank you in advane,
Joseph
