Hello, I have the A1 timer set to generate a PWM signal that opens and closes a mosfet that powers the LCD display backlight . What is the correct way to disable the timer to stop the PWM signal (and therefore turn off the LCD display) and set the timer to its default values so you can use it again with other settings? Thanks in advance.
Fran Martin.
